Question about Kenmore 43142 Front Load Washer
It sounds like it's coming to get me!! Since it's imbalanced
Since 2 jeans were washed, it is really loud. It sounds like the ballast is loose. if the load is med. it's super really loud but will spin fast -if the load is bigger it doesn't spin much and the clothes are soaked. Now, since the hoses were removed for my diagnosis they are leaking it seems. I heard this noise is due to the imbalance-ness. When I took the back off all the springs and "tethers" seemed in place. A repair shop told me to run it empty, I did and it was fine but when I put clothes in it...........
  • lroy152 Jan 29, 2008
    okie dokie, but where are the bearings?
  • 126 Answers
Check the bearings....when the bearings are gone, it will leak too...
Posted on Jan 29, 2008
Loud grinding clicking noise during the drain cycle
It sounds like your drain pump has failed or has something stuck in it. You didn't specify a make and model so all I can say is that there are several good videos on YouTube about this problem because it's fairly common. Good luck!
Nov 23, 2013 | Whirlpool LHW0050PQ Front Load Washer
When my washer is on spin cycle it is making a knocking noise and is loud. It is really bad on towels.
Sounds like it is being overloaded. Alternatively take the lid off and check that the counter-weights are still ok, these look like concrete blocks. Also try and look underneath by tilting the appliance back and checking the shock absorbers are still connected, these are the 2 bars connected between the drum and frame. If all looks ok try reducing the load size. Especially towels and jeans as they become very heavy when soaked with water.
Feb 22, 2011 | Washing Machines
WHIRPOOL washer model LSR8010PQ0, WHEN LOADED WIT...
If large items in the machine create an imbalanced load the machine is designed to switch off...Towels are notorious for doing this because they hold so much water. Jeans don't soak up much water. Wash towels with towels alone and the problem should be reduced....Good luck....Nomess
May 16, 2010 | Washing Machines
Washer making loud noise. Shuts off, not draining.
It appears that you have an imbalanced load, or a nearly balanced load with a machine that easily goes off balance during spin. I would suggest:
1. After the unit trips on imbalance and stops spinning, open the lid and redistribute the laundry load inside to balance its weight equally around the interior of the drum. Note that cotton fabrics hold much more water than synthetics, and this has resulted in imbalanced loads even though they visually appear to be balanced. Close lid to restart spin.
2. Remove the front panel and check both tensioning/centering springs on the sides of the tub. A loose spring could easily cause the machine to go off balance.
3. Finally, check the main bearng play by holding the drum steady and moving the top of the agitator spindle horizontally toward the rim of the tub. Any excessive play is a clear indicator that bearing is excessively worn and may be resulting in an unbalanced load.
Oct 05, 2009 | Maytag Washing Machines
Shakes and makes a loud noise - imbalanced
Hi.....
Im not an expert, but i used to work for comet electicals. I have come across this problem a few times, and most times the problem was caused by the transitbar/ bolts not being removed on instalation. These can be located at the rear of your machine.
Hope this help, Graham
May 19, 2009 | Maytag Washing Machines
Turn off ALARM - Whirlpool washer
This sounds like the imbalanced load alarm. This can occur with large heavy loads like blankets, bedding, lots of diapers (cloth), jeans etc. The best solution is to wash lighter loads and not overload the machine. If overloading continues, the machine could be damaged.
Apr 11, 2009 | Whirlpool Ultimate Care II GSW9650LW Top...
Dryer Noise
You need to have you belt replaced. Over time the belt will strech.
this causes the dryer to still spin but the belt will sometimes loose the grasp of the drum and cause the belt to spin only.
This happens because over time with heavy loads of towles and jeans pull down on the drum as it is being loaded. Than when in cycle the jeans will drop from the top to the bottom pulling aginst it even more..
Aug 14, 2008 | Dryers
Sounds like a loose screw/bolt/nut during the spin cycle
There is nothing wrong with your machine. Don'f bother with the sound , You said you threw 2 pair of jeans, so its bottons are causing the sound against the drum during cycle. Finished your laundry and worry no more. To make sure, throw some another clothing asides form jeans, like shirts, and feel the normal silent of your machine.
Good Luck,
Eriez
Jun 05, 2008 | Maytag Neptune MAH5500B Front Load Washer
Loud buzzing sound
Hello Jack,
That buzzing might be two things. It could be the color wheel or the ballast for the bulb. To check this you will have to move the projection section of the TV out of the case and listen for the sound in the area of the color wheel and the ballast. Try removing the color wheel power to see if the buzzing stops if it does then it's the color wheel is not and the ballast is buzzing then It's the ballast, and it will need replacing or if you know electronics you could try fixing the old ballast (I would suggest getting a new ballast).
Better still if you are uncomfortable working on the set you could get a qualified TV repair person to repair your TV .
I hope this helps,
Thank you,
Shuttle83
Jan 07, 2008 | Televison & Video
Kenmore 43142 Front Load Washer Logo
67 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
