You need to sync your controller with the ps3, put the USB dongle into one of the available slots on the ps3 - exactly where you would normally connect a wired controller on the front. Now switch on your ps3, the dongle will connect, now put your USB cable into the black ops controller and switch on - your 4 lights should be flashing on the controller. Now press connect on the USB dongle, your controller should now sync to the ps3 and hopefully will show as controller No 1. Remove the USB cable and play wireless.
It sounds to me like there is a noteable delay due to a combination of things: your Bluetooth wireless controler (primary reason), and the cable connection from your PS3 to your TV. Now, to determine what the problem is specifically, you'll need to check a few things:
1. Make sure your PS3 is updated to the latest software
2. Check to make sure your cable connections from your PS3 to your TV are firmly in place. I personally have noticed that I got delayed reactions when my HDMI cable was not firmly secured to my HD TV. Weird, but as soon as I unplugged and re-plugged in the cable at both the TV end and the PS3 end, it cleared things up for me. If that does NOT work (btw, this can also be the case if you use a composite or component set up too).
3. Check to make sure that your PS3 controller is fully charged. Controllers that are partially charged occasionally do demonstrate really weird results, like the delay you're talking about. So, make sure that your PS3 controller is fully charged.
4. If the controller is fully charged AND your PS3 to TV cable is plugged in properly, then try to plug the USB cable to connect your PS3 controller to your PS3. Sometimes, for reasons I don't know about yet, this could solve the delay problem.
At the back top of the remote behind the 4 red lights there is a tiny pin-hole. With your PS3 on, press the big PS button on your remote, then push the button inside this little hole; a pencil lead may work. This is the only time you need to do this.
Good luck and please give me a good rating if i've helped you.
If it is properly hooked up to the PS3 via the USB cable, it should only take about an hour to fully charge. NOTE, it will only charge while the PS3 is powered on. I hope this helps. Good luck to you.
I was having the same problem. Controller would only work when plugged in. Solution: I shut down and unplugged the PS3 for several minutes. Plugged in the controller. Turned on the PS3 and let it boot up. Pressed the PS button on the controller and let it sink up. When I unplugged the controller it worked.
