Question about Samsung CLX 3160fn All-In-One Printer
Transfer belt error
Samsung 3160FN ALL IN ONE "pain in the neck" I replaced the transfer belt twice already and it still says replace belt. I think it might be a gear inside the machine that is stuck can you help?!!??!
  • 3 more comments
  • Anonymous Feb 14, 2008
    transfer belt error
  • Ruroshin Feb 15, 2008
    same problem
  • moe007 Feb 21, 2008
    paper got jammed, removed jam, and now comes up with transfer belt error all the time.
  • Anonymous Sep 30, 2008
    transfer belt error
  • Anonymous Oct 10, 2008
    I changed my black toner cartridge for the first time this AM and now 'transfer belt error" What is this?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 65 Answers
Transfer belt error, this is cause by the OPC drum which connects the belt. Make sure the drum sit well with the belt else replaced the drum.
Posted on Mar 14, 2008
How to fix transfer belt error in my samsung CLX3160fn
To fix this error, you will need to replace the transfer belt and/or reset the transfer belt count on your printer. If you are happy the the print quality of the printer, then you can try to reset the transfer belt count and that will clear the error. Otherwise you need to get a replacement transfer belt and swap it out before resetting the count.
To remove your existing transfer belt, you need to open the front panel, and remove the imaging unit by pulling the green handle. The belt is located above the imaging unit. Pull the belt down to release and then pull it straight out of the machine. Take your new belt and slide the back into the machine and push the front of the belt up to lock in place. Then you need to reset the belt count.
To do this, follow the steps below.
1. Enter Tech Mode by pressing [MENU] [#] [1] [9] [3] [4]
2. If you do not see the Tech Mode menu press the menu button again. (You need to enter the key sequence quickly.)
3. Select Tech Menu
4. Select DataSetup
5. Arrow to Clear Counts and press OK
6. Enter Password 1934
7. Arrow to Transfer Belt and press OK.
Hope this helps you.
Feb 27, 2011 | Samsung CLX 3160fn All-In-One Printer
What is this error? transfer belt error? what is the likely repair cost?
It means that the transfer belt count is at the limits of its useful life. The part number is JC96-03611C. The typical replacement part cost is around $150- $200.
Feb 02, 2011 | Samsung CLX 3160fn All-In-One Printer
CLX-3160FN askes for replace TRansport belt, is it a
replace belt,take drum out slide transfer belt wich is located ontop of drum.see how it is connected,slides in/out.
Jun 24, 2009 | Samsung CLX 3160fn All-In-One Printer
Re Samsung CLX-3160FN & Transfer Belt Error
Take out the Imaging unit ,transfer belt and fix it properly.
Also take care that you will keep the printer on even surface.
IF nothing is solving the problem then you need to replace the transfer belt as a final solution.
Jun 18, 2009 | Samsung CLX 3160fn All-In-One Printer
Transfer belt nees replaced
find samsung dealer,not hard to replace.
Jun 03, 2009 | Samsung CLX 3160fn All-In-One Printer
TRANSFER BELT ERROR
This error indicates that there is a problem with the transfer belt. Either it has failed, reached end of life ( it is a consumable item, just like toner, and needs to be replaced on occasion ), or just is not correctly installed.
Try reseating it first. Remove the imaging drum unit ( the housing that holds the 4 toners ). The transfer belt is the unit behind the drum that is inserted along the top edge of the drum cavity.
it can be a little tricky to get it in there correcty. Kind of hold it up against the top of the cavity as you slide it back towards its holder.
Oct 08, 2008 | Samsung CLX 3160fn All-In-One Printer
Transfer belt error
Rather than turn printer off, unplug from power source, wait a few minutes and plug back in. It's worked twice for me so far...
Sep 12, 2008 | Samsung CLX 3160fn All-In-One Printer
Samsung printer, transfer belt error message
Check on you drim uint the gears damaged.
Aug 06, 2008 | Samsung CLP-500 Laser Printer
Transfer belt error on Samsung 3160Fn
Yes, I fixed the problem. Send me $19.95 and I will tell you.
May 24, 2008 | Samsung CLX 3160fn All-In-One Printer
Samsung CLX 3160fn All-In-One Printer Logo
2,579 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
