Question about Baby Lock Esante
Needle timing. Ihave a Model Ese2 . I have a quarter inch foot with a very tiny hole for the needle. I forgot to change the needle setting to the middle and broke my needle. They say that threw off my needle timing. I would like to know how to repair this myself since I have done it before and it cost $40 every time I have it repaired.
  • dvkh48 Feb 23, 2009
    Button Hole attachment doesn't make the button hole
  • Anonymous Mar 30, 2014
    I tried to change the needle the old one came out but I cannot get the new one in. I am using necchi needles
    New Friend:
  • 185 Answers
Timing of a sewing machine, which timing? Needle to hook timing is fairly simple, turn the hand wheel in the direction the machine sews until it is at bottom of the stroke. Continue turning it until it moves up 2.54 mm if it is timed correctly the point of the hook should be right behind the needle and passing above the eye in the middle of the scarf of the needle. There are several timing of a sewing machine, needle to hook, feed and swing timing.
Posted on Feb 23, 2008
How do I change my needle position to a scant 1/4 stitch
Unless your machine has multiple minute needle positions, you probably won't get a perfect scant 1/4 inch with that method. I haven't found a 1/4" foot or a needle position that gives a perfect scant 1/4".
Instead, look at setting a mark on the sewing machine surface that measures a scant 1/4" from the needle point. I use a ruler and set the needle point on a scant 1/4" from the ruler edge, then use painter's tape or something similar to mark the guide where the fabric edge will set.
Or, the fastest and easiest guide is a pad of 3X5 Post-It Notes. Measure a scant 1/4" from the needle point, remove the back sheet of a Post-It pad, and then align the sticky edge of the pad to the scant 1/4". Instant fabric guide that is easy to remove and is reusable.
How to Mark Scant Quarter Inch Seam with Painters Tape to Your Sewing...
Jan 28, 2018 | Sewing Machines
Does a quarter inch quilting foot come with the machine, if so what does it look like?
If your machine is considered a "quilting" machine, it may have a 1/4" foot included. However, most machines do not include the 1/4" foot. A quarter inch foot looks a lot like a basic presser foot except the edge should be 1/4" away from the needle.
FWIW, you can achieve a 1/4" seam by placing a ruler under the presser foot and gently manually lowering the needle point until it rests on the ruler's 1/4" mark. The ruler's edge would then be exactly 1/4" away from the needle. You can place a piece of painter's tape (on the sewing surface) adjacent to the ruler edge and this would serve as your quarter inch guide.
Even if you decide to purchase a quarter inch foot, in my experience, none of them provide the "scant quarter inch" seam for piecing. Other than marking a scant quarter inch measurement on your sewing machine, achieving it will usually take some testing to determine what constitutes a scant quarter inch on your machine.
3 Ways to Master the Perfect Quarter Inch Seam
http://quiltville.com/quarterinch.shtml
Scant 1 4 seam allowance
Accurate Piecing Basics Quarter inch Seams WeAllSew
Jan 18, 2018 | Sewing Machines
Which presser foot is best to use for piecing quilt shop?
Probably the 1/4" quilting foot. It is designed so it's easier to sew a scant 1/4" seam by aligning the fabric edge to the foot's edge, which is what you need for piecing. Of course, to get it perfectly accurate, you may need to move the needle slightly or figure out where exactly 1/4" from the needle falls on your machine (important if you will be matching points in your piecing). Measuring 1/4" from the needle and then marking with a strip of painter's tape works for some.
https://www.connectingthreads.com/tutorials/How_to_Sew_an_Accurate_Quarter_Inch_Seam_Allowance__D95.html
Nov 29, 2017 | Sewing Machines
What is the setting for the 1/4" foot
Generally, it is assumed that you set the needle at the center position and align the fabric edge with the edge of the 1/4" foot. However, there is a degree of variance from one machine to another, so it is a matter of testing your machine. For quilt piecing, most often the sewist will have to adjust the fabric position to stitch a "teensy" bit less than the edge of the 1/4" foot. Again, it is a matter of testing your machine and adjusting your fabric. For those with computerized machines with many needle position settings, some sewists are able to adjust the needle one needle position to the right to attain the "perfect" quarter inch.
how to achieve 1/4" seam Internal Server Error
Sep 06, 2017 | Sewing Machines
Keep breaking needles after putting down presser foot
Sounds like you need the manual. This will give you a lot of basic information on how to use your machine. Please read the book all the way through.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwit24G7z-bSAhWqwFQKHZjPD1YQFggcMAA&url=http%3A%2F%2Fwww.brother-usa.com%2FModelDocuments%2FConsumer%2FUsers%2520Manual%2FUM_XL_2600_2610_3500_3510_EN_206.PDF&usg=AFQjCNGxRYCu023uIgfNhqFvn7XXwkK2CA
Also, check that you are using the proper presser foot for the stitch you have selected, ie do not use a zig-zag stitch with an embroidery presser foot that has only a tiny hole for the needle. Be sure you are installing the needle correctly. If the needle is backward, it could be hitting. When a needle hits something solid, it could knock the machine out of time, requiring a service call. Before running the machine, you can check whether the needle will clear by hand-rotating the handwheel one full cycle. If the needle strikes something, at least you can stop before it breaks or causes further damage.
Mar 21, 2017 | Brother Sewing Machines
The needle keeps breaking
Either you have the wrong foot installed or your stitch setting is incorrect. Dial in a narrower setting. You may have a zig-zag setting without the zig-zag foot attachment, or your "width" dial is too wide for the foot's hole. Slowing turn the wheel and watch where the needle penetrates the foot hole. A collision at that point will break your needle every time!
Apr 24, 2016 | Kenmore Sewing Machines
Crazy question but .....how do you center the needle? Always sits to the left
Don't know about your particular model, but maybe left is the normal "resting" position. When on zigzag it will move to the right then back to the left. As long as all of your different stitch patterns keep the needle between the limits of the hole above the shuttle and does not hit the machine bed then I would best guess everything is fine.
Hope that is of some help.
Jan 21, 2016 | Singer 3321 Talent Sewing Machine
The needle is hitting the needle plate (and breaking, of course) instead of going through the hole to the bobbin
I am wondering if it could be an issue with the type of needle you put in there. I am having trouble with a sewing machine tension and the store people told me that you have to use the manufacturer/ original style bobbin (it's engineered to fit the gadget 'Just so').
I know on my non-computerized Brother sewing machine, that I can change the needle position to L/M/R and I see it move when I move it left and right.
I guess you've probably checked all of the other settings on your machine?
Is the presser foot coming unscrewed?
Mar 03, 2014 | Brother PE770 Computerized Sewing Machine
Needle keeps breaking Model 150 Euro=Pro Sew Machine
broken needles can happen if you are pulling the fabric through rather thsn letting feed dogs move it, or if stitch setting needs a wide hole foot but you have straight stitch foot on. could also mean timing between needle and shuttle is out of sync.
or needle size is too small for weight of fabric you are sewing.
check out www.sewing.about.com for needle size info and use new needle for each new project.
if yoy suspect timing out take to technician for fulk service.
Jun 16, 2011 | Euro-Pro Sewing Machines
Sewing Machines Logo
719 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Jon Piercy
Jim Goldsmith
Jim Goldsmith
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
