Hi, Check and clean the disc. If the disc has too many finger prints it will be harder for the Wii to read. If that doesn't work try a laser cleaner disc. Good luck
If Wii gives Disc Read Error, first step you need to check is to try
another disc or clean the exisitng disc. This will confirm that problem
is with either Wii or Disc. If the console itself is giving disc read
error then it needs to be repaired. You may check out DIY Wii Fix Guide,
that will show step by step information to fix the problem yourself. It
also gives information on fixing many Wii Related Problems, so its a
kind of Wii Problems Reference Fix Guide.
Unplug all of the cords from the Wii, TV, and outlet. Wait an hour and plug it all back in and it should work. If it does not, then you will need to call Nintendo to get it repaired or replace the laser yourself. Thanks, I hope this helps!
kind of Wii Problems Reference Fix Guide. , .
I had the same problem, I take it you have a modded wii(chipped), if you use a backup disc it is of a lower quality then original discs, the wii gets read errors without you noticing and tries to read those disc areas again sometimes suceeding and the gaming goes on, sometimes it fails, and a disc read error occurs.
Over time the dvd assembly will take some damage it will loose it rigidity it once had and the wii stops reading discs.
The problem gets worse if you have standing up, so first thing si to flip it down and try.
Otherwise you (or someone you trust) will have to open the wii and adjust the lens sled so it wont flap as much up and down.
Hope this helps..
