Amazingly enough, If one or more of your brake lights is burned out this can cause the Glow plug indicator to flash, replace the burned out bulb(s). This often sets a Code but will not turn on the Check Engine light. It took me forever to find this solution first time it happened. I've seen it many times since.
Testimonial: "Thanks very much you saved me alot of money"
Check your brake lights and brake light switch. These brake light switches are a common problem with vw's. They can become intermittent and can also fail off or on. A revised switch is availible from Vw if this has failed on your car., Good luck
SOURCE: glow plug light flashes after can has been running
obviously there's a problem with the system... your best SOLUTION is take it in for proper DIAGNOSIS.. ya think?
SOURCE: I have a 2003 TDI jetta and glow plug light keeps
Sounds like it is telling you that you need to get a glow plug replaced that is not functioning properly. Have a reputable shop let you know which one it is.
