Question about Microsoft Windows Vista Home Premium with Service Pack 1: Windows
I have a medion driver disc for windows 7 upgrade kit. When i try to install it no instructions appear just 7 programs : Chipset, Raid, TV Tuner, WLan, Lan, Sound & VGA how do I install windows 7 ?
    New Friend:
    Problem Solver:
  • 5 Answers
Guys who need windows key can go link http://cheapwin7activationkey.tumblr.com to got. my key got here and after i used is great works.
Posted on Nov 14, 2016
    New Friend:
I have a medion scaner an I realy need a update for Win 7 64BIT, can you help me wit this CD ? actualy with the soft from it. samm_rs@yahoo.com Tx.
Posted on Feb 10, 2014
    Problem Solver:
  • 13 Answers
Did this come with your computer or did you purchase it from somewhere? This doesn't install Win 7, just the drivers after the upgrade. If you purchased this cd, the drivers are only good for a Medion computer.
Posted on Dec 31, 2009
I upgraded matheboard from p6t6 (stopped working for some reazon) to p6t7. My hard drives have been set up to raid. I have windows 7 ultimate installed. I set bios to raid and choose proper disc as boot 1...
On many systems with RAID1 support built into the mobo chipset, that system includes some RAID management software in BIOS. You won't see it until you turn on RAID capabilities in the BIOS and add a drive. But you might find all the details you need in manuals on the matter from Dell, so look for those. They could have come with your machine, or you may have to search their website and download.
On systems I've seen you create and manage RAID arrays using that built-in software, NOT Windows tools. In fact, some RAID1 management tools would allow you to convert a single stand-along HDD to a RAID1 array by adding a matching HDD unit and then having the system copy all the data to the second drive. This is almost the same as the process to repair a damaged RAID1 array by replacing one faulty drive with a new one and rebuilding the array.
HOWEVER, Windows ALWAYS needs a RAID driver installed in it to use any RAID array. If you are simply booting from a "normal" stand-alone disk into Windows and then using a RAID array as a data storage system, the RAID driver installation can be done any time after Windows is running as you set up the new storage system. BUT Windows in ANY version cannot BOOT from a RAID array unless the RAID driver has been installed at the very beginning of the OS installation. This implies that, if you want to convert your single disk into a RAID1 2-disk array and use ONLY that as the HDD resource in the machine, you will need to re-install Windows, this time including the required RAID driver install at the beginning, in order to boot from that array.
I have read that there may be ways to convert a non-bootable RAID array into bootable by some complicated editing of Windows registry and boot files in order to force it to load the right driver at the right time from the right spot on a HDD, etc. But I am not SURE that would work. It's definitely for the adventurous knowledgeable techie.
So here's a quick guide to installing hardware RAID on a motherboard that features a RAID controller. These steps assume you are performing a clean Windows 7 install rather than an upgrade, and they might differ depending on your system set-up, but the general principles should be the same.
  1. Download the RAID drivers for your motherboard from the manufacturer's website and save them to a memory stick.
  2. Back up all your important data!
  3. Turn your PC off and unplug it.
  4. Install 2 hard disks preferably with identically capacity into your PC.
  5. Turn on your PC, press the delete key or F2 key when prompted to get to the BIOS menu.
  6. Find the option to select the RAID mode, save your settings and exit BIOS.image.axd?picture=bios-raid-options.jpg
  7. On reboot you should see a new menu option to enter the RAID controller settings. Enter the key combination when prompted to get to the RAID controller menu. image.axd?picture=amd-raid-menu.jpg
  8. Create a new RAID array selecting either RAID 0, or RAID 1.
  9. Select the disks that will form the array, save the settings and exit.
  10. On reboot press the delete key or F2 key when prompted to get to the BIOS menu.
  11. Check the boot sequence of your PC and ensure your optical drive is top of the list.image.axd?picture=bios-boot-sequence-options.jpg
  12. Insert your Windows 7 disk into the optical drive and exit the BIOS.
  13. On reboot press any key when prompted to boot from the optical drive.
  14. Windows 7 should start installing.
  15. Select your localisation settings and click next.image.axd?picture=localisation.jpg
  16. Click "repair your computer" and click the "load drivers" button.image.axd?picture=windows%207%20repair%20menu.png image.axd?picture=load-drivers-option.jpg
  17. Insert your memory stick and browse to the correct driver and install.
  18. Exit back to the Windows 7 install menu click "Install now" and on the next screen click "Custom (advanced)" to perform a clean install.image.axd?picture=install-windows-custom_thumb.jpg
  19. When you are asked where you want to install Windows 7 you should see that the 2 RAID hard disks are now visible as just 1 drive.
  20. Add a partition to the new drive so Windows with be able to recognise it.
  21. Continue installing Windows as normal.
Dec 04, 2010 | ASUS P6T7 WS Supercomputer Core i7 / Intel...
I want to upgrade my Toshiba Qosmio G25-AV513 to windows 7, but I understand that some of the programs will not function properly due to the old hard drive. Is this true or is the company I called for...
Uhm. I am typing this from a Qosmio G25-AV513... Using Windows 7.. With the original Hard drive.. Someone is lying to you. Lemme guess.. Best Buy?? Anyway.. It wasn't a totally straightforward upgrade.. You will need a little computer knowledge (finding drivers, ETC.) And since this computer came with a RAID setup, you will need to download the windows 7 raid drivers, and put them on a thumb drive BEOFRE you start installing, because when you get to the install screen it won't find a hard drive, you have to put the thumb drive in and click "Load Drivers", then load the RAID driver and it will work.. Drivers are kind of a pain to find since Toshiba didn't update their website with Vista or 7 drivers.. Thanks Toshiba. If you need help, e-mail me. P2000Canaro@gmail.com. Good luck!
Dec 02, 2010 | Toshiba Qosmio G25 (G25-AV513) PC Notebook
I have a TITANIUM Medion MD 8030 XL PC Desktop. I have upgrade the operating system from XP to Windows 7. MY tv/fm tuner card however no longer works in Windows 7. The XP driver for the tv/fm tuner...
Hi Adrian, i have a problem with my Tv turner, the driver for the web dont works, i lose the dvd recovery from my medion titanium 803 is any posibilty tha you can make a copy y share with me, if want i can pay u a fews buck via Paypal. Please send me a mail to leo4everr@gmail.com
Sep 01, 2010 | Medion MD 1804 (MD 1804 / MD 7315) PC...
DRIVER CD WON'T INSTALL ON WINDOWS 7
I got the Drivers i needed for FREE like the good old days.
Mar 05, 2010 | V-Stream Xpert TV-PVR 883 Low Profile PCI...
How to install windows 7 on Satellite A205-S5880
To install Windows 7 no need for RAID driver. If you face issues in installing Windows 7 disable RAID in BIOS, install Windows 7 and then install RAID driver.
How To Manually Upgrade from Vista to Windows 7 - Satellite A200/205:
http://cdgenp01.csd.toshiba.com/content/support/downloads/PSAF3U-PSAF6U-Win7UpgradeInstructions.pdf
Windows 7 Drivers page:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=2060003&rpn=PSAE3U&modelFilter=A205-S5880&selCategory=3&selFamily=1073768663
Dec 31, 2009 | Toshiba Satellite A205-S5880 Notebook
After i have performed the setting ,i tries to
try this download this program instal it,scan and update your drivers from here http://www.radarsync.com/
Dec 05, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
I NEED NEW DRIVERS FOR WINDOWS MEDIA CENTRE 7 ON
Get connected to the internet and download the necessary driver software for windows media center.
Nov 07, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
I need to reinstall my medion tv tuner / need free installation p
If you feel comfortable opening up your PC, you may want to try plugging the card into a different PCI slot on your motherboard.
Mar 08, 2009 | Computers & Internet
TV Tuner express card 54 DVB-T Medion
you need to install/re-install the drivers for the expresscard, should be downloadable from medion. Also check in control-panel that the device is there. If you look in My Computer/control Panel/System/Device Manager and the device is listed, with a yellow exclamation mark. try removing/uninstalling. or physically remove from the computer, re-install and go through the new hardware wizard to set it up.
Mike @ compurepair.
Nov 30, 2008 | Medion md40298 Notebook
Microsoft Windows Vista Home Premium with Service Pack 1: Windows Logo
511 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
