Question about Sony Dvcam DSR-PDX10 DV Digital Camcorder
Channel Two Input silent
Audio input Channel one works fine. Audio input Channel two is silent. Is there some adjustment I'm missing or is this a repair problem?
On the XLR attachment. Make sure the Rec CH Select is clicked up to CH1 - CH2. If it is down on CH1 only that might account for your problem. Audio will only record on CH1. To get stereo click the switch to up. Monitor the incoming sound with the audio level switch at the back of the camera. You should see level on 1 & 2.
Posted on Feb 11, 2008
Not sure of particular model, but if it's like z1 then it's convoluted and non-intuitive.
But here goes.. if i can remember.
Go into menu, then audio
check that the channels aren't linked
if set to manual check manual adjustment wheels
The z1 doesn't seem to allow on board mic and xlrs, so check that
Does mic need phantom power?
Is XLR input set to mic?
Sorry i can't be more model specific... but hopefully something of this will be helpfull.. the main thing to check tho is that the xlrs aren't linked
Posted on Jan 29, 2008
Not detecting right channel audio input
First make sure the connections are on the correct places. Audio is white and red, not yellow, right channel is red. Then swap the left and right cables, to see if the signal on the left cable input is now heard on the right channel. This will tell you if the input signal on the right cable is missing or if the internal handling of the right signal is bad.
Dec 14, 2013 | Pinnacle Video Transfer
I can't switch channels
Consult the owner manual (you can GOOGLE to find one with the model number if you do not have it) to see if the set has a feature to lock out channel being changed---this feature is on some sets so if using a box children etc cannot change the channel.
You can also try to route your signal to a rear audio/video input and change input to that input and change channels with the box if you use one.
Mar 30, 2012 | Hitachi 32HDL52 32 in. LCD Television
My new behringer vmx 200 dj mixer dosnt play sound from ch1 ...ch2 works fine ive tried everything but ch1 dont work
be sure when you select the chennel 1 input as your audio source you have an audio device plug inn at the channel 1 audio input..
Sep 11, 2011 | Audio Players & Recorders
Rotel RTC-850 Preamp left channel is silent. After some interconnect swapping, I determined I have a problem with my Rotel preamp. When I play my CD input into the LEFT channel i get the...
Before we throw in the towel, turn it off and exercise every control a lot of times throughout its range, particularly the Tape Selectors. Sometimes oxides will develop on seldom used controls and their 'normally closed' contacts will not pass a signal.
Dec 25, 2010 | Rotel Audio Players & Recorders
Lux Audio 5.1 home theater speaker & Yamaha HTR 5540 AMP
configure ur PC (both OS audio and third party sound driver) for surround sounds. control panel- sounds and audio devices - speaker settings - advanced - speker settings. so this done. make sure u select the 6 input channel - the button is on the right edge near the volume knob. near the vol button there are two buttons for selecting input type with up down arrow. from that u can select the input type this will be indicated on the top front indicator. but with the 6 input channel selected all selections are preceeded. if u select stereo mode u will have left/ right audio only.
make sure u connect the input right. connect from computer to 6 channel input. main, surround, center and sub-woofer.  connect the spekers to main (L/R), rear(surround) (L/R), center and sub woofer to terminal marked sub woofer ouput. this done select like i said before the 6 channel button. that should do it.
Mar 13, 2010 | Yamaha HTR-5540 Receiver
Sound disappears when channel is changed
try connect a rca cables to ensure sound , the tv has scart port or audio output rca? the digital input on receiver is non priority level, so every time you change chanell the receiver jumps to next Line input present. (receiver output security)
Jan 17, 2010 | Onkyo TX-DS474 Receiver
Red light is on when i connect input cable earthquake 1000w amp
Cables are either shorted, or deck is putting out too much power for input on amp... many new head-units will put out up to 7v on the output jacks (RCA) the amp may only want to see up to 1v will need to consult head-unit manual for adjustment of outputs.
Jan 22, 2009 | Earthquake Sound PH-D2 Car Audio Amplifier
Mic level problems
There is a small switch on the front side of the camera ( the lens side) make sure that it is set to mic (Input 1)
Hope this helps.
santhoshcj@gmail.com
Jan 31, 2008 | Panasonic AG-DVX100A Mini DV Digital...
Sony Dvcam DSR-PDX10 DV Digital Camcorder Logo
120 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
