Question about Panasonic DMR-ES10 DVD Recorder
U61 on panasonic dmr es15
I'm getting U61 errors. I read to open the cover, unscrew the 3 screws holding the dvd player in place and push the head back. I've unscrewed the 3 screws do i try to remove it from the metal casing too?
  • 6 more comments
  • jlmundy Jan 29, 2008
    ok .i figured out to remove the metal casing. I slid the head back towards the back of the unit, put everything back together again and power it on, still get the u61 error. Of course, it's 13 mos old, so out of warranty and only happened when i used a new memorex +R dvd to record. WIll cost me $130 to send back to panasonic. Any advise? Thank you
  • Anonymous Feb 11, 2008
    Same exact problem!!!! Out of warranty also
  • fred1homenow Feb 17, 2008
    U61 code came on after I turned the power on, It then wanted to open the DVD drive. the drive did not open all the way, so i pushed it back in myself and I have this U 61 code not but I did have a U66 at first too.
    The unit is not operative at all.
    Fred
  • Anonymous Feb 17, 2008
    I have a DMR-ES25S. It displayed the U61 error while recording. I bought it in Dec 2007 recording less than 30 times. With eye protection goggle, I opened the DVD drive, powered up the unit. The lens moved in and out searching for disc or tried to read a disc then displayed U61 and ejected the DVD tray. I suspected that the lens or the reading head is defected.
  • Rachel1980 Apr 18, 2008
    I have been having the SAME error (U61) message on TWO Panasonic DVD Recorders (one is a VCR combo). I love them as far as ease of use, but they are junk!
    Please let me know if you figure out how to fix this error - every time I put a DVD in, it makes loud noises like it's eating it and working hard...Also, mine won't work with Memorex DVD either (it used to, but not any more). I have to use Maxell DVD-R (had trouble with the +Rs, too). Ridiculous.
    [email protected]
  • Laughinstaff Apr 22, 2008
    I'm getting the same U61 error on my Panasonic DVD recorder. Surfing the net it seems that just everybody else is too - always just after the warranty runs out. Total junk - I will never buy another Panosonic product again!
  • Anonymous May 29, 2008
    I recorded 3 programs successfully and went to pull down a 4th when it said that there is a problem with the disk and I should replace it. When I try it ultimately gave me the U61 error code. This happened twice.
  • Anonymous Mar 26, 2009
    I have the same problems 2 years old , just thro it away ...not worth to repair .
For U61 errors:
Turn unit off
flip down front a/v input panel
simultaneously press the channel up and stop buttons for at least 10 seconds.
Posted on Jun 03, 2008
I have seen several postings regarding errors for the DMR ES15 recorder. I have resolved errors on my 15 month old device by cleaning the black spool that retains and spins the disc. Using denatured alcohol on a lint free cloth, I carefully cleaned the hub but did not saturate the material. This immediately cleared the no read and unable to record errors. Of course, I had to remove the outside covers to access the inter-workings of the read-writer.
Posted on Aug 10, 2008
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 62 Answers
This error U61 indicates the unit is carrying its recovery process, which restores the unit to normal operation. It does not mean the unit is broken. Solution is to wait until the message disappears.
Posted on Mar 05, 2009
I opened the case, and then the DVD case and cleaned the rubber seat for the DVD with alcohol and quickly dried it with another Q tip. I then pushed the head to the back; as far as possible from the middle. I cleaned off some of the hardened grease from the guides on which the laser head travels. Then put it back together and it still gave the U61. I turned it off and then back on while holding the up channel and the down channel buttons in. It still didn't work. I opened the case and removed each of the ribbon connections and put them back in twice. Then I closed it up and held down the up and down channel buttons when it started. It worked. I could change to VHS and back to DVD. It plays and records. It must be that the lead solder on the ribbon plug-in connections gets oxidized and need to be cleaned. Just pulling them out and pushing them back in does it.
Posted on Jul 06, 2012
Same here U61 , and 4weeks out of warranty, another one for the dump.
Paddy
Posted on May 27, 2008
6ya staff
SOURCE:
How do I remove the cover of a delonghi ec270
Prise the back cover off with a flat head screw driver. Sides first, then ease top and bottom off. Remove two push in caps by gently squeezing out with a plier, align the groove to the same direction as plier. Locate two screws holding cover, unscrew, and off it comes.
Aug 25, 2012 | DeLonghi EC270 Espresso Espresso Machine
My dvdv 6600 dvd player cannot played anymore
If Your player used to play disc before but all of a sudden stopped playing disc, yet it powers on and try to read a disc and come up with a 'no disc' error message or loads and does not come up with any message, then it means there is a problem with the laser/lens of the player. If it does not power on at all, then it means the problem is from the power board which is inside the player.
For the no disc error message, the solution is for You to clean or replace the lens of the player.
To clean the lens, Please get a laser/lens cleaner disc and insert it into the player, that will clean it for You, but if You want to clean it manually, please follow the steps below: You will be needing a cotton bud,a cup, a screwdriver, and a glove.
  1. Turn off the player,
  2. Unplug it from the power source and wear Your glove,
  3. Unscrew the player and keep the screws in the cup in order for it not to be missing,
  4. Then You slide the cover open,
  5. Unscrew the plastic cover that holds the disc in place for the lens/laser to read it,
  6. You will have direct access to the laser/lens,
  7. Use the cotton bud to carefully clean the laser/lens which is the crystal like object held in some casing,
  8. Screw back the disc support plastic that holds the disc,
  9. Then You test it with a DVD before screwing it back together.
If that does not solve the problem, then it means You have to replace the lens, to do that, please follow the steps above to step 6, then follow the rest of the instruction below:
  1. Disconnect the flexi ribbon that connects the lens to the main board,
  2. Carefully remove the laser from where it is connected to,
  3. Replace it with a new one,
  4. Reverse the process to reassemble the player back together,
  5. Then You plug it to a power supply and test it with a disc.
Hope this helped. Thank You for using FixYa!!!
Jan 28, 2011 | Samsung DVDV 6600 DVD Player / VCR Combo
Dvd stuck in player when it ejects th edvd is not in the slot. how can I open the computer to get the dvd out
unscrew the screws at the cover of the cpu...locate where the dvd-rom is placed and unscrew it...open the dvd by uncscrewing its screw and there you go
Dec 05, 2009 | Averatec D1002UHCE-1 All-In-One Intel...
U61 Code will not reset - any suggestions?
You have the same issue as the one who is posted here at Fixya. But this requires you to open the DVD cover. If the unit is still under warranty, its best to bring it to the authorized service center. If not, you can try and test this if it'll work.
http://www.fixya.com/support/t221217-u61_error_code
"I have the same problem (same error # same model of DVR).
I noticed it happened after I left a DVD in play mode and paused for a long time.
I saw a message on the Internet that error U61 can mean that the lens is unable to move (return to its normal position).
The Internet message said that person unpluged everything, then opened the cover to the DMR-ES15 (3 screws) and gently pushed the DVD head back towards the rear of the DMR-ES15.
I assume that would void his warranty, but I am considering trying it since the time to have it repaired versus the replacement cost makes the possibility of a "self-repair" attractive.
Here is part of that actual Internet message. I hope it helps you:
Yesterday, my DMR-ES15 started to malfunction, giving me the error U61.
No matter how many times I tried to press Enter, and Power On, the machine
kept re-booting with the error U61. I noticed that the drive was making some noises as if the Read head was not able to park properly.
So I decided to open up the unit and find out why.
I took out the 3 screws holding the top in place. And then moved
the drive head mechanism back (pushed it towards the back of the unit).
I then plugged the power in, turned it on, and amazingly there was no more U61 error.
I test the unit this morning again and everything seems to work properly again!"
Aug 17, 2009 | Panasonic DMRES15 DVD Recorder
Two dvd's stuck in player thanks to a busy toddler
I had the same problem... my DVD took one in even though it already had one in there... Tweezers did not work until we used a pie server covered in masking tape with the DVD attempting to eject and then grabbed one DVD out. The DVD player works too!
Nov 11, 2008 | Rosen CV7080D Portable DVD Player
ES15 - U61 - what am i supposed to push back?
Yes, there are four screws holding the drive top in place. When you remove these and the top you will see the drive head which can be pushed towards the back of the unit. I tried this but it still didn't resolve the U61 problem, I'm amazed that a company like Panasonic allows such a glitch to occur to so many customers.
Nov 27, 2007 | Panasonic DMR-ES10 DVD Recorder
U61 error code
UMM the DVD top lid uses FOUR screws. The entire DVD drive is bolted to the chassis with 3 screws.
Oct 14, 2007 | Televison & Video
Model No'DMR-ES15 - U61problem
I get this message occasionally on my Panasonic DMR-ES15. It's actually a really simple fix. It occurs when there is a corruption in the disc which causes the recording mechanism to malfunction. There is a separate error message for this, however it is usually not detected until it's too late. When the recorder asks you to carry out the recovery process, do it. When the disc ejects, make sure you take the disc out that was in there when it occured and throw it away...it will keep happening because the disc is permanently corrupted. However, do not close the tray without a disc or the self-check will fail. Instead pop in a disc of the same format that the error occured in (if it was DVD+RW then put in a DVD+RW). It resolves the problem every time on the first try. (It only happened two times in a year and a half for me). As the manual says the unit is "NOT BROKEN".
May 23, 2007 | Panasonic DMR-ES10 DVD Recorder
Panasonic DMR-ES10 DVD Recorder Logo
5,449 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
