Question about Philips Televison & Video
Older Magnavox TV #RS3160-C103
This is second-hand without an owners manual. I just bought a new Home Theater System. It is hooked up properly to play DVD's...I can hear the movie play thru my surround-sound speakers, but cannot get a picture other than regular TV. Yes, all the obvious buttons have been tried. I have a universal remote (not the original) for this TV but it doesn't seem to be communicating my commands, such as getting a set-up/display screen so that I can program the HTS to play movies. Do I need a different remote?
PLEASE HELP!!!!!!
Joanna
6ya staff
SOURCE:
Bill Heronemus
  • 308 Answers
SOURCE: Samsung TXJ2754 (27") DVD issues (Sound but no Picture)
Assuming you have picture on the TV when hooked up to cable, antenna or satellite I would take the DVD player to a friends house to see if it worked on their set (using your cables of course). If you can't get a picture on your TV no matter what, then it could be either the Jungle IC or EEPROM IC inside the set. Since it displays "No Video Signal" on the screen, that leaves out the High Voltage section of the TV. My main suspicion would be the video cable or settings on the DVD or TV.
Posted on Jan 03, 2007
tvtek
Don
  • 1284 Answers
SOURCE: Cannot get DVD to Play on TV
Try the old RCA/GE channels of 90/91 or 92 to get to the inputs. Or try entering channel 00. Let me know if that works.
Posted on Feb 23, 2007
Anonymous
SOURCE: DURABRAND HOME THEATER
if you have a cable box run the subwoofer thru that . should work fine but you will have to turn off sub to kill volume as its running thru cable box not the audio of the tv
Posted on Dec 16, 2007
Anonymous
  • 3 Answers
SOURCE: home theater system connections
Hi
I have the same tv but my dvd surround is a toshiba, that shouldn't matter though. When I watch a dvd I go to component 2 which is where I have my dvd connected on the input of the tv when I watch tv and want the surround on I go to component 1 which is the tv input then on my dvd player I go to auxillary and I can watch tv in surround. I don't know the LG home theatre system but you should be able to select your inputs like between dvd, tuner, aux. Flip between them and you should get sound. hope this helps.
Posted on Jan 19, 2008
SOURCE: playing DVDs
try to use an Audio-Video(AV) cable(it has two or three wires,ask for it at the electrics shop),and push the button AV on your remote control.
Posted on Jul 19, 2008
Hi i have a magnavox 42" plasma TV (model
I'd look for the manual and see what it says about that red light. I can't find squat for "Magnavox KM42010P".
May 28, 2011 | Philips Magnavox MRD120 - home theater...
IM tryin to hook up my samsung home theater system to my philips tv. It works when watching dvd, but when i switch to my basic tv cable it doesnt play sound out of my surround sound speakers. How can i...
Check what type of Audio input it has on it. It should either have an Optical Audio input(glowing red while unit is turned on) or an Audio input(red and white jacks) You would run the correct cable from the Audio Output on your tv, To the Audio Input on your surround sound reciever. Let me know if this helps solve your problem.
Mar 04, 2011 | Philips Magnavox MRD20037 System
LOST MANUAL HOW O YOU HOOK UP THE SURROUND SOUND TO TV
1. Does your TV has an Audio OUT? If it does then connect the TV audio out to your Home Theater system's Audio In.
2. Are you using Cable box? If you do then connect the Audio out of your Cable box to the Audio In of your Home Theater system. video out of your cable box to the video in of your TV.
Jun 25, 2010 | Philips Magnavox MRD500VR System
Can't get the tv to play through the home theater
No they all are compatible with eachother no matter what brand tv,surrround sound. It is all in the hook up & without you stating how you have it hooked up,no way to tell because one siimple connection is all you r missing. You have it most way there if sound is ok on dvd.If you explain how you have it hooked up i can surley help you!!
Jan 23, 2009 | RCA L32HD31 32 in. LCD HDTV
How do we hook up the theater system to our tv?
If the tv has audio out on the back use phono leads to hook up to your system,if not then use a scart to phono convertor to get sound out of tv.
Hope this helps.
CABLE GUY.
Dec 29, 2008 | Audio Players & Recorders
Hi We have just bought a Panasonic Theatre Surround System SC-PCT560 and can only get it to work when a DVD is playing. We cannot get it to work with Sky or normal TV. Any ideas? Thanks, Julia
You can have TV sound from your home theater system.
Download User Manual of SCPCT560 from Panasonic Support and go to page-7 for hook up procedure of TV sound out from home theater.
Thank you.
Nov 30, 2008 | Panasonic Televison & Video
Lost installation guide for Magnavox MRD 510 Home Theater System
Download MRD-210 User Manual as it might help you to hook up video cables properly. Connections between Tv and Homer theater is not proper in your case.
Sep 11, 2008 | Philips Magnavox MRD510/17 Theater System
Home theater
Here is a link for your manual. It will be faster than telling you how to hook it up. Don't be mislead by first numbers you see in the left corner. Should be the correct manual for your home theater system. http://www.p4c.philips.com/files/d/dfr150017/dfr150017_dfu_aen.pdf
Mar 14, 2008 | Televison & Video
Televison & Video Logo
109 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
