-   I have a mitsubishi wd62628 dlp
I cant seem to get the xbox 360 or ps3 to work in component in 1-2 or 3
The 360 worked fine for a day and then it is now just a blue screen or scrambled image if i turn blue screen off in settings . the ps3 work great in the hdmi and dtv hd work fine on component in and hdmi . my xbox 360 is older so i dont have hdmi out and it worked before i dont get why it stopped working . it works in vga so its not the xbox.-   smithjeff10
Aug 29, 2008
-   Same problem as described. Watching TV no problem. Suddenly goes to blue screen with message that there is a cable/signal error. Tried switching to DVD player (different cables) and also got a blue screen there. Must be something within the circuitry of the TV because the Cable box and DVD player work independently using separate cables.
-   vincepa
Jun 20, 2008
-   All connections are connected properly but blue screen comes up and states it is not connected correctly. About to pull my hair out. It worked great this morning. Turned it off, went to work, came hom eand now this. Noone was here and there are no animals to touch anything or crawl around. Any ideas that I haven't already heard.
-   Sony 57" rear projection. Blue screen and then shuts off. Any help or answers. Thank you.-   dionmr
Feb 20, 2008
-   I have cox cable running from the wall to ant a/b neither works. screen is fuzzy then tuns blue. i get A&E on PIP. every channel is A&E, but can only see it in PIP.-   guitarmaster
I replaced lamp and picture shows well except at the bottom of sceeen ther is a glow like a flash...
(More)
I replaced lamp and picture shows well except at the bottom of sceeen ther is a glow like a flash lite reflection.or glare from a light that wasnt there before i changed the lamp.
when the pt-61lcx66 is on, the screen is totally green. It won't show any channels and only shows...
(More)
when the pt-61lcx66 is on, the screen is totally green. It won't show any channels and only shows the menu choices for the tv itself. The sound works though the surround sound. What might be the problem?
Looks like I have extra blue and yellow lines abow the image on my Hitachi 61SWX12B 61 in , just...
(More)
Looks like I have extra blue and yellow lines abow the image on my Hitachi 61SWX12B 61 in , just started today ?
