Question about HP PSC 1210v All-In-One InkJet Printer
Error in writing to LPT1 or printer not ready
My printer is on and im not sure what the error is. I have shutdown the computer and unplugged usb cord and started over. I still displays this message.
  • 1210V Jan 30, 2008
    yes, still have the problem
  • Anonymous Feb 21, 2008
    error writing to lpt1
  • 3 Answers
The printer is writing to an LPT port when you probably have it installed USB. Go into your control panel, then "printers" and then you will have a list of installed printers. Right click on the one with the checkmark if it's your printer (not like the XPS Doc Writer) and go to the PORTS tab. If your printer is supposed to be USB, get the "Virtual Port for USB" selected and make sure all the documents are deleted from the queue and have at it"
Posted on Mar 19, 2008
What does Communication Error mean?
I am guessing that you are using Windows 7. If so go to Control panel 'Hardware and Sound' Printers and select Remove a Printer. You may then unplug the printer usb connection and restart your computer. When the computer has restarted , you may go to the link below to download the most current drivers and install them .
Do not plug in the usb connection until you are told to do so. Also, the printer may select a default connection to LPT1 , which is a parallel port connection (apparently this printer likes to do so , and this will give you your "communication error" ). If it does, go to printers in control panel (see above) , right click on the icon for your printer , select "properties" , and left click on the " ports " tab. Make sure that the port selected is USB001 or similar and NOT LPT1.
Epson Stylus Photo R280 Ink Jet Printer
Aug 16, 2014 | Epson Stylus Photo R280 Series
Service error 9000
Error 9000 is a USB overcurrent error. Unplug the power cord, unplug the USB cable, and plug in the power cord. Leave the USB cable unplugged. Turn on the printer. If it still has the error, it needs a new logic board. Price of board exceeds cost of new machine.
If the unit comes ready, replace your USB cable.
Sep 20, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Mfc7340 will not print--it was working just fine and then it errors out. Uninstalled and reinstalled and it shows ready but errors out
Hello ,
First, please make sure there is no error message displayed on the LCD screen of the printer
Now we will check the status of your printer in the printers menu in the control panel.
The printer’s status should be set to “ready”
If the printer is “paused” simply clear the print queue, right click on the printer and select “resume printing”.
If the printer says “offline”, follow these steps.
  1. Clear the printer queue
  2. Shut down the computer
  3. Unplug the USB cable from your computer and your printer
  4. Unplug the power cable from the printer and wait 15 seconds
  5. Plug the USB cable back into the printer and the computer.
  6. Plug the printer’s power cable back in.
  7. Turn your computer back on.
Your printer status should be back to ready now and you are able to print.
Thank you,
Mar 26, 2010 | Brother Office Equipment & Supplies
Lost communication with computer, neither USB or LPT1 works. Printer stopped mid-job after working well for 3 years
please check the printer statues ..after switch on the printer its comes to the ready condition ( ready is on ) .. second thing please check the printer driver in control panel ( printer and faxes ) it should be ready .... one connect the printer to the pc and check it detecting or what if its detecting please reinstall the printer driver and check .......... if its not detecting its may have problem with the printer connector or main board ............. please reinstall the printer driver and try ....... if the printer is working means it will help you .....if you are getting any error while giving please post the error .......
Jan 04, 2010 | HP DeskJet 1220c InkJet Printer
Green light blinking, won't turn off and can't print anything
unplug your usb or any cord that links to your printer...
then press and hold the power button of your printer (it should force your printer to shutdown)
then plug-in your usb cord (connector/cable) back to your computer then turn in you printer again... wait for your computer to recognize it
(note the green light blinking is an indication that the printer is busy) therefore you should wait for it to be recognize (note: a sound maybe heard once your computer recognize it, some may appear as pop-up)
it should be ok now make sure you still have ink in your cartridge
Jul 07, 2009 | Lexmark X2470 All-In-One InkJet Printer
Light is blinking, doesnt print, it prints before but now it doesnt. appears online and ready on the computer.
If the port had been changed to LPT1 the printer will not work.
LPT1 is the large parallel port, while you are using USB on this printer.
the red light came on probably because of a jam , or because of one of the documents in the printer cue.
The easiest thing to do is
Unplug printer usb.
Go to control panel>installed printer.
Delete all the instances of this printer from there and chose to delete drivers if asked.
Reistall the printer using the printer disk, plug in printer data cable only when asked by setup wizard.
If you have a different USB cable, also use it, just in case.
If that does not fix the problem , then there is an internal fault in the printer.
Regards.
Jun 01, 2009 | HP DeskJet D1460 InkJet Printer
I have been unable to print to my lexmark z11 color jetprinter. pages come out blank. I received an error messarge saying : there was an error writing to LPT1 A printer timeoout error occurred. To...
This sounds like more of a communications problem than it does a "time out" problem. I am assuming that the printer is connected to the computer via a parallel cable. If that is the case, try unplugging the cable at both ends, the reattaching it. If that does not change anything, try replacing the cable.
If that does not solve the problem, try replacing the parallel cable with a USB cable and then follow the directions below.
If by some outside chance you have the printer connected to the computer via USB cable you can do one of two things. Replace the USB cable with a parallel cable or change the printer's port settings to use the USB cable. - If you do have the printer connected via USB cable you might be able to rerun the installation software that came with the printer and it may automatically pick up on the USB set up. If not, go to Contro Panel\Printers and Faxes\ - Right click on your printer and open properties. Under properties, click on the Ports tab. Since the error message stated "error writing to LPT1, check to insure that the LPT1 block is checked. If it is, and you are using a USB cable, scroll down until you see two blocks - "USB001 Virtual printer port for USB" and "DOT4_001". Check the box beside "DOT4_001" then click on Apply and close the window. The try printing again.
Hope that helps - Graye
Nov 24, 2008 | Lexmark Office Equipment & Supplies
Connect 5250 DN by LPT1 and USB?
Sure you can.
But you have to share your new USB printer on the network if you want to use this print (usb) from the computer that has LPT1 printer connected on it.
Oct 22, 2008 | Brother HL 5250DN Laser Printer
Error problem
I found this problem raised because of improper installation of drivers. I have down loaded the drivers from HP site and got it rectified.
Aug 29, 2008 | HP DeskJet 3745 Printer
Hi my printer is online and ready to use, but every time i try to print it comes up with an error message saying it cannot communicate with the printer....i have unplugged the usb and turned the computer...
Try another USB port. It may need a USB 2.0 instead of a USB 1.1 port. Most machines have both but they are not marked. Make sure that you
- unplug the USB to the computer
- turn off the computer
- turn the computer back on
- THEN insert the USB from the printer into the computer and wait about 15 seconds.
- you should see "found hardware xxxx" and "installing device driver"
If not then you have another problem because the drivers are not installing correctly.
Jun 20, 2008 | Lexmark Office Equipment & Supplies
HP PSC 1210v All-In-One InkJet Printer Logo
342 people viewed this question
Seeker5211
Seeker5211
