Question about Dell W3706MC 37 in. LCD HDTV
W3706MC Rear Output Connectors Problem
There are two color coded (Red and Black) sets of output connectors for the speakers. One set quit providing sound to the speaker altogether, the other set works to some degree, except it sounds garbled, as if I was listening an AM radio station. Dell's Decision One (the company that fixes Dell TVs) solution? $687.00 for freight from VA to OH, $262.00 base price for diagnosing the problem, plus parts and labor. I might as well buy a new TV. Warranty is expired. Is there a way to replace those connectors? How can I find out the part number? Another Dell technician suggested I purchase a surround system but I am not sure if a surround system will solve the problem since one set of connectors does not work and the other sounds worst than my local AM radio station. Any suggestions?
  • 4 Answers
I bought one recently from the pawn shop. GREAT BUY for me because it had no sound. Hooking it up to an external Audio Receiver, I use the pass through (Audio Out) from the DELL, and it works like a charm. Try this out!
Posted on Jan 21, 2010
    New Friend:
  • 90 Answers
I would 1st confirm that the rattling is not comming from the speakers. hook different speakers up to test. if continue to garble, the boardmay have a short. ebay the description audio board for dell ???? you may find it.
Posted on Mar 24, 2009
Need the wiring diagram for a realistic eq booster model no. 12-1955
The main colors are:
Green - L+
White - L -
Brown - R+
Gray - R-
There are 3 sets of these. The ones with thinner wire are for high level input (from a stereo's speaker outputs). The two other thick sets are the speaker outputs to front and rear. They should've been attached to connectors labeled front and rear, if they aren't, you gotta find out through trial and error with the fader. Lastly, black is for ground of course, then the thin red wire is for 12V+ power (on with ignition), and the thicker red wire is power output to a deck, if you want it to turn on along with the amp/eq.
Apr 16, 2011 | Car Audio & Video
Tip
Wire connections for RAB250D w\casset radio
Here is the electrical wire connections for the Clarion RAB250D w\casset in dash radio by color code. Yellow w\fuse holder is battery + constant source needed to retain progamming memory. Black is ground - negitive chassis. Red is the ignition key on + switch source. The speaker connections you should note that they are paired colors. The black trace is the - negitive on the speaker polarity. The solid color is the + positive of the speaker polarity. Purple set is the right rear speaker. The Grey set is the right front speaker. The Green set is the left rear speaker. The white set is the left front speaker. There is one blue wire with a white trace which is a power output to a optional power amp. Isolate this wire if not in use. Cap the end or tape it.
on Apr 30, 2009 | Clarion RAB250D
I just moved and had someone disconnect my high end surround sound home audio system. I'm still trying 2 figure out the connections to the back of the speakers.. They are B & W Nautilus SCM1...
If your speakers looks similar to these...
You should see 4 connections on each speaker.
Look for a label that says "IN" or "INPUT"... probably the top connections. 1 is gold (with a red cap) and one is silver (might have a black cap on it). If you have the original cables, they will be red and black.
Attach the red cable to the gold... black cable to the silver. Do the same on the back of your audio system (more than likely red/black look for the "OUT" or "OUTPUT" connectors.)
The main thing is making sure the cables are connected to "like" colors (when possible).
The other two connectors on each speaker, if labeled "OUT" or "OUTPUT"... are for piggybacking more speakers. Otherwise, they are more than likely used as a "RETURN".
Apr 02, 2011 | Audio Players & Recorders
I urgently need a Clarion cd1500r installation manual or wirng color codes
Hello, here is Clarions wire codes.
FRONT Right SPKR: +Gray -Gray/Blk,
FRONT Left SPKR: +White -White/Blk,
REAR Right SPKR: +Purple -Purple/Blk,
REAR Left SPKR: +Green -Green/Blk
Brown Wire = Phone Mute Lead (If applicable)
Yellow Wire = 12V battery lead in (Connect directly to battery)
Red Wire = 12V Ignition wire (Connect to Acc switch)
Blue/White Wire = Amp turn on lead
Black Wire = Chassis Ground
Orange/White Wire = Illumination Lead (Connect to dimmer switch)
Blue Wire = Auto Antenna Lead (lowers power antenna Do not use for Amp Turn on! Use the Blue/White Wire for Amp,EQ, Ect.. turn on wire only
RCA Connectors if applicable:
Black RCA Harness:
White RCA = Rear Audio Left Sub Output 1
Red RCA = Rear Audio Right Sub Output 2
Gray RCA Harness:
White RCA = Front Left Audio Out to amp
Red RCA = Front Right Audio Out to amp
Oct 19, 2010 | Clarion Car Audio & Video
How do I connect external speakers to my set.
Look for the audio output connections.Sometimes,it is at the left or right side, top or back of the set.Usually, the color of the terminals are Red and Black & most of the time there is letter R & L beside each one.R stands for right chanel & L for left chanel. Buy the speakers with the same RCA
input terminal connections w/ that of your set Then buy the cables w/ RCA male connectors.Any sales person at Frys Electronics Costco Sears Best Buy will give you the right accessories you need.
Jun 26, 2009 | Dynex 19 in. LCD Flat-Panel HDTV
Marantz SR-940
Just finish repairing Marantz SR 940 with no sound output. Problem was a clamped speakers relay located behind the speakers lugs (red and black post connectors). To reach the relays you must remove the little circuit board behind those colored connectors et unsolder the posts. There is 2 relays, one for A set and one for B set of speakers. Very EASY when you know the solution!!
Nov 24, 2008 | Audio Players & Recorders
Rear Speakers do not sound, other 2 do, and boofer.
There are several reasons why there is no sound coming from the rear speakers.
  • Improper connection of the signal cable is a possible reason why there is no sound coming from the rear speakers.
7949.jpgGreen connector is for the front left and right channel. Black connector is for the rear left and right channel. Orange connector is for the LFE (Low Frequency Effects) subwoofer and the center channel.
The connectors for the Logitech products are color coded as explained. The connectors on the sound card may not be color coded or a different color coding maybe used depending on the manufacturer of the sound card. Check the manual for the sound card to make sure the correct connector is connected from the Logitech speaker to the sound card.
  • After verifying that the connections are made correctly, the sound card needs to be checked to make sure it is setup correctly. There are many sound card manufacturers so we cannot possibly cover every make and model. We recommend contacting the manufacturer of the sound card to make sure the sound card is setup correctly for use with analog 5.1 speaker systems.
  • When a software DVD player is being used to watch a DVD, the audio output needs to be set to surround sound mode. Please refer to the user manual for the software DVD player to check the settings.
Many DVDs have more than 1 sound format available. Just as the sound card and the software DVD player, the DVD itself has to be set to the correct sound format.
  • Finally you can test to see if the speakers are working correctly by plugging the front channel cable coming from the sound card to the rear channel connector on the subwoofer. If sound comes out of the rear speakers, then there is no problem with the speakers. The problem could be with the software DVD player, or the audio setting on the DVD.
THIS article can be used to test if your speakers are indeed working.
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. -You can rate this solution with one of four votes (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
May 04, 2008 | Logitech X-530 Computer Speakers
Logitech X-530 Speakers System
7949.jpg Green connector is for the front left and right channel. Black connector is for the rear left and right channel. Orange connector is for the LFE (Low Frequency Effects) subwoofer and the center channel.
Hope that helps!
IrishDruid
Need a wire color code for a ford radio f58f-18c815-aa
Notice, this is from the 2005 Ford F150 Wiring Harness. Other radios should be the same or very close. From the main 24 wire connector on back of radio (C290A).
Pin 1- Light Green w/Violet stripe - Voltage always
Pin 2- Light Green w/Yellow - Accessory delay relay output
Pin 3- Light Blue w/Red - Instrument illumination
Pin 4- Black - Ground
Pins 5, 6, & 7 - Not used
Pin 8- Orange w/Light Green - Speaker, left front +
Pin 9- Grey w/Light Blue - Speaker, left rear +
Pin 10- Orange w/Red - Speaker, right rear +
Pin 11- White w/Light Green- Speaker, right front +
Pin 12- Dark Green w/Orange- Speaker, right frt -
Pin 13- Black w/Light Green- Ground
Pin 14- Grey w/Black- Vehicle Speed Signal
Pin 15- Red w/Black- Voltage supplied in Start
Pins 16 & 17- Not used
Pin 18- Light Blue w/Red- steering wheel signal
Pin 19- Dark Green w/Orange- steering wheel return
Pin 20- Dark Blue- Parking Aid mute signal
Pin 21- Light Blue w/White- Speaker, left front -
Pin 22- Tan w/Yellow- Speaker, left rear -
Pin 23- Brown w/Pink- Speaker, right rear -
Pin 24- Not used
Good Luck
Feb 09, 2008 | Car Audio & Video
Connecting Durabrand SA51AR to computer
Each "red and white" represent a stereo pair (Right and Left respectively. What type of connectors are on the SA51AR? I will guess TS (tip sleeve) or Phono for the sake of this answer.
It sounds as if the PC's outputs are stereo TRS (tip, ring sleeve) 1/8" female connectors, which is normal. TRS connectors carry both the Left and Right signals whereas Phono and TS only carry one signal each.
Radio Shack has converters which will allow you to plug a "red and white" connector in one end (either TS or Phono) and will provide a TRS output on the other which will plug into your PC's sound outputs. That way, the Red/White pair for "Side Speakers" (front L/R) can plug into the one grey jack and the Rear (rear L/R) can plug into the black-jack, etc.
Feb 07, 2008 | Audio Players & Recorders
Dell W3706MC 37 in. LCD HDTV Logo
371 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
