Question about Samsung HLT6176S Television
HLT6176S bowing on bottom only
I have a Samsung HLT6176S that is bowing only on bottom more than an inch any suggestions
3 white pixel dots on the screen, just replaced my bulb.
If the white pixel dots start to multiply then Problem will be in the DMD board or the Light Engine.
PTS rebuilt boards/ Light Engines 1-800-844-7871
Samsung Parts 1-800-627-4368
May 30, 2011 | Samsung HLT6176S Television
My 52 inch rca hdtv comes on but it looks like the screen is bowed and the colour is off.do you know of any solutions to this problem.
My rca 52 inch hdtv picture looks bowed on the top and bottom of screen. And everything looks like it has a red shadow behind it.
May 12, 2010 | Televison & Video
Samsung HLT6176S forgets the menu settings when it turns back on
probably stuck in shop mode mine did that and i di no know it it's in your owners book how to change
Nov 13, 2009 | Samsung HLT6176S Television
Blue convergence is bowed
The Convergence circuit probably has failed and unless you are familiar with the circuitry I
would suggest getting a professional repair facility. If you are, replace the convergence IC's and also look for any open resistors for the Blue Sub-Yoke
Hope this helps,
Skyassoc
Jun 24, 2009 | Hitachi 50GX30B 50". Rear Projection...
I have a 61 inch Samsung DLP. Works great except
it is configurable in the menu options. if you change there and goes back to how it was then you are probly in shop mode.
Mar 03, 2009 | Samsung HLT6176S Television
Philips 46-inch Rear Projection with bowed image?? slight distortion
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when when using the convergence menu.
Screen is bowed in but stationary.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit inlcludes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself. Its an easy fix.
Jul 02, 2008 | Philips 46PP9302 46" Rear Projection...
Bow at top and bottom of the screen
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 10, 2007 | Samsung HCM5525W 55" Rear Projection...
Televison & Video Logo
119 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
