posted by Denise B on Jan 29, 2008
The buttons (Menu/Enter, Auto/Exit, etc) on the front of the monitor stopped working. Any suggestions?
Comment by Denise B, posted on Jan 30, 2008
This is a monitor in my office at work and the company won't go for that idea. Thanks for your suggestion.
Best Solution
Hi Denise,
Hope this helps; If you can control this before, ask for asisstance in opening monitor chassis with certified technician due to High Voltage Shock risk. Resolder the menu buttons and the control circuits. Resolder also SMPS module driving voltage to control circuit.
Best regards,
Rosener
Best regards,
Rosener
Comment by rosener, posted on Jan 31, 2008
Your welcome Denise. I understand the monitor still usable, button settings are seldom use anyway. If there's a need to adjust basic control try to look if your monitor comes with the software control/driver application you can adjust settings there like frequency adjustments, color scheme, etc.. However you can also access settings at Control panel, Display properties. Have a nice day!
Rating Locked! (?) Denise B has rated this solution as Thanks for Trying
Solution #2
posted on May 18, 2008
Best Solution
rosener
Rank:
Wiz
Rating: 81%, 65 votes
Hi Denise,
Best regards,
you are an idiot i have the same problem several times with this unit too. and it has nothing to do with a burnt wire you ********* stupid ********.
rosener
Rank:
WizRating: 81%, 65 votes
Hi Denise,
Best regards,
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for TDV Vison TDV FV19B 19 in. Flat
Email this problem
Email this problem
Can you Help with these Monitors problems?
TDV Vison TDV FV19B (Black) 19 in. Flat Panel...
Vison 19" monitor speakers...
have the speakers plugged in... Answer This...
Repair Service
Find Monitor Repairman Near You:
