Question about Marantz VC4400 Multi-disc DVD Player
To repair or not to repair?
VC4400 problem:Hi!THe door wouldn't shut to my player so I unplugged and took the lid off to find a cd off track. A little white plastic cog has come loose. Now the door won't shut or open. Is this worth repairing?Thanks for your time!S rogers
How to adjust my shanling mc-50 cd player lid so it plays every time?
Sounds to me like you have a faulty kill switch on the lid, may be loose or dirty
May 04, 2014 | Audio Players & Recorders
HI. My Acer Aspire 3500 DVD drawer was I guess off track. The drawer wouldn't open so I pried it open. Now it won't stay shut and when it is shut I can't open it unless I use a paper clip.
There is very little you can, these items in general cannot be repaired. Go to www.ebay.com Type make and model of laptop, refine search to cd/dvd driver.
Jun 12, 2012 | Computers & Internet
KD-HDR40 will not play any CDs, only displays a "CD reading" message.
Sounds like CD mechanism failure. Did some sticker or anything went inside? Any way, need service.
Mar 03, 2012 | JVC Kd-hdr40 Car CD/ MP3 Player
When recording disk reads repair
"REPAIR"
Because the disc was left in the unit after recording and the power plug was unplugged later, the track number and
recording time data have been cleared without being recorded on the disc.
While "REPAIR" is displayed, the track number and recording time data are repaired by tracking the recorded area. Further
recording or finalization is possible when the display returns to the previous condition. Tracking the recorded area takes about 40 minutes if the disc has been fully recorded.
Jan 29, 2011 | HHB CDR850 CD Recorder
Jvc xlmv33 three tray karaoke cdg player
TRY A LASER LENS CLEANER,,AND TAKE COVER OFF TRY BLOWING IT OUT ,,
May 12, 2009 | JVC KARAOKE, 3-CD CHANGER, 3 MIC INPUT,...
Tracks too short to to create CD from hard drive.
either have to delete the short tracks from playlist to burn...when i get mssg theres usually nothing there (hit new track 2x by accident, just silence) Or if u want what is on the short tracks, have to join it to longer track b4 or after it, making one longer track, and no more 1 sec track...to do: hold playlist edit and delete track button, will ask if want to join two tracks, say yes and its done...When u do this, the track you do this on will b joined to the previous track, it will give u mssg showing which two tracks about to join and what track name will b left...(for example do u want to join track 01 to track 02...resulting track name will b track 02)..can then burn once all short tracks either deleted or joined to larger tracks...
Apr 03, 2009 | Alesis MasterLink ML-9600
Draw doesn't open
Hi...
I would say "belt" 1st too.
http://www.encompassparts.com/models/?DENDCD620
Belt is there.
Mar 24, 2009 | Audio Players & Recorders
Faulty goodmans 1104s dab player
In the lid should be a mgnetic plate that holds the disc to the motor spindle (much like slight pressure would). Inspect it to make sure it's free moving and seating all the way when the lid is closed. I had one unit where the spindle on the motor shaft had slid down slightly causing the magnetic plate to not seat down all the way. Also, if the magnetic plate is removable, try placing it on the disc with the lid open and bypassed and see what happens.
Hope that helps...
Geno
Mar 06, 2008 | Televison & Video
Player stuck in scan mode
Hi...
Unplug it from the wall...give it a couple minutes. Try playing a CD again (using manual controls) If that works , your remote might be the issue.
If you bought the thing new you paid good $$ for it.
It's worth having it looked at by a Pro.
Oct 22, 2007 | NAD C521 CD Player
Technics SL-PD9,SL-PD7A
Ouch, you should not have disconnected the front door.
Unplug.
Take the lid off.
take all CD's out.
Figure out where the plastic bit goes.
Good luck.
Sep 23, 2007 | Technics SL-MC6 CD Player
Televison & Video Logo
Top Marantz Televison & Video Experts
Marvin
Marvin
 Grubhead
Grubhead
Are you a Marantz Televison and Video Expert? Answer questions, earn points and help others
