Question about Nintendo Wii Console
Wii Remote My Wii remote just started continously vibrating overnight. I have tried changing the batteries, different batteries etc but it will not stop vibrating. You can still use it to play games but as you can imagine it kinda hurts your hand after a while. Please Help!!
  • 28 Answers
Press the home button and go to your setting and try turning the wiimote volume up
Posted on Jan 30, 2008
Wii fix guide
Try this link it may help. If not there may be an issue with the console or controllers. Try the controllers on a different wii. Try a different controller with your wii. Wii Remote Not Working or Syncing Correctly Wii and Wii mini Nintendo...
Aug 21, 2014 | Nintendo Wii Remote Controller
Wii remote just stopped working changed batteries but it is dead no lights no vibration
Hold the power button on the remote for 30 seconds. If still no response the remote may be bad.
Apr 10, 2014 | Nintendo Wii Console
How do you re-align a Wii remote?
To Adjust the Wii Remote Pointer Sensitivity, follow these steps..
Wii
  1. Access System Settings.
  2. Select "Sensor Bar."
  3. Select "Sensitivity."
  4. Aim the Wii Remote at the television.
  5. Use the + and - buttons on the Wii Remote to adjust sensitivity until only two blinking lights appear.
  6. Press the A button when done.
Wii U
  1. From the Wii U Menu, select "System Settings."
  2. Using the Left Stick, scroll to the "Wii Remote and Sensor Bar" icon and press the A Button.
  3. Select "Adjust Wii Remote Pointer Sensitivity."
  4. Tap "Next."
  5. Point the Wii Remote at the sensor bar and press the A Button.
  6. With the Wii Remote pointed at the sensor bar, press the - and + Buttons to adjust the sensitivity so that only two white dots are visible in the black window.
  7. When you are finished, press the A Button.
  8. On the Wii U GamePad screen tap "OK."
Please
Dec 14, 2017 | Nintendo Wii Console
Wii remote vibrates
Unfortunately I don't thin this can be fixed short of opening it and disconnecting the vibration motor. I'm pretty sure either the relay that drives the vibration or the transistor that drives it have failed. you could give it a whack and see if that fixes it but from what your describing it sounds like a shorted component.
Sorry
Mar 30, 2009 | Nintendo Wii Console
2nd Wii remote not working
sounds like you have a defective wii-mote to me...time to find out how that warranty / exchange program is
Feb 15, 2009 | Nintendo Wii Console
Wii Remote will not stay sync with console
Have you tried the following? If this doesn't work then pleae provide details on details such as the batterys you are using, number of remotes, etc.
The Wii maunual does not give clear instructions how to reset and sync your Wii remotes. I have found that from time to time my remotes will not sync, especially after they have changed 'order' a couple of times. It appears there is a bug in the code that keeps track of remote codes, and it has a limited buffer for the storage of remote ID's / order. Here are quick step by step instructions how to reset the remote list on the Wii console and re-sync your Wii remotes.
  1. Un-plug the power cord from the back of the console for 5 minutes (60 seconds should do, but leave it off longer to ensure all the power drains).
  2. Plug the Wii back in, and turn on the power button.
  3. Open the panel on the front of the Wii unit. You will see a Red button.
  4. Open the back panel of the Wii remote where the batteries are installed. Beneath the batteries is a small button.
  5. Press and release the small button. The Blue lights on the front of the remote begin to flash.
  6. Press the Red button on the front of the Wii unit.
  7. The Blue lights on the remote should stop flashing after a few seconds. Then one Blue light will remain representing player 1.
  8. Repeat for remote 2, 3 and 4.
Dec 28, 2008 | Nintendo Wii Console
Wii remotes will not go on at all
try to put regular batteries in the remote, see if it still has the problem. if not it is the rechargeables
Dec 26, 2008 | Nintendo Wii Console
Playing Wii Fit, continually get message:Communications with the wii remote have been interupted press A to reconnect the wii remote. Have changed batteries, help?
try checking the sensor bar connections, moving the sensor bar around to different positions.. higher/lower/left/right/closer/further. also if you have shinny background behind the sensor or sunlight/bright lights these will cause loss of signal. check the bar and remotes for oily film. last thing try a different remote if it does the same thing your sensor bar may need replacing if it doesn't the remote could be defective. hope this helps.
Sep 15, 2008 | Video Game Consoles & Games
Wii remotes
Try changing the batteries. If you have the rechargable battery, then put in some regular batteries and see if that makes a difference. Also try and re-sync the remote to the Wii. Also, make sure the se4nsor bar is plugged into the Wii and not damaged. I hope this helps. Good luck.
Aug 15, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
139 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
