Question about Garmin nuvi 350 GPS Receiver
GARMIN 250W Nuvi
Screen says "updating gps firmware 1%" then another says "gps firmwar complete" EVERY 10 seconds it comes on. can not connect to satellite
help
  • 3 more comments
  • Anonymous Feb 24, 2008
    Having exactly the same problem with nuvi 750.
  • billme Feb 27, 2008
    I have the same problem and it wont' stop doing it.
  • NYCARIMI Mar 02, 2008
    I am having the problem with my NUVI250
  • Anonymous Jun 25, 2009
    same with my 250w
1) Power up
2) Press battery symbol until you enter in test mode
3) Connect USB cable (if you do this step, you must see in device manager as GARMIN USB DEVICE)
4) Make update from WEBUPDATE
You must see update for GPS receiver. When it finished remove the cable to restart
Posted on Jun 13, 2008
Garmin just shows its loading maps and then screen goes blank and it repeats this even when I hold down the button for 10 seconds to reboot Why is it not turning on?
A Garmin Nuvi 1300 freezes on 'loading maps,' or is acting erratically is symptomatic of having corrupt firmware.
To correct this, I recommend backing up your favorites, clearing all user data, and if it still is stuck, then updating your Nuvi firmware.
Follow these three steps to take to get your Garmin Nuvi 1300 running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
_______________________________________
Garmin Nuvi 1300 Manual Download
Garmin Nuvi 1300 QuickStart Download
Garmin Nuvi 1300 Favorites Backup
Garmin Nuvi 1300 Hard Reset
Garmin Nuvi 1300 Webupdate
May 20, 2010 | Garmin nuvi 1300 Car GPS Receiver
English manual
I can help you with your Garmin Nuvi 250W.
You can download your Nuvi 250W manual from here.
I hope that helps.
_________________________________________
back up your favorites
clearing all user data (hard reset)
update your Nuvi firmware
Apr 25, 2010 | Garmin nuvi 250W GPS Receiver
Touch screen not working properly
If recalibration didn't work, then the touchscreen has failed. This NOT A FIRMWARE ISSUE!!
Please see this link:
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Every 30 seconds my Garmin Nuvi 200 displays a dialog box that says "Updating GPS Software 1%" followed by "GPS firmware update complete [OK]. Whether you press OK or not, the screens pop up again after 30...
did anyone find a solution to this problem? I have exactly the same at the moment. I've tried number of times to update it by webupdater, to reset it... practicly everything with no success. Thanks!
Nov 22, 2009 | Garmin nuvi 200W GPS Receiver
System software missing garmin 250w
If the unit indicates "software/firmware missing", then you can only try to re-install firmware by running WebUpdater again. If it doesn't work, then the unit has to be sent to service to have it re-flashed.
Jun 03, 2009 | Garmin nuvi 250W GPS Receiver
Firmware Update
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The latest software which can be done by installing a program called WebUpdater. WebUpdater can be installed via the link below and you must use it:
http://www8.garmin.com/support/collection.jsp?product=999-99999-27
Once updated please allow the unit to reboot which will ensure the software successfully installs.
After installing WebUpdater once from the Garmin website, perform all future software updates from your computer. Simply connect your compatible Garmin device to your computer, then run WebUpdater from your computer's "Start Menu" by selecting "Start", "Programs", "Garmin", and finally "WebUpdater"
Garmin Communicator Communicator Plugin is properly installed and up to date, version 2.9.1.0. (Dec 21, 2009) If after following all the above the final steps would be to perform a master reset.
  1. Start with the unit OFF and unplugged from power
  2. Touch and hold the lower right corner of the screen with an index finger or the eraser end of a pencil
  3. Continue touching and holding the lower right hand corner of the screen then power the unit ON
  4. Release the power button when the device powers on. After 5-10 seconds you will see a new message: Do you really want to erase all user data?
  5. Remove your finger from the touchscreen when this message displays
  6. Touch Yes, and wait
The device will automatically reset. Please follow the on screen prompts on the nuvi and when completed place your device in an area with a clear view of the sky until it acquires satellites.
Mar 26, 2009 | Garmin nuvi 260W GPS Receiver
Garmin Nuvi Firmaware Update Complete, Unable to catch satellite signal
Try performing a reset of the unit. Hold down the bottom right of the touchscreen and turn the unit on. It will ask you whether you want to reset allk data. Choose yes and try again. This should solve your problem. Hope this helps.
Feb 20, 2009 | Garmin Nuvi 660 GPS Receiver
So what happens when you connect it to the PC?
Make sure no sd cards are installed while you do this.
download and install web updater, run it it gets to a screen where it looks for the gps, plug the usb cable into the GPS (no USB hubs please!!!) Make sure it detects the GPS before you continue. Select the updates you need (don't install all the languages !!) after this is done the program will report the downloads are on the garmin, unplug the unit and it will reboot and whilst rebooting it will install the updates....so don't touch it until it reboots again and displays the regular screen....and make sure the batery is fully charged before you do this...!
Jul 23, 2008 | Garmin nuvi 350 GPS Receiver
Screen shows "updating GPS firmware"
Hey, got this problem licked!
Go to the Garmin website and download their latest S/W. It fixes the problem!
May 28, 2008 | Garmin nuvi 200W GPS Receiver
my garmin nuvi200 keeps on searches for satellite,but it couldnt able to pick up signal. A question mark over a map is always im seeing througout
Apr 06, 2008 | Garmin nuvi 350 GPS Receiver
Garmin nuvi 350 GPS Receiver Logo
247 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
