Sherwood RD-6500 Receiver Logo
Posted on Dec 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The lighted display on my receiver has gone out. I am unable to see or change the channels. Can it be fixed?
Anonymous
Level 3:
  • Master 15,935 Answers
  • Posted on Dec 30, 2009
Anonymous
Master
Level 3:
Answers
15935
Questions
19
Helped
5034739
Points
35540
Yes - the bulb can be replace at a local electronics repair shop for around $75 depending on your location.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Iam unable to find why the tv is skipping from channel 2 -9leaving us unable to view 3/4/5/itv2.Is ther a possible transmitter fault
Try having the TV tuner run the process of re- indexing / re- discovering the channels
That should immediately tell you if the receiver is having a problem
If it cant connect to known good channels then there may be a failure on one of the boards
Othwise that should fix the problem and allow access to the skipped channels
Accidently changed something and not able to get antenna tv now - do not ahve cable here at work
I am unable to see at a glance how to correct this but it is between its menu, channel and volume buttons to alter the settings it may be worth to run through the re-tune sequence below?
To preset a channel or to change a preset channel, follow the procedure below.
1) Press the POWER button to turn on the TV.
2) Press the MENU button so that the menu display appears
on the TV screen.
3) Press the CH(annel) ? or ? button to point to "CHANNEL SET".
Then, press the VOL(ume) ? button.
4) Press the CH(annel) ? or ? button to point to "AUTO PRESET CH".
The tuner scans and memorizes all active channels in your area.
? The TV distinguishes between standard TV channels and cable channels.
? When AUTO PRESET CH action is completed, the lowest memorized channel reappears on the
screen.
? When you press the CH(annel) ? or ? button after selecting "AUTO PRESET CH", the tuner
will stop at the memorized channels only.
? The TV may recognize TV channels to be CATV channels by the receiving conditions. In this
case, try AUTO PRESET CH action again in the fine receiving conditions.
? When AUTO PRESET CH is activated where there is no TV signal input,"NO TV SIGNALS"
will appear on the display after the completion of channel scanning.
[ADD/DELETE FUNCTION]
1) Press the MENU button so that the menu display appears on the TV screen.
2) Press the CH(annel) ? or ? button to point to "CHANNEL SET".
3) Press the VOL(ume) ? button so that "ADD/DELETE" is selected.
4) Use the CH(annel) ? or ? button to select the
channel you wish to put into memory or to erase from memory.
Note: The menu will disappear in about 10 seconds.
Perform "ADD/DELETE" function while this display appears on the
screen.
? Press the VOL(ume) ? or ? button to light up the channel number
in LIGHT BLUE if you wish to add the channel into memory.
in LIGHT RED if you wish to erase the channel from memory.
5) Press the MENU button to exit the menu.
Hope this helps.
All display lights are illuminated but device doesnt work
Do you hear the speaker protection relay click after about 10 seconds when you turn the receiver on? Does the display show PROTECTION on the display? These conditions indicate a bad channel that will keep the receiver from functioning but you still have lights. Steve
Ticker along bottom of screen for news channels and sports channels is being cutoff along the bottom. That is, the ticker moves right to left and I can read it but the bottom 10-15% of the letters is...
I might need a little more detail to solve this problem - I suspect the problem is an incorrect setting on your cable/satellite receiver (assuming you are using one), but let's start with the TV.
Firstly, switch the TV on and select a channel where you can see the ticker. Then press the "FORMAT" button (above the red REC/CONNECT button) on your Mitsubishi remote control. This will change the screen aspect ratio and the current setting will be displayed on screen. Each time you press the FORMAT button the screen size should change.
The screen aspect ratio settings for your TV are STANDARD, EXPAND, ZOOM, STRETCHED and NARROW. Press the FORMAT button repeatedly until "STANDARD" is displayed on the screen. If the ticker is still cut off, you need to change the aspect ratio setting on your cable/satellite receiver.
Please note: If the TV will only allow you to select STANDARD, this is not a fault. It simply means that the aspect ratio cannot be changed on the TV because it's displaying a picture from an external source, i.e. a cable/satellite receiver.
You should then look for a button on the front of your cable/satellite receiver or the cable/satellite remote control marked "FORMAT" or "ZOOM". When you have located this button, try pressing it repeatedly until the ticker is both fully on the TV screen and the picture covers the entire screen.
If you don't have a FORMAT or ZOOM button for your cable/satellite receiver or you are unable to set the picture size correctly, leave the TV set to STANDARD and then reply to me with the brand and model number of your cable/satellite receiver. I will then be able to assist you with finding the correct picture settings and give instructions on how to set these correctly.
I hope this helps - please post back here if you need further assistance.
Regards,
BElectric
All the bbc channels are coming up with a message saying due to technical faults unable to show programme please try again later. this has been like this since tuesday
You need to do a channel scan. I think your area has 'gone digital'. Refer to your manual on how to do a channel scan, or post your make and model and we'll get back to you.
Zahc
12helpful
4answers
The box super usb 21st Aug 09
Below is a letter from a supplier of Starview which they have been sending out to their customers
Hi Folks - Hope All Is Well.
It Has Recently Come To Our Attention That A Few Of Our Customers Have Recently Been Experiencing What Seems To Be Power Supply Related Issues With The Starview 4 USB Receiver. This Infact Is Actually A Software Related Issue & Is NOT Due To A Premature Hardware Failure Or A Premature Power Supply Failure.
As A Precaution, We Are Requesting That All UK & EIRE Owners Of The Starview 4 USB Receiver Upgrade To the Latest Software Version With Immediate Effect To Prevent Any Issues.
This Is In Your Own Interest & Must Be Adhered To Ensure All Warranties Stay Valid.
The Software Must Be Copied To A Good Quality USB Memory Stick & Can Be Installed By Pressing A Few Buttons On The Remote Control.
Please Do Use A Good Quality USB Memory Stick, To Prevent Any Firmware Corruption On The Receiver. This Will Prevent The 8882 Error From Being Displayed On Receivers Front Display Panel.
Firstly Download The V1.12 Software From This Link:
V1.12 Software
Select The Blue Coloured "Download Now" Button
Unable to receive picture since change over
I'm sure that the converter instruction guide said to do this but determine whether both the converter and TV are set to the same frequency; the converter's output frequency and the TV's input should both be either channel 3 or 4.
With the converter's remote, press the 'Menu' button to make sure the converter has some kind of known output, then change the TV's channel to each of the two channels above.
5helpful
Nokia 5800 display screen has gone white
Your display circuit is broken, even if the LCD-panel,
seems to be ok the display is damaged.
This is a very common problem in Nokia phones.
The only way to fix this is to change the display.
You need a T-6 Torx Skrewdriver to do the job.
You can find displays for fair price at :
www.mytrendyphone.com
This is your solution! Please vote!
RXV 1500, I am unable to get 5.1 audio
Just got off the phone with Yamaha customer support, who were very helpful.  The display on the amp, in the lower right hand corner, displays the source input, not the output.  So, for example, you can be watching cable tv, and the cable tv is sending a 2-channel stereo signal to your receiver.  Your amp shows only L and R.  But since it has a processing system, depending on the processing program you have chosen it will probably distribute that sound to all five speakers.  You will be confused, because you hear sound from all speakers but you only see L and R lit up.  You will believe that you are not getting 5.1 sound.  And you will be correct: you aren't, because the source is not sending you a five-channel signal.  That's where I got panicked.  So the Yamaha representative said, insert a DVD that you absolutely know contains a Dolby Digital audio.  I inserted Shaolin Soccer DVD, went straight to a scene in the middle, and bingo!  The center and surround right and left speaker lights lit up!  So there is the 5.1 surround sound.  It will light up when it detects that kind of sound from the source.  Otherwise it will probably give you a sort of "fake" 5-channel sound that it creates from a 2-channel source.
Now the question becomes, are your connections getting the 5-channel sound to the amp correctly?  I just confirmed that my DVD, connected with a Coaxial cable to the Yamaha, does get 5.1 surround sound, if the sound is encoded in the DVD.  I have not tested this yet with video games or Blu-Rays; I will post again if and when I confirm that this works on a PS3.
Blank display on a Onkyo TX-SR501
try to connect the receiver to a tv via the monitor out from the receiver to the tv. you may be able to see the OSD (on screen display of your settings) change the function on that to turn on the front display. alternatively look on your remote to see if you can turn up the light of the front display.
if these don't work possible that the light of the display has blown.
good luck
smeags.
Top Sherwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Ngoro
Arnie Burke
Arnie Burke
Are you a Sherwood Audio Player and Recorder Expert? Answer questions, earn points and help others
