Question about Dell DJ MP3 Player
Dj 30 power supply
Where can i buy a power supply for my dj30 dell
You mean battery try replacment ipod mini
Posted on Feb 27, 2008
Can the battery of a Dell Ditty be replaced? If so, how?
Hi, You can buy the battery at any mp3 player accessory store around your area, or you can other on line through eBay.com and Amazon.com.
How to Change the Battery in a Dell DJ-20..
The DJ is an MP3 player developed by the Dell computer company. Like any other battery-powered electronic device, the battery will likely give out and stop working at some point. If this happens to a Dell DJ, the two main options for fixing it are to send it to Dell to have the battery replaced, or do it yourself. You can save a great deal of time and money by replacing your own Dell DJ battery.
Things You'll Need:
* Micro screwdriver set
* Tweezers
Instructions
Hold the Dell DJ upside down so you have a clear view of the bottom.
Wedge a flat-head micro screwdriver in between the black plastic piece and the USB port on the bottom of the DJ. Pry the plastic piece off and set it aside. You should now see four tiny screws on the bottom of the DJ.
Remove the four screws with a micro Phillips-head screwdriver. Set the screws aside in a safe place.
Pull the metal plate out that was held in by the screws. You may need to use a screwdriver to help pry it out. Once removed, you will have access to the inside of the DJ.
Locate the small red cable with a white plug on the inside of the DJ. Carefully pull the plug out. If you cannot grab the plug with your fingers, use a pair of tweezers to do so.
Grab the battery with a pair of tweezers and pull it out. The battery is the thin rectangular piece that the red cable is attached to.
Insert a new battery where the old one was. Plug the battery into the motherboard where the first battery was plugged.
Reattach the metal plate on the DJ with the four tiny screws. Snap the black plastic piece back on to finish the job.
Feb 21, 2011 | Dell DJ Ditty MP3 Player
Just bought a Dell DJ30 NP3 player but it didn't have an instruction manual. Where can I get one?
This is the link to the dell.com
http://support.dell.com/support/downloads/devices.aspx?c=us&cs=19&l=en&s=dhs&SystemID=PDA_MP3_DJ_2&category=31&os=WW1&osl=EN
Jan 07, 2011 | Dell DJ MP3 Player
Dell DJ Ditty fully charged but shutting off due to "low battery"
charge your player and reset and try again if not works
then replace battery of your device that is damaged
Dec 25, 2009 | Dell DJ Ditty MP3 Player
Dell DJ 30gb not recognized in vista
try using a different usb cord and u can also use songbird to put songs on it
Aug 16, 2009 | Dell DJ MP3 Player
DELL INSPIRON 6400 WILL TURN ON BUT WONT CHARGE
I would try checking the power supply first before replacing the battery. The power supply is much cheaper and sometimes interchangabel with other models. Also try cleaning and reseating it. If you do end up needing a battery though dont buy it from dell. get it on ebay, amazon or a decent priced online store for best prices. If you're lucky you could get another one for about $20 or $30. good luck
Jul 13, 2009 | Dell Inspiron 6400 Notebook
My Dell DJ 30 works, but now I can't read my screen
Good morning...yesterday I dropped my Dell DJ...the music would play, but the screen went blank...nothing I tried worked...so I just let it play/run...then it came back on...so everything is fine now...thnak you
Jun 04, 2009 | Dell DJ MP3 Player
Installing Disc
Go to Dell.com and enter your service tag located on the back of the Dj. The information will come up. you can also see downloads and software. Just see if it's a JD 15, 20 or 30.
Apr 20, 2009 | Dell Pocket DJ MP3 Player
Dell adapter
The Pocket DJ is essentially a rebadged Zen Micro, and the Zen Micro chargers for it work.
Check this out:
http://www.monoprice.com/products/product.asp?c_id=108&cp_id=10832&cs_id=1
May 03, 2008 | Dell Pocket DJ MP3 Player
First Gen Dell DJ 20 Gig "File Cannot Be Written" Transfer Issue
Yahoo jukebox was bought out by Rhapsody. I had the same problem and their only solution was for me to buy a Rhapsody subscription. I know this is not the solution you want to hear but that seems to be the only way to keep any music that was stored using the yahoo jukebox.
Apr 08, 2008 | Dell DJ MP3 Player
Dell DJ MP3 Player Logo
61 people viewed this question
Top Dell Audio Players & Recorders Experts
jairo sanchez
Greg Cann
Greg Cann
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
