Question about Sony Handycam CCD-TRV308 Camcorder
CCD-TRV308 Recording issuses
My CCD-TRV308 camcorder won't record. When you try to record and then play it back you will have sound but no picture. It will play old videos I have recorded a while ago. Just not recent videos I have tryed to record, The screen just displays a snowy screen through the entire recording process. When played pack it's just a solid black screen.
    President:
  • 4,402 Answers
When was the last time you "cleaned" the heads? Use a good commercial head cleaning tape. They have both "Wet" and "Dry" types. I prefer the "wet" over the dry. I think it does a better job but they are hard to find sometimes.
you can also do it manually with "foam" swabs and "methanolCCD-TRV308 Recording issuses - 1.gif". Alcohol works but the methanol leaves less residue behind.
If that doesn't solve the problem the next step would be to take it to a repair shop for cleaning and re-alignment.
Posted on Jan 29, 2008
Sony handy cam Hi 8 ccd trv308
Sony has a recall on some of these ccd imager problems. Contact Sony to see if your model applies, but it sounds like an imager problem on your pal format camcorder. Larry
Apr 19, 2010 | Sony Handycam DCR-SR220E HDD Camcorder
When playback of tape, fuzzy, not clear picture, or blue screen with sounds
try rewinding the tape and play it from the beginning.if still the same,video heads may be dirty and needs to be clean.i recommend you use a dry head cleaning tape.after which reinsert tape and play it again.if issue persists use a diff tape with previous recordings.if still no go,use new tape and try recording on it,play it back and check.if still the same your unit will require service.thanks:) hope this help.
Mar 12, 2010 | Sony Handycam CCD-TRV308 Camcorder
No picture when recording have sound just lines going through len
Seems ccd imager is bad in your Sony camcorder that you get noisy picture in recording. Let me know exact model number of camcorder to provide you more info.
Jun 05, 2009 | Sony Handycam DCR-TRV255 Digital Camcorder
Sony 8mm camcorder will record sound but no video
Since it is playing the tape, the play head is ok. Now recording is done by recording heads so you may have a clogged heads or damaged recording heads. Try to clean the heads with head cleaning tape to see if it would help. 1. remove the tape and leave the door open. 2. using a canned air, blow out any dusts in the tape area. 3. run head cleaning tape for about 10 seconds and no more. 4. try the recording.. If this does not resolve, you may have a damaged or heavy clogged video heads. Take it to nearest video technician for a diagnostic. -James
Mar 28, 2009 | Sony Handycam CCD-TR517 Camcorder
When camcorder is turned on the screen shows red or yellow screen
I have the same problem of picture distortion when recording on my PV-GS200 camcorder. It's due to a faulty CCD block, which you can read about on various websites. I can play back pre-CCD failure tapes without a problem. Panasonic recalled quite a few GS200 camcorders with specific serial numbers in the US and Canada, and replaced the faulty 3-CCD chip free of charge. I just discovered this tonight and intend to ring Panasonic tomorrow, as the camcorder - bought new - lasted only two years before the CCD fault became apparent. Obviously, the camcorder was not of merchantable quality.
Jan 27, 2009 | Panasonic Palmcorder PV-GS200 Mini DV...
SONY CAMCORDER CCD TRV 328 rec,problem
Your camera ccd-TRV328 has defect with ccd imager that's why not giving picture in camera / recording mode. This part (ccd imager) needs to be replaced and good news Sony will replace it free of cost.
Please click Sony Official Website for details.
Regards,
Sep 02, 2008 | Sony Handycam CCD-TRV328 Camcorder
Recording from camera to VCR
1st setup ur VCD with TV and playback it to view on TV. If picture is coming, thats OK.
2nd plug ur camcorder in VCR input and select VCR input according to plug in and monitor the camcorder picture on TV through VCR. If its ok, now u r ready to record the picture from camcorder to VCR.
Jun 07, 2008 | Sony Handycam CCD-TRV308 Camcorder
Light
auto light try to turn off once ok light settings
Feb 03, 2008 | Sony Handycam CCD-TRV308 Camcorder
Sony Handycam CCD-TRV308 Camcorder Logo
142 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
