Question about Sony Handycam DCR-DVD108 DVD Camcorder
Sony camcorder dvd 108
My new camcorder , when i tried to load the software and it ask for me to plug in the camcorder usb then it would go no further, sony says its probably camcorder software not communicating and want 130 to fix it, its brand new but out of the 90day; freebees help
  • frenchfry05 Jan 30, 2008
    i did what u said but the same thing happened, it found the hardware and said install software and then wizard said it cant find necessary software.
    when i click finish, it says make sure camera is the one that came with this installer cd. I kept thinking that is was the wrong cd but sony says no
    President:
  • 4,402 Answers
Go to my computer > click on hardware tab >
click on device manager button > in the is next screen on the bottom should have>>universal serial bus controllers
(write these down just in case it cant find them)
right click on them and uninstall
reboot let windows reinstall them
Also told Microsoft hotfix causes this problem try uninstalling the last hotfix
Posted on Jan 29, 2008
Sorry to say that i couldnot get my answer.oncemore my question is i have a sony handy cam HDR-CX230.it can be recharge via USB port and photo can be transfered.previously i charged my handycam in my...
First off I would buy a converter that allows you to plug your usb cord into it and then it plugs into an AC outlet. It will charge faster. Second, it sounds like when you PC is trying to recognize the hardware you have plugged into the usb port it isn't finding any software associated with the device and is for some reason restarting. If you received a software disc with your camcorder, try loading it on this PC and see if that fixes the problem.
Jan 21, 2014 | Sony 8GB HDR-CX230 HD Handycam Camcorder...
I have a sony handy cam DCR - DVD105, I want to know all the ways of being able to connect it to a laptop and extract the files to use in other softwares, like Window's Movie Maker, or Power Direct 09.
How to load Mini DVD to Mac
  • Though Mini DVD can not be played back in Mac slot loading player, we have other ways to load Mini DVD to Mac.
  • Method 1 If Mini DVD camcorder has FireWire or USB; just connect the Mini DVD camcorder to Mac using FireWire, or USB to load Mini DVD to Mac.
  • Method 2 If Mini DVD camcorder has not FireWire or USB; just shop for external mini-DVD drive that uses either a USB or Firewire connector cable, and then connect the external mini-DVD drive to your Mac and install any extra software that came with it. Insert the mini-DVD into the external drive, and then access the files on the mini-DVD as you normally would to load Mini DVD to Mac.
  • Method 3 If Mini DVD camcorder has not FireWire or USB; buy an adapter that converts a mini-DVD to a normal DVD by adding on a circular plastic piece that emulates the full size of a regular DVD. Attach the adapter to the mini-DVD and load it into the Mac's DVD drive to access the files. (Check the specifications of the adapter before purchasing, as several on the market do not work in vertical-loading drives like those found on the MacBook Pro.)
  • Method 4 If Mini DVD camcorder has not FireWire or USB and you don't want to buy a separate external drive or full-size adapter either, but you do have access to a PC, you can transfer the files on the mini-DVD onto the PC, then put them onto a USB flash drive, which will work on your Mac.
more detailed at http://www.bigasoft.com/articles/easy-solution-to-import-midi-dvd-into-imovie.html
Apr 21, 2011 | Sony Handycam DCR-DVD105 DVD Camcorder
Can not get video files from a mini dis dcr dvd 108 handycam when I try to import to my pc it says does not support this dis i was using usb cable to pc with sony's software thanks jim
First make sure to finalize recorded disc in camcorder, finalization option is available in camcorder menu and will be enable by powering camcorder with AC charger/ adapter.
Now you can transfer movie files in computer or put recorded disc in computer dvd rom and copy files.
Jul 31, 2010 | Sony Handycam DCR-DVD108 DVD Camcorder
Cant connect my sony camcorder to comp via usb
do you still have the software that came with your camcorder? if not you just need to finalize the disc and connect via usb and use a dvd ripping software. if yes then you still need to finalize disc and use the software to transfer videos to pc.
Mar 31, 2009 | Sony Handycam DCR-DVD108 DVD Camcorder
Need to have software or whatever to play ccd trv 108 handycam
Hi, You could view the video on the PC using the windows movie maker and a USB/ firewire cable connected to the camcorder.
Feb 24, 2009 | Sony Handycam CCD-TRV108 Camcorder
How do I upload video clips from my Sony DCR-DVD 108
I understand that you tube uses a different format to the camcorder.
What I do is copy the clip to memory card then plug memory card into a USB card reader & copy movie / photos to your hard disk drive.
then upload them to you tube later.
any problems just email me rward88@hotmail.com
Jan 20, 2009 | Sony Handycam DCR-PC9E Mini DV Digital...
Finalize DVD
Some Camcorders need you to plug the charger to enable you to finalize it. This is to avoid your disc or data be destroyed or corrupted should your camcorder ran out of battery.
Mar 17, 2008 | Sony Handycam DCR-DVD108 DVD Camcorder
Sony DCR-DVD 108 disc won't play or record
Movies shot DV Camcorder forms mpg files when down loaded in computor and can not be converted to a CD. Problmes comes in conversion of mpg files to AVI, WMV, AVSEQ or MPEG2 etc.
Oct 29, 2007 | Sony Handycam DCR-DVD108 DVD Camcorder
How do I find my camcorder on my computer?
That's when I try it with a FIREWIRE connection.
Sep 14, 2005 | Sony Handycam DCR-TRV330 Digital Camcorder
Sony Handycam  DCR-DVD108 DVD Camcorder Logo
42 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
