Question about Ice Cream Makers
Taylor ice cream machine 751
I have an Taylor 751 and one of the two milk shake mixers by waring slowed down and than quit. I found a in line fuse. I think that there may be a reason for the fuse to blow.
Charles
    Problem Solver:
  • 9 Answers
First the machine slows down cos the milk mix is over frozen the set point on your control board must be to high or damaged try adjusting the white plastic cooler control down ( turn ccw to lower) this shut bring the compressor and mixer run time down if note turn the adjustment no more than 1/8 of turn.
The machine must be pluged and turn on to adjust good luck and be really careful.
Posted on Apr 15, 2009
    New Friend:
The shake mixers are an add on to the machine so it should be easy to repair just the mixer itself and use it and the other mixer in the mean time. most of the wiring and fuses for the mixers are separate from any for the operation of the ice cream machine.
Posted on Feb 01, 2008
Taylor 490 ice cream machine is shutting off
For Taylor ice cream machine maintenance, please see our Support page or our Youtube channel. Providing ice cream equipment maintenance to you for free!
Ice Cream Machine Support
May 02, 2014 | Taylor Ice Cream, Shake Machine 490-33
I need to down load a manual for ge ice cream maker model 106765
  • 1
    Place the mixer bowl in the freezer. The amount of time required depends on the temperature of your freezer, but you should expect to leave it in the freezer for about one day prior to use. To check if the bowl is frozen, shake it gently. If you don't hear any liquid sloshing around inside, it's ready to use.
  • 2
    Place the mixer bowl onto the motor base when you're ready to make ice cream. Insert the mixing paddle into the bowl and place the cover over the bowl.
  • 3
    Turn on the ice cream maker and pour the ice cream mixture into the hole at the center of the appliance until it reaches the fill line. Do not exceed the fill line, as the ice cream will increase in volume as it freezes. Use the low setting if you want a firm ice cream and the High setting if you want a softer consistency. Do not add nuts, candy or chocolate chips at this stage as they can become hung up in the mixing paddle and stop the machine.
  • 4
    Cover the center hole with the cap and allow the ice cream maker to run for 30 to 45 minutes.
  • 5
    Add mix-in ingredients such as nuts and candies two minutes before shutting down the machine.
  • 6
    Turn off and unplug the machine prior to removing the ice cream from the bowl. GE recommends using plastic or rubber utensils to avoid scratching the inside of the mixer bowl.
  • Read more: GE Ice Cream Maker Instructions ' eHow.co.uk http://www.ehow.co.uk/how_7784888_ge-ice-cream-maker-instructions.html#ixzz1ahXwP2GR
    Sep 09, 2011 | Gel Canister 106765 1.5 Quart Ice Cream...
    Ice cream machine was making ice cream and now the machine runs but will not freeze the mix it is like a milk shake
    a.improper pressure switch setting . b. low refrigerant level. c. TQC needs adjusting. d. faulty solenoid. e.insufficient mix in freezing cylinder.
    Sep 06, 2010 | Taylor 632-27 Ice Cream Maker
    My taylor freezemaster ice cream machine does't work properly
    I can not get the plugs out of the back of the machine. In the hopper
    Jul 03, 2009 | Rival 8550-X 5 Quart Ice Cream Maker
    Taylor 8756 ice cream machine clogs at face
    i need to know where i may go to get directions to put this taylor 8756-22 ice cream machaine back togeather if you can help please e-mail me at johnjohnson1967yahoo.com thanks
    Jun 01, 2009 | Taylor 632-33 Ice Cream Maker
    Is there anyway I can find out how old my Taylor 751-27 is by its serial number?
    Just call your local taylor distributor. there is one in Cummings Ga. The number is 770-458-5546.
    May 09, 2009 | SaniServ 401 20 Quart Ice Cream Maker
    Taylor 751 sp dead
    Sound like you might have a loose wire or ribbon cable,might even be a loose wire on switch.Be sure to turn breaker off to machine and unplug it before you check them. Also check the motor reset.
    Jan 24, 2009 | Taylor 632-27 Ice Cream Maker
    Taylor ice cream maker single serve
    You can't. Taylor won't send you one unless you are a foactory trained technician. Sorry
    Oct 19, 2008 | Taylor 632-33 Ice Cream Maker
    Ice Cream Makers Logo
    573 people viewed this question
    Top Ice Cream Makers Experts
    Marvin
    Marvin
    ray gallant
    Ruth summersides
    Are you an Ice Cream Maker Expert? Answer questions, earn points and help others
