Question about Sony KP-46WT500 46" Rear Projection HDTV-Ready Television
Bright green flash and red arching lines
1. While watching tv the screen will flash very bright green, then go off. The standby light flashes 8 times . turn unit off, then back on and it seems to work for a while, this issue is pretty intermitent.
2. There a red bow shaped lines on the top and bottom of the screen that are particualy noticalbe durring dark scenes but even more obvious when swithing from one source to another.
Not sure if the above are related or seperate issues.
If someone could point me in the right direction it would be most apprectiated and if someone could send me the repair manual for the Sony KP46wt500. 9pluck9@gmail.com
Thank you
Keith
  • 9pluck9 Jan 31, 2008
    avsforums answerd my question
    Thank you puggy666 I will take a look
    Did not realize bulbs only lasted 4000 or so hours.
  • 48 Answers
You need to check the bulb in the back of the set as it could be on the way out . just check to see if the bar in the bulb has gone black as it is a good sign the bulb is on it's way out . the bulbs only last 2-3 years or 4000 hours . If thats ok you most probaly have dry joints on the tuner , they just need resoldering
Posted on Jan 31, 2008
My sony kp-51ws510 color rear video projector tv when i turn it on it stays on for abt five seconds and then turns off and also the timer and standby light is flashing red
this model did have problems with bad picture tubes---screen goes bright red,green,blue and set shuts down.
set also does this to protect itself---when fails look to see if specific sequence of blinks
Apr 17, 2012 | Televison & Video
TV quits working, screen goes black and red light next to power green light flashes 4 quick flashes . After a second or two of no flashing,red light repeats "code" flash. We pull the power plug at the TV,...
The Sony diagnostic routine for 4 blinks indicates it to be a vertical deflection problem.
Did you see a solid horizontal line in the center of the screen prior to it going out? If so, that is a tell tale sign for vertical problems.
basic sony reset below
The STANDBY light will flash if the television detects an issue within the television. Some of these issues can be resolved simply by following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center
Nov 27, 2007 | Televison & Video
How do fix my 5 inch sony the light flashes 8 times
Prior to this were you getting a bright red, green, or blue screen with trace lines?
Apr 03, 2012 | Sony KP-57WS500 57" Rear Projection...
Turn tv on,picture good for 4 seconds,then green curved line like a rainbow all green,then 4 green sequence flashes,picture goes out theN volume continues for 2 seconds then out front red power light then...
This is a set with bad picture tubes-not available except on rebuild basis.
Are you seeing bright green screen and then set shuts off?
Let me know so I can help--8 blinks is AKB error.
SD TECH
Sep 15, 2010 | Sony KP-51HW40 51" Rear Projection...
I try to turn it on but it just blinks on stand by
Probable Lamp. If lamp hasn't bown the red Lamp Lite won't flash but other lamp issues cause stby timer light to continue flashing. If stby red lite is flashing, count the no. of times flashing - could open thermal fuse (6X flashing)
Nov 27, 2009 | Sony KDF-E42A10 42 in. LCD Television
I want to find the Sky remote code for this Tv.
Just got an LG 42LH2000 and code 0206 works
May 16, 2009 | LG Televison & Video
Turn on pic turns red with thin bright red horizontal lines
Sorry to say, but that's usually the sign of a bad picture tube. One of the elements inside the tube shorts and you see the picture you describe, and the set shuts down due to high voltages getting to places it shouldn't. There's no solution except picture tube replacement, and that is uneconomical. You're better off replacing the TV when the tube goes bad.
Mar 31, 2009 | Toshiba Televison & Video
Sony 2002, kpws500
Minium is the green picture tube need to be replaced, if you can take the front cover and access panel off there is a control with 3 focus and screen controls.
you can adjust the 3 screen controls to possibly get a little more time out of it before the crt's need to be replaced. careful if you turn them down too much there will be no picture, and if you turn them too high the tv will go bright and shut off
Apr 13, 2008 | Sony KP-57WS500 57" Rear Projection...
Sony KP-57HW40 Error Codes 6 & 8
ITS PROBABLY THE RED PICTURE TUB (CRT). IT LOOKS EASY TO INSTALL, BUT YOU NEED TO MAKE ADJUSTMENTS TO THE SCREEN ONCE IT IS INSTALLED. THE PART IS $3OO. TRY TO FIND SOMEONE TO INSTALL IT FOR $150 OR LESS. HERE IS A WEBSITE TO HELP YOU MAKE ADJUSTMENT IN THE FUTURE ON YOU OWN.
PRIDAH
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Nov 10, 2007 | Sony KP-57WS500 57" Rear Projection...
Sony KP-46WT500 46" Rear Projection HDTV-Ready Television Logo
98 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
