Skipping CD We tried cleaning the CD's but every CD seems to skip so we tried cleaning out dust from the player itself but that didn't work either. What could we do or where could we go to have this problem fixed and how much would that cost. The system that I have is a Venture 5CD, Home Stereo System, Model # CD2775MSW
  • Anonymous Dec 20, 2008
    lots of skipping just had it for 11 months, what can i possible do with this.
    its a sony mhc-gx470 shelf system.
  • happy73 Feb 14, 2009
    I've had my SONY CMT-M100MD for 5 years now. Everything works perfectly apart from the cd player. It doesn't matter what cd it is it always skips on track 1 of every cd. I even bought the best cd laser cleaner-it skipped on that too. Are these models still available to buy?
  • 107 Answers
Try to adjust the trimpot/variable resistor.
Posted on Feb 02, 2008
Every CD skips. Seems to skip very badly at the beginning of each track and then about a third of the way through it will play normally. I have put the CD's in the correct way and have cleaned the dust...
The dust has probably got on the lens, which needs to be cleaned too. You can try a lens cleaning disc. But if that doesn't work I would use some Servisol Video 40 on it.
Jul 11, 2017 | Sony CDP-CX450 400-Disc CD Changer
When I turn the system on the CD Drawer keeps going in and out repeatedly by itself. When I load a CD it won't recognize it and won't play it and keeps going in and out opening and closing by...
Hello
Check all connections, such as from player to amplifier or receiver and receiver to speaker. Check and clean contacts on RCA jacks and cables and try a different input on the amplifier or receiver.
Clean the lens. Use only a special CD lens cleaner and follow the instructions carefully.
Check the traverse assembly (the metal rod that the laser travels along and the gear that drives it) if CDs aren't recognized or won't play, frequent skipping occurs at random, CDs randomly get stuck in one spot, the player can't find tracks correctly, or cleaning the lens doesn't work. Dust and lint may be interrupting its function.
Have the laser-head assembly checked by a repair person if the traverse assembly seems intact and free of debris.Look for broken plastic parts, such as gears and clips,look for loose or broken internal connections.possibly have gears and belts replaced.
Jun 09, 2011 | Audio Players & Recorders
Disc will not play appears to be skipping
There is a product called a cd/dvd lens cleaning disc. Worth the investment to have around.
Be sure discs are free of dust and scratches.
Apr 27, 2010 | Technics SL-PD6 5-Disc CD Changer
Cd's are skipping. cleaned discs and still skipping. tried cd's in different player and they work fine.
3M makes a CD lens cleaner that is a playable CD with micro brushes sticking out of the surface of the CD.
You can find them at office supply stores, K-mart, etc. I don't remember where I bought mine, but it works great for a CD-recorder that I use in a high dust environment.
Here's a link
to one that I just found by googling "3m cd lens cleaner"
I've never dealt with that vendor before, but it has a picture of the product so you can see what I'm talking about.
If this helps, please be sure to hit the "thumbs-up" for me!
Jan 24, 2010 | Sony CDP-CX300 CD Player
CD is skipping
Probably need to clean the lens inside the player. If you have compressed air you can GENTLY spray inside the tray to remove dust, otherwise go to Walmart and buy a CD cleaning kit to clean your lens. If it still skips then you might have a bad disc or player
Hope this helps
TankMurdock
Apr 27, 2009 | Aiwa NSX-D30 CD Shelf System
Plays cd's but lots of skipping going on. I tried cleaning with a CD player disc cleaner that I got today. That didn't help. None of the CD's skip in another machine. Thanks!!
When optical lens got dusty or thin layer of dust on lens, cd starts skipping, as you tried cleaning with lens cleaner cd but no result.
You need to open the unit and clean the lens with good quality cotton bud / swab with care.
Still no joy, replace optical lens.
Oct 10, 2008 | Sony XPLOD CDX-GT200 CD Player
Professional new karaoke system skipping and lyric problems
your disc is scrath or maybe the lens of your player is already weak,or have dust,if you can do the job,clean it with a soft cotton..wipe carefully with only one direction..try also the lens cleaner.
Feb 23, 2008 | Memorex MKS5009 Karaoke System w/CD/CD+G...
Skipping
Have your laser lens cleaned or buy a dvd lens cleaning cd available at radio shack. cost around 15 dollars.
usually when the laser lens builds up dust on or around laser lens players tend to skip.
Jan 14, 2008 | Mintek LCD TV Progressive Scan DVD Player
Tascam CD-450
re shock mount it in case blow out all the dust
Jan 14, 2008 | Tascam CD-450 CD Player
Cd player skipping
The DVD transport rides on chrome rails. These get dust and stuff on them and wont allow the optics to track.
If you dare, open the unit UNPLUGGED from the AC.
See if you can get at those rails easily. clean with WD40 on a swab. clean with a new swab . then a couple drops of mystery oil on a swab and run down the rails over and under.
You must be VERY gentle if you clean the lens with isopropyl
Oct 05, 2007 | JVC XL-MC2000 200-Disc CD Changer
397 people viewed this question
 Grubhead
Grubhead
