Question about Samsung HCJ652W 65" Rear Projection Television
Remote not working for TV
The remote is not working to change the setting on the tv
  • Anonymous Feb 01, 2008
    I know that the remote is working because it can change the channels on the cable box.
  • 77 Answers
If the batteries are good try this:
If you have a video camera, set it to record, then point the remote at the video camera and see if you can see the lights blinking at the end of the remote. (The video camera can see the infrared light pulses emitted by the remote even though your eyes can't). If you see pulses then your remote is working. If not the your remote is broken.
Posted on Jan 29, 2008
6ya staff
SOURCE:
Tv remote doesnt work
Programming a universal remote does not change any settings for the TV. If the original remote is not working you may want to try changing the batteries. If this does not help, the remote itself may be bad.
Apr 09, 2014 | Panasonic Viera TX-32LX70 32 in. LCD TV
Rca 24" tv remote won't operate tv
If set turns on with the power button on set the remote is : not set to TV, not programmed for the set, has bad batteries or is bad.
If it even works one function it may need to be reprogrammed or taken apart to see if works---you can test the remote by pointing it at a digital camera with a LCD screen and pressing buttons to see if it makes the screen flash on the camera.
Test the remote first
Apr 09, 2012 | RCA Televison & Video
The battries in remote are new. the remote wont change channels or turn power on and off.The buttons on the tv set wont work either.It keeps saying child lock is on.
As the remote is not working please
1.check the batteries are properly installed with correct polarity.(+ and -)
2.Check weather correct remote operating is set.(TV,VCR etc)
If both are OK then please programm your remote again with the TV.As you removed your battries it might reset the code
When using buttons on TV it says CHILD LOCK is ON.
Child lock fuction is to prevent children operating buttons in TV console. This can be set only by remote. Cannot set by TV console Buttons.If this fuction is activated you cannot use the TV console buttons.
Thanx
Jul 23, 2010 | LG 47LC7DF 47 in. LCD HDTV
Remote not working anymore for my LG 42PQ20. Ive tried changing
call LG if you think the TV is not accepting the signal from the remote the TV may have a fault in it. If you have any universal remotes try programing them to control the TV if they work but the other does not it is remote.
Mar 15, 2010 | LG 42PQ30 42 in. Plasma TV
Remote won't turn tv off or on. Mute, volume also does not work
Take the set apart and see if there is a separate board in front of the set. Remove the board and check for cold solder joints first. If o.k., replace sensor. Then again you could contact toshiba and order another key pad for the set.
Jul 07, 2009 | Toshiba 13A24 13" TV
No remote (LG or otherwise) works
The remote receiver in the TV set, or its associated circuits inside the TV are not working. This would be fully proven by trying another known working remote on the TV set.
Jerry G.
Mar 29, 2009 | LG 32LB9D TV
Harmony 880 Logitech tv remote - won't change channels on direct tv
you may need to reprogram your remote, or, if you have your profile setup on the harmony website, reload from there
May 11, 2008 | Logitech Harmony 880 LCD Remote Control
Remote stopped work for my kp-61hs10
Sounds to me like a problem in the tv, not the remote. A short maybe, or a bad connection somewhere.
Dec 22, 2007 | Sony KP-61HS10 61" Rear Projection...
Front controls mixed up & remote doesn't work
the channel down button is stuck on, you need to replace this switch internaly to the set.
Nov 14, 2006 | Sony KV-36FS100 36" TV
Samsung HCJ652W 65" Rear Projection Television Logo
44 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
