Question about Canon PIXMA MP830 All-In-One InkJet Printer
Scanner My scanner will no longer communicate with my computer. I can not get it to work and I feel I've tried everything.....any suggestions.
I couldn't get the MP830 scanner USB interface to work on initial installation. Canon was unable to help, other than to say that the USB 2.0 had to be native (i.e., had to be on the motherboard, and not an addon board). London Drugs computer dept (from whom I bought the printer) suggested that re-installation of the operating system (WinXP) might help. Bingo - it worked!
Posted on Feb 12, 2008
Won't Scan -- "Cannot properly communicate with the scanner"
I think the USB cable is defective or the scanner is failing.
Apr 25, 2017 | Epson Gt-15000 A3 Flatbed Scanner Eu-45
Epson scanner cannot communicate
My solution was that Epson Scan was set to connect via network instead of local. (All was working fine, then it quit-something changed this setting) Try this, go to start, choose all programs, choose Epson folder, choose Epson Scan, choose Epson Scan Setting. In the pop up box set the connection to local or network, whichever is appropriate. Close the window and open photoshop and all works fine. It could be that your problem is the opposite of mine- I try switching this to the other setting even if the change is wrong, then switch it back to see if that works too.
Good Luck.
Jan 05, 2013 | Epson WorkForce WF-7520 Wide Format...
Microtek Scanner thinks it's busy when it isn't
Check using a new USB cable. Unplug everything else plug into USB except for mouse and keyboard. If not work. Un-install driver and software. Download driver and latest software. Reinstall printer using driver only. Then use Paint to test it.
May 05, 2017 | Microtek MRS-1200X6U ScanMaker X6 Flatbed...
Xerox documate 152 scanner - won't scan
Hello.
I am a Support Engineer with Xerox Scanners.
If scanner is stopping @ 98% is normally due t oa communication problem. Make sure USB cable is conencted to rear of PC ,and cable is no longer than 6ft..
We also have an extensive support site and knowlegebase at http://www.xeroxscanners.com/en/en/support/
If you continue to experience trouble, please feel free to contact us by calling 800-648-0410bsat4ube4gblqiaaaaasuvork5cyii=.
Regards,
Xerox Scanners Support
Oct 30, 2012 | Xerox DocuMate 152 Pass-Through Scanner
We have 2 scanners. A wireless network. All too often the scanner is just as dead as a dodo. We send it in for repairs it comes back and it keeps losing the IP address and defaults to honeywell login. We...
I would suggest not
try uninstalling the drivers for the printers then going on line to the manufacturers web page and selecting a download for the model and suitable for your win os and start again
it indicates a communication problem with the pc
if you are running win xp the problem could be there as win xp is no longer supported by Microsoft and was good is no longer good
Nov 25, 2017 | Dolphin 7900 Handheld Barcode Scanner
Scanner no longer communicates with the pc
Have your scanner turned on when you boot up your computer. Go to Programs, Acessories, Scanner and camera wizard, and it will give you directions if the scanner is not installed and recognized.
Aug 21, 2009 | Pacific Image PrimeFilm 3600u Film Scanner
The software cannot communicate with the scanner (Prime Film 3600
I have a PrimeFilm 1800u. When I attempt to scan into a Roxio application, the program does not respond. The hardware and software are both installed. No problems scanning or communicating with this scanner before. Is there somethere there that has a soultionfor this problem ? Thanks
Mar 16, 2009 | Pacific Image PrimeFilm 3600u Film Scanner
Scanner Powers up - does not intiate, cannot be accessed by PC
Power everything down, computer and scanner. Make sure your scanner is connected to the AC wall outlet, and to the pc. Then turn on your computer. Reinstall the driver and software by following this link http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=kVFQIoh3k1nuobYrVg0U002FnSoPZ+wxlW6UdEWrYhTx6DwU003D&tc=6 And download the latest update (2007) and you should be good to go
Nov 23, 2008 | Epson Perfection 4180 Photo Flatbed...
All in One Scanner/Printer problems
Go to this link and type "cannot communicate with scanner" in the search box. Click Search. Then select the "ERROR: Cannot communicate with scanner" link. You will see several things to try to correct your problem. Usually, this error shows up if there is another USB device connected which prevents the computer from "seeing" the scanner, even though it can print without problem. So do try to disconnect any other USB device (except mouse or keyboard) and reboot the system.
May 20, 2008 | Canon PIXMA MP160 All-In-One InkJet...
SCANNER ERROR
Generally all in one devices have problem with drivers!!! The main problem is communication between computer and printer!! Try to find another driver or reinstall the old ones!!!
Sep 24, 2007 | Xerox WorkCentre XD100 All-In-One Laser...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
75 people viewed this question
old marine
old marine
