Question about Canon imageRUNNER 3300 All-In-One Laser Printer
Constant jamming, front door opening on its own
Waiting on service, but i'm in a real pickle. Yesterday for no apparent reason the machine is jamming with almost every copy in 2 spots. Side door roller & the normal jam area in the front left. Well to add to that, now the machine has mysterious gremlin living inside it. With no one anywhere near the machine the front door opens with force.
I am dead in the water without my fax/copier.
Any help is appreciated.
    President:
  • 4,402 Answers
Remove paper dust from roller above
Posted on Jan 29, 2008
How to open door on2000 mercedes s 500 door deos't open from inside or outside
Thats a real pickle but you have to somehow get the door open without damage and remove the door panel and then replace mechanism controlling doorlock
Aug 02, 2013 | 1999 Volkswagen Passat
Problem with paper feed. frequent message: carriage jam, open top. No apparent jams, cleaned rollers, slider bar, etc, problem persists
Turn off the printer
Open the Rear Access Door,
Clean the rollers ( upwards ) with a lint free cloth ( little damped in water )
Close the Door
Open the Front access door, Check if there are any paper pieces stuck,
Remove the cartridges out and Install back.
Close the Door and turn on the printer.
It should work.
Regards,
Ron
Feb 22, 2011 | HP PSC 1610 All-In-One InkJet Printer
Washer Door won't open
kill the power either unplug it or turn the breaker off wait few minutes hopefully might reset it if not call service... may need new control board or latch mechansim kinda common after power outages when power comes back sends jolt blows electronics out hope this helps
Jan 27, 2010 | Maytag Neptune MAH5500B Front Load Washer
We have a Kenmore Elite front loader and yesterday while washing a load of laundry, the lights flickered and then the machine turned off. I checked all the breakers, unplugged and replugged and nothing...
There is a pull tab at the bottom of the door latch assembly that can be used as a manual release for the door by pulling it down.
Lean the washer backwards and unscrew the 3 screws under the bottom edge on the front of the washer to remove the lower panel under the door. Once the panel is removed, reach the tab with your hand up inside the washer behind the front casing on the right side and pull it down. The door will open.
If there is an error prior to the jamming of the door, the door latch assembly must be replaced. Feel free to let me know if that is the case.
Dec 01, 2009 | Kenmore Elite 45986 Front Load Washer
While printing with OKI C5600 very often error message pops up about jammed paper though no REAL jam happened. To solve I just open and close paper tray and front door. JAM PAPER error is real pain if...
Have you tried cleaning the paper feed roller(s)? Either soap & water OR isopropyl alchohol with a cotton ball will do, just make sure the rollers are dry before trying to print again, otherwise damage to imaging unit (drum/toner unit) could occurr. If the printer doesn't feed in the first place, the printer thinks it has a jammed paper, thus opening paper tray and front cover resets misfeed/ jam condition. Let me know your progress....Tim
Oct 24, 2009 | OKI C5500n Printer
Over Flow Fault detection
Press "end of cycle" button; and wait for 2 minutes before trying the door. Do not force the door.
Rate me if helped please.
Jan 12, 2008 | Asko W6661 Front Load Washer
Coffee machine
I had the same problem. It had to go back to the service department and a replacement part was needed.
May 17, 2007 | Saeco Incanto Classic Espresso Machine
Canon imageRUNNER 3300 All-In-One Laser Printer Logo
53 people viewed this question
old marine
old marine
