Question about Samsung HP-R5072 50 in. Plasma HDTV
WHAT CAN I DO TO RESOLVE THIS MATTER--PLEASE HELP ME SOMEONE???
HAVE TO BLACK LINES IN SCREEN. ONE MAY AN INCH WIDE ON LEFT SIDE AND MAYBE HALF AN INCH RIGHT SIDE
  • binot9192 Jan 29, 2008
    model code HPS5053X/XAA VERSION SD01
    Sergeant:
  • 261 Answers
Are you using a cable box? If you are then it maybe setup incorrectly. If not, See if when you press the MENU button if the screen is filled. If it is ok then, then the plasma panel is good, but the video processing is possibly bad. Have you tried all video inputs? Let me know more info and i can assist more. Have a good one. Jay
Posted on Jan 31, 2008
Samsung tv size 42 inch
your tv may need to have the service team reset the system. those lines represent system program protocol from the factory. nothing can be done unless you take to where you buy
May 29, 2013 | Televison & Video
Got white vertical lines on left side of display
Vertical lines on an LCD screen are not a good sign. This usually means that your screen is going bad.
Jul 21, 2010 | Toshiba Computers & Internet
Two inch wide vertical band spreads across half of screen
this is a problem is your scan section either letf or right scan boards are bad. if its under warranty take it back if not it needs to be serviced. you can probably do it yourself.
Jul 01, 2009 | Televison & Video
3-INCH WIDE VERTICAL LINES RUND DOWN LEFT SIDE OF FAX MACHINE
Do your incoming faxes have the same marks?
If not you might find that the scanning part of your machine has a dirty mark on the glass or that the unit has become faulty.
Try and take a copy from the machine and print from a report or any print from memory.
If you have the black lines on both then i'd suggest getting a new drum unit, if u have it only on the copy I would have a look at your scanner glass and see if there is a dirty mark on it. if not maybe call out an engineer as the scanner unit maybe faulty.
Need anymore help msg me.
Dec 11, 2008 | Office Equipment & Supplies
Black Lines
My Hitachi TV Flat screen 42 EDT 4 1A has a one inch black line from the top to the bottom of the
screen on the left side. What or how do I fix it. I did blow it out with a air compressor as suggested by a local repairman.
Nov 09, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Black Vertical Lines in screen
All I can tell you is that you maybe have left your T.V. on a channel that didn't move for so long, or maybe someone else did and it burnt the screen. Plasma's run off of plasma gas to create the great picture and they collect on the screen and stick. What you need to do is go to your menu and look for "screen burn protection" and put it on white and let it sit for 20 minutes. All of one color such as white doesn't harm your T.V. The only way anything burns is like a bright white line in front of a black background.
Oct 26, 2008 | Samsung SP-R4232 42 in. Plasma HDTV
4 by 3 lines
noticed lines after watching 4by3 aspct ratio all day ,and then i switched to a hi def wide screen i could see lines on ether side of screen where the 4by3 asect ratio would end ,would not go away no matter how long i left the projejtor on displaying hd wide screen pcture ,this is an easy fix ,i just powered off projector and unpluged from outlet for 24 hour,s ,them pluged back in and powered on the projector and the lines are gone ,hope this helps someone out with the same problem ...
Sep 14, 2008 | Sanyo Televison & Video
LCD monitor problem
what is the solution for this? my husband just turned his pc on when we got home and there are line blue lines running up n down in the black
Oct 11, 2007 | Computers & Internet
Samsung HP-R5072 50 in. Plasma HDTV Logo
88 people viewed this question
Jerry Greenberg
Jerry Greenberg
