My Candy DFI 45 DISHWASHER WILL NOT RESTART AFTER POWER CUT, THE SELECT TYPE OF WASH BUTTON IS LIT UP BUT WHEN i PUSH IT TO SELECT NO LIGHT SHOWS ON THE SELECTED WASH
ring a local appliances repairer in your area or look ebay..or we can get it if u in uk.ring a local appliances repairer in your area or look ebay..or we can get it if u in uk.
You can't post conmments that contain an email address.
What is a Candy brand dishwasher? Made in the UK? That is not a manufacturer I have ever heard of here in the US.
What do you mean, 'doesn't seem to heat up any sense?'
If the dishwasher is older than 5 years, write it off to age a buy a new, high quality machine. Or do the dishes by hand.
Machines get old and die. If you are UK native, don't buy anothre Candy.
It sounds like you have a bad control console, and the problem is that your START button (the most critical one!) is bad. You can't replace just that button or key; you have to replace the entire control console.
my husband found the solution on line when he googled the problem. He read that the drain could have been blocked, or it said press the drain button. That did the trick, and now I have clean dishes! He didn't have to pay anyone to solve the problem which was nice.
1. No power to the dishwasher
Make sure there's power getting to the dishwasher. Check for a
tripped circuit breaker or a blown fuse. Check the wall socket for
power. Sometimes the power cord disconnects at the dishwasher
(inside the junction box, behind the bottom kick panel), if this is
the case, the wiring must be repaired or replaced.
2. Door switch
Replace if defective.
3. Timer/Control
Replace if defective (note: uncommon problem).
4. Selector switch
My Hotpoint FDW60 dishwasher - I select new programme (normal 55 degree wash) and it defaults to 45 degree wash green light flashing and just making a whirring sound but nothing else happens. I have tried pressing the restart button, holding it in until I get the continuous sound and then restarting the programme but the same thing happens
