Question about HP LaserJet 1000 Printer
Noise when paper is feeding through the HP 1000
It has a funny nocie when the paper is going through
Dust makes it clean and lubricate
Posted on Feb 26, 2008
Funny noise indicating that there is a paper jam while there is nothing what to do to clear that noise.
instead of paper jam might had a miss feed which is the paper cant be picked up. which draw all draws? broken gear (s)
Dec 14, 2015 | Konica Minolta Bizhub C652 Color Copier,...
Keeps saying load paper, paper is in
Are the rollers worn out? If they have a slick appearance, that is your problem. Also examine the tray and see if it is lifting properly.
Sep 30, 2017 | HP Photosmart 3310 All-In-One InkJet...
Hp printer deskjet 1000 will turn on, yet paper will not go into printer computer states it it working ok
Try sliding the paper further in, from my experience with these printers the paper has to fit snugly over the belts to feed in properly.
Nov 12, 2011 | Office Equipment & Supplies
We have a HP laser jet 5 - it keeps paper jamming and makes a funny noise
There is no easy fix. You need to find the broken part and order a replacement. LJ5s need to have the feed rollers replaced after a few years, so I'd start by looking at anything with a rubberized roller on it. Check any gears for missing or malformed teeth.
I get my parts from irgplotters.com by calling in and asking for them. They have experts on staff that do this stuff all the time.
Feb 28, 2011 | HP Office Equipment & Supplies
My HP laser printer 1300 had a paper jam
When printing or copying, paper will not pick up or feed into the HP LaserJet 1000, 1200 or 1300 series product causing paper jams or wrinkled output. Symptoms are as follows:
  • The pickup roller will spin and try to pick paper.
  • The paper will partially feed into the product accompanied by a crackling, crunching noise then jamming.
  • The paper may feed all the way through the paper path accompanied by a crackling, crunching noise. The output will be skewed and wrinkled.
SOLUTION: Reposition the black Mylar light shields back into the proper position.
  1. Unplug the power cord from the product.
  2. Remove the paper and paper input tray.
  3. Slide hands, palms side up, into the paper input tray cavity (see Figure 1) until the fingertips reach the end of the cavity. Figure 1: Paper input tray cavityc00068598.jpg
  4. Bend fingers up to push the black Mylar light shields back into place. The proper position of the black Mylar light shield will be flat.
  5. Reconnect the power cord.
  6. Print a self-test/configuration page to verify product is functioning correctly.
Feb 24, 2011 | HP LaserJet 1300 Printer
Have a hp laserjet 4l paper jam problem.No paper is jamed inside.Press the reset button,goes through its cycle process. See the D shape roller sensor working,but no paper is being pick-up.Hear a funny...
I have had a similar problem. The 4L has an inherent fault in the motor drive gear. It is made of nylon and has probably developed a hair line crack. As a result the gear slips when the printer starts up and tries to feed paper. I have replaced this part some years ago by replacing the whole motor and gear. I did find the replacement parts on eBay today. Here's the url:
http://stores.shop.ebay.com/Laserprinterkits-Printer-Repair__W0QQ_armrsZ1QQ_fsubZ4
The manual is also on line at another place. But when you order the parts you get a manual on CD. I am not the guy selling the parts but need them too that's how I found them.
Good luck.
May 04, 2009 | HP LaserJet 4L Printer
Paper feed
Yep the paper feed roller wears and will need replacement (open front cover in centre of machine tabs on either side it just clicks out.
should also change sep pad (multi feeds)
Here in LINK to purchase items pic below
Dec 21, 2007 | HP LaserJet 1000 Printer
Printer won't print
you will have to lift all the compartments up and look for any loose paper.
Dec 06, 2007 | Brother HL 1440 Laser Printer
Open Questions:
See all HP LaserJet 1000 Printer Questions
HP LaserJet 1000 Printer Logo
75 people viewed this question
Ben Johnson
