Question about Bose (321GS) System
DVD drawer will not open
The drawer makes a noise like it is trying to open but never does. I have unplugged power source and basically rebooted to no avail. Any more suggestions?
  • 3 more comments
  • simbose321 Mar 22, 2008
    I have the same issue. We put in a copied video disc that had no menu option. It started to play after pressing play, then it froze. After that, we're unable to eject the disc.
  • Anonymous May 10, 2008
    BOSE 321 GS. CD door will not open. As other person mentioned the unit makes a sound as if it is trying to open but never does. I have already tried unplugging sub woofer from the wall, waiting 2 minutes, and pressing the stop/eject button when the unit is re-powered to no avail. Any more suggestion. Unit is about 3 years old.
  • Anonymous Jun 04, 2008
    Ditto. I have the same problem. The door suddenly stopped working - just makes noise and would not open. Tried unplugging device and rebooting - still not working.
  • Felixtax Jul 04, 2008
    My bose 321 dvd tray makes noise but will not open. I was able to get the dvd out, but it will not open anymore.
  • jbarnett88 Jul 16, 2008
    Are there instructions for opening the screwless case and replacing the DVD?
Disconnect the main power, wait a while, and then re-connect power. My system re-booted and the disc then ejected properly.
Posted on Jul 18, 2008
I had luck with disconnecting the power cord from the back of the unit.
Posted on Apr 02, 2008
Why can't we get the dvd to eject?
Possibility 1 -
The laser light inside the DVD player is most probably no longer aligned and cannot read the beginning of the disk. Therefore it keep on trying to find the first line but it can't.
Possibilty 2 -
Your husband entered a pirated copy and sometimes the first few tracks are unreadable due to the lower quality of DVD-R used and it jams the laser light inside the DVD player.
What needs to be done is to unplug the DVD from its source and gently pull open the DVD drawer in order to remove the stuck disc inside. Once that is done, power up the unit and press on the "eject" bottom so that the drawer can close itself.
Good luck.
Aug 16, 2012 | Samsung DVD-V4600 DVD Player/VCR
Hi, I need a pioneer dvl-909 service manual that tells how to replace the loading belt. Thanks, Bill
Try to see if the drawers are blocked by something either inside or outside of the case.
Mar 17, 2012 | Pioneer DVL-909 DVD Player
Cdr drawer won't open on Philips cdr 800.
looks like the rotor is jam or broken,try to unscrew it and open the top cover so you can see the rotor and then plug it in to the power source ,then always press the open/close button and check the rotor if its jam or broken and see what happen.
Jun 06, 2010 | Philips CDR800 4-Disc CD Recorder
DISC DRAWER WILL NOT OPEN
First, start with power cycling the player. Turn off the player and disconnect the power cord from the wall socket. Leave it unplug for about 5 minutes. Turn the player back on and try to open the drawer.
If same problem occur, then follow the steps below:
1. Turn off your DVD player. You do not want to risk electrical shock while working with it.
2. Locate your DVD player's manual Eject button. It is usually a small hole located underneath the DVD drawer.
3. Insert a stiff wire-such as a paperclip or safety pin-into the hole. Push gently and the drawer should open partway. Gently pull the drawer the rest of the way open.
4. Remove the DVD and see if there is a problem with it. Most DVD player drawers get stuck when a DVD is warped or the label is starting to peel. If the DVD is warped, discard it. If the label is peeling, remove the label.
5. Turn your DVD player back on. If it gets stuck again on a different DVD, then the problem may be with your DVD player rather than with your DVDs.
Mar 21, 2010 | Panasonic DMR-ES10 DVD Recorder
How can I get my DVD to get unstuck out of my VCR/DVD player?
I can't get any support from sansui. I think your DVD player is trying to read the disk. It can't and its stuck in DVD mode. This is just something I would try I don't know if it will work. Unplug the power source hold down the eject button and plug it back in. The objective is to try to get it to spit that disk out before it has a chance to try to read it.I hope this helps. If it does give me a vote and I'll know it worked.
Mar 04, 2010 | Sansui VRDVD4001 DVD Player/VCR
Dvd drawer will not open
Manually open the tray. It's possible that you have a dvd stuck in the drawer because it wasn't fully seated. Look at at the front of the drive and you will see a tiny hole. Take a paper clip or safety pin, stick it in the hole and push. You will see that the drawer will pop out and you can retrieve your stuck dvd. Thanks for using fixya.com
Jan 27, 2009 | Progressive Computer JSI 6 spkr. Home...
DVD drawer stuck out
Try to unplug the unit from its power source, give it a minute then plug it back in.If open appears on the window, hit the eject button. See if that will work for you. If that dont work, hit source and on at the same time, then eject if open appears in the window. That should close the draw for you.
Apr 19, 2008 | Bose 3·2·1 II System
DISC WILL NOT EJECT
Don't know if this will work for you, but I unplugged the player then plugged it back in again whlie holding down the power button. The player did not power up until I released the power button and pressed it again. That did it.
Dec 26, 2007 | Panasonic DMR-EH50 DVD Recorder
DVD door won't open
try using a knife without the dvd player plugged in that will get out the cd
Sep 22, 2007 | Philips Magnavox MWR20V6 DVD Recorder/VCR
The drawer on the unit won't open.
When the DVD player is plugged into power and switched on, and won't power up (nothing shows up in the front display panel), the power supply unit in the DVD is blown. the noise that player made was probably a capacitor going off. You will have to get the unit repaired.
Jul 28, 2007 | NexxTech DP3222 DVD Player
Bose (321GS) System Logo
101 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
