Question about Brother DCP-8045D (Bundle) All-In-One Laser Printer
Doc. Cover Open
DCP 8045D Printer Manual
Have checked all doors. This message comes up. I can print from pc but cannot use any other function.
  • Anonymous Apr 27, 2009
    I can print from the printer but the 'doc.cover open' sign is displayed on the LCD of the printer. I checked all the covers are closed properly. I also removed the catridge and replaced it again and shut the covers properly before switching the power on. Please help!!1
  • Brother Master
  • 1,113 Answers
Broken left hinge stopping doc cover switch in left corner activating
Doc. Cover Open - 53b706a.jpg Here is link to purchase one for $25 bucks, three screws and job done, easy fix!
Posted on Jan 29, 2008
How do I reset dcp-8045d hex dump mode
Probably the easiest way to turn off the Hex Dump mode would be to reset all printer settings. There should be a reset menu that will allow you to reset the printer to factory defaults. After which it should recognize the new ram and print normally.
Apr 02, 2015 | Brother DCP-8045D All-In-One Laser Printer
I need to know the number for the toner cartridge for a DCP 8045D all-in-one laser printer
The OEM number from Brother is TN540 for a standard cartridge and TN570 for a high yield cartridge (more toner)
Jan 04, 2011 | Brother DCP-8045D All-In-One Laser Printer
Brother DCP 8045D prints and copies but won't scan
Check out that the Scanner USB cable is connected to the PC apart from the printer Cable
Mar 08, 2010 | Brother DCP-8045D (Bundle) All-In-One...
The Brother DCP 7020 printer displays error
back cover door switch is displace so it called back cover open.
Oct 12, 2009 | Brother DCP-7020 All-In-One Laser Printer
Dcp 8045D laser printer error say doc cover open, I don't no what is a doc cover, and the manule the machine came with can't be found
The document cover (or lid) is the large part that you pull up (open) when you want to scan a single page using the "flatbed" part of the scanner instead of the automatic document feeder (AFD).
There may be something under the lid that is holding it up slightly open.
Lift the lid and close it...
It should work, now.
If NOT, Turn OFF, unplug from outlet, wait a few minutes and plug back in.
Hope this helps!
Sep 10, 2009 | Brother DCP-8045D (Bundle) All-In-One...
My copier/printer lists the LCD alert 'back cover open'
"back cover" can be connected to more than one cover. If there is a door in the back it may also be connected to the Side cover.
What you need to check is the switches/sensors to see if maybe they are not sitting correctly in place.
Open the doors and look for a protruding piece of plastic on the door, this corresponds to a hole in the machine that has a sensor or switch behind it, is it pushing the switch all the way ? (may need to be adjusted). Is there a sensor? is it loose?
Dec 11, 2008 | Brother DCP 7010 Multifunction Laser...
Brother dcp 8045d paper jammed - there's no paper!!
you can replaced scratched part at authorized service)))
If you have error "paper jam" and cannot find paper in your DCP, you must manually recheck all (!) (4 items) paper sensors ))))
I think that a paper sensor at fuser section damaged))))
Nov 07, 2008 | Office Equipment & Supplies
Brother DCP-8045D (Bundle) All-In-One Laser Printer Logo
196 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
