Gateway M305CRV Notebook Logo
Posted on Jan 29, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Laptop monitor connections
There is a black and white wires comming off the monitor of my gate way laptop are they used?
Anonymous
Level 2:
  • Expert 56 Answers
  • Posted on Jan 29, 2008
Anonymous
Expert
Level 2:
Answers
56
Questions
0
Helped
18528
Points
155
The wires are probably the receivers for your wireless card.
  • Anonymous Jan 29, 2008
    On some Dells that I have seen, if you take the keyboard off, you will see these two wires run into the card. So to be 100% sure, you would have to trace their origin.
I am trying to connect to gate way monitor
You need a cable from the "audio-out" from your laptop to the "audio-in" port on the Gateway, to transmit the sound to the monitor.
Only BLINKING COLOURS LIKE RED WHITE BLACK
If the problem is with laptop monitor, try restarting the computer. If problem remains, try connecting your laptop to external monitor to see if problem is with laptop monitor or with display adapter.
If picture also like this with external monitor and with laptops own monitor after reboot, possible HW issue can be expected.
Gate opener
obviously something else is wrong causing the batteries to go bad OR there is a capacitor in there and this is normal. check with the manufacture
Dec 28, 2013 • Baby Gear
Display divided into 3 parts
LCD screen cracked, and Three even strips going across? Doubtful. Haven't seen it but I always have my mind open.
Three strips that are irregularly shaped? Look like glass that has cracked?
'Jagged edges'?
LCD screen is broken.
Three even strips indicates to me, that there may be a problem with the Video Cable. Then the screen Inverter is next in the diagnoses.
My money is on the Video Cable.
ALL power removed, Anti-Static Precautions FOLLOWED, I would check out the graphics chipset first.
1) Laptop OFF, monitor OFF, connect a VGA monitor to the VGA port on the laptop.
Left rear side. This is an example of a VGA Cable, and VGA connector. (VGA port on a laptop ),
http://en.wikipedia.org/wiki/VGA_connector
(Color of connector does Not matter. It is generally Blue, though)
You can use a CRT type of monitor, (Looks like a small TV), or a flat LCD screen monitor if it has a VGA cable.
2) Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
There are at least 3 display options available;
1) Laptop internal monitor ONLY
2) Laptop internal monitor AND external VGA monitor
3) External VGA monitor ONLY
Press, and hold down on the Fn key, and at the same time tap once on the F5 key. (The F5 key is the Display Toggle-Over key)
No display on external VGA monitor?
Hold the Fn key down again, and tap once more on the F5 key.
Is the display on the external VGA monitor, the same as the internal monitor of the laptop?
Problem is the graphics chipset.
Display is fine on the external VGA monitor?
Problem is the Video Cable, screen Inverter, or LCD screen.
Video Cable:
A) http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/big/Toshiba-Satellite-A105-14.jpg
Switch Cover removed, Keyboard removed. Shows you where the Video Cable plugs into the motherboard.
B) http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/big/Toshiba-Satellite-A105-21.jpg
Palm Rest Cover you can see the white rectangular connector, for the motherboard side of the Video Cable, at the top left.
It's above the black cable, and near the screw hole.
The Video Cable leads from the motherboard, up through the left Hinge, and into the Display Assembly.
From there it connects to the screen Inverter, and back of the LCD screen.
http://www.ebay.com/itm/Toshiba-Satellite-A105-6017B0050801-LCD-Video-Cable-Genuine-OEM-Laptop-TESTED-/290754851160?forcev4exp=true&forceRpt=true
In the photo, (You can hover your mouse cursor on it to enlarge), the right side connector plugs into the back of the LCD screen.
The black connector to the far left connects to the motherboard.
The small white connector at the top with the Red, Green, Black, etc wires, connects to the screen Inverter.
(The small Black cable, that comes out from the black motherboard connector, is a Ground wire )
Due to the close proximity of the Video Cable to the left Hinge, it can be pulled on from just normal opening, and closing of the laptop over time.
This means the Video Cable connection on the motherboard side could be loose, or the LCD screen side, or both.
The diagnoses is to PHYSICALLY check BOTH connections. A loose connection at the motherboard, or at the back of the LCD screen could be so small in distance, that you will not see it with the human eye.
Could also result in damage to the Video Cable.
View the Video Cable with the Switch Cover removed, and see if there are any obvious signs of damage to the sheath of the cable.
If there is there could be damage to the tiny wires inside the Video Cable. (Stretched/Broken)
Use a multimeter set to OHMs, to check all wires inside the Video Cable for continuity, or have a 'Mom and Pop' computer store check it for a few bucks, or replace the Video Cable.
Video cable connections are tight? Video cable continuity check checks out OK?
Screen Inverter.
The test for a screen Inverter is to use a sensitive multimeter.
Read fairly expensive.
http://www.fonerbooks.com/test.htm
Not having access to a sensitive multimeter that you can use, means just replacing the screen Inverter. Seems like 'part changing', and it is, but you have to work with what you've got.
http://www.sparepartswarehouse.com/Toshiba,Satellite,A105,Laptop,Inverters.aspx
Find THE model number for your laptop, and the correct screen Inverter. A screen Inverter, and an LCD screen are a MATCHED unit.
Screen Inverter is checked out to be OK, or replaced, and symptoms are still the same, the problem is the LCD screen.
Remember, the first part of the diagnoses was to see if the divided parts were EVEN going across, or jagged and irregularly shaped.
Jagged in shape, and not even strips going across, means cracks in the LCD screen.
Replace.
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-replace-LCD-screen-1.htm
[ Main article for A and B links above;
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-motherboard-1.htm ]
For additional questions please post in a Comment
Regards,
joecoolvette
I can not se where the connection white from the lcd monitor goes to circuit board
The lead you are talking about, more than likely, is the wireless antenna wire. It has a tiny connector that preses on to the connection on the wireless card. The card usually has two connections one a black wire and the white. Use great care in attaching them to the card, as they can be damaged easily.
If this information was helpful, Please rate it. Thanks
Raypak 2100 r405 wiring? has one red, one white and red, one black, one white and black and green ground. How do I wire for 120
Wire the red and red tracer toghther and the black and black tracer together then wire these to your 110v lines then green to your green.
Splicing a monitor output wire from my laptop to
This cant be done.. You need a video card that has the yellow jack [video out]
the red and white jacks are your sound,
get a headphones to RCA adapter for the sound card[computer] going to projector or radio...[just need the RCA adapter to get sound]
But to get the video[yellow jack] to work you NEED a video card with a yellow jack inslled in your computer...or a video card that has a adapter for RCA video
I have a
3helpful
4answers
Dell Latitude XT2 fails to start up.
I know this is an old post, but the LED code for CAPS lock on, F4 flashing, F5 on means memory issue. I had this issue, reseated the memory, and the issue was resolved.
Gateway 400vtx - Reconnecting laptop monitor to laptop base
Find the location of the GPU. The connector should be located near it.
1helpful
Black screen, White blinking line on bottom of Monitor
During the move was your laptop dropped or bumped ? If so you might of unseated the video adapter from your laptop. Have you tried another monitor? I wouldnt rule the monitor as the problem. Try another monitor. If you have more questions or problems feel free to get back to me and I will do my best to talk you through a solution.
Top Gateway Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
