Question about Vacuums
How to replace belt
I have a Riccar 4508 and need to replace the belt. Tell me how to do this.
  • Lauren Junge
    Lauren Junge May 11, 2010
    Are you sure that the model is a 4508?
    President:
  • 1,673 Answers
Most Riccar's, turn vac over, take off the bottom plate, Brush roll and belt are there. Put new belt over motor shaft, then over brush roll, push brush roll back into place and re-install bottom plate.
Posted on Jan 31, 2008
Why does the belt on a riccar vacuum keeps coming off?
The cause could be different depending on which model you have. Some models have stretch belts which should be replaced at least once per year because they lose elasticity. The most common problem I've found with Riccar vacuums is the belt coming off when a new belt is installed on an older model. Riccar vacuums are very well built and many owners use their vacuum for many years without having it serviced. I recently had a 17 year old Riccar Vibrance model brought in for service because the belt crumbled to pieces. The vacuum had the original belt and filters. Putting a tight new belt on the vacuum pulls on the motor because it must be stretched so much. After many hours and years of use screws may need tightened up and motor mounts and pivot points can become worn.
If your model is a few years old or is used heavily I suggest having it inspected by a qualified Riccar service center. A properly maintained Riccar vacuum can last 10 or even 20 years. A few dollars spent on maintaining it can add years to the usable life.
Feb 04, 2017 | Riccar Vacuums
How do i replace the fan on a riccar rsl3 vacuum cleaner?
RICCAR SIMPLICITY SUPRALITE RSL MOTOR and FAN
Its looks the same as a Kirby its done with a nut on the axle on the armature of the motor.
Feb 20, 2016 | Riccar Vacuums
What size replacement belt for riccar 1700 vacuum
You need to contact your local Riccar dealer. They are not available except from Riccar dealers.
www.riccar.com
Sorry.
May 30, 2014 | Riccar 3623210300 RC 1700, 1800 Full Size...
Riccar upright beater bar won't spin
Start by replacing the belt. Stretch belts should be replaced at least once per year because they lose elasticity. If that doesn't solve it have it check out by your Riccar dealer. It may be the clutch pad or might need adjusted.
Apr 06, 2014 | Riccar Vacuums
How can I replace the belt on a Riccar Rad 8 model
Your belt should not need replaced unless it has over heated the belt somehow. It has a lifetime belt. There are screws on the bottom of the vacuum that allow the cover of the nozzle assembly to be removed to gain access to the belt area. It may be less cost in the long run to have it looked at by a Riccar repair technician.
Mar 30, 2013 | Riccar Vacuums
I NEED A BELT FOR A RICCOR 8900..............................PART NUMBER A20-R2 CAN YOU TELL ME WHICH ONE I NEED.....................THANK'S CRISTA HARDIN
You seem to have two model numbers. I plugged the following into Google and got plenty of locations for Riccar belts.
Riccar 8850 Vacuum belts
You can do this and find a supplier you might want to deal with.
Sep 15, 2010 | Riccar 8850 Vacuum
No suction on carpets
The reason it doesn't pick up on the carpets is because the belt is stretched or worn and can't turn the roller brush against the resistance of the carpet. Here is a link to the replacement belts you need:
Riccar Upright Vacuum Belts
Dec 29, 2009 | Riccar 8850 Vacuum
Riccar 8800 belt replaced but now floor brush won't spin
Are you sure that you get the right sized belt? This is the correct one you need:
Riccar 8800 Belt
Dec 15, 2009 | Riccar 8850 Vacuum
Broke need replacement belt
You can get replacement belts for that model here:
Riccar 8955 Replacement Belts
Dec 02, 2009 | Riccar 8955 Upright Vacuum
Vacuums Logo
136 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
