Question about Bissell Powersteamer 1694 Upright Vacuum
Won't extract water from carpet.
I have a Bissell Quicksteamer, the model number on the back of it is 1950-W. The only problem I'm having is it won't extract the water from the carpet. It was working fine the last time I used it. I even took it apart and cleaned all the parts. Still no suction. Please help!
    President:
  • 1,673 Answers
Seems the 1950W is now obsolete, cna't even bring up a drawing of it. Usually when the vac. motor is running, then there has to be suction. But if a seal or gaske is missing, then the suction will be lost. So you might check the dirty water tank to make sure there isn't a part missing or out of place. Check this out, it is for a 1950-3:
http://bissell.com/images/schematics/1950.pdf
Posted on Jan 31, 2008
Instruction to put it together
Bissell has the assembly instructions in the manual for the unit. Most Bissell manuals are available here: http://www.bissell.com/user-guides/ . The direct link to the manual for 1950 series Quick Steamer is http://www.bissell.com/user-guides/DownloadAsset.aspx?id=567 .
I hope this helps. Out of the box, the assembly is very simple. Put the handle on the lower body and secure with a Philips screw. The water tanks lift off and then get placed back on the body of the unit. (Use care when the tanks are filled with water.) See the manual for adding the bare floor tool.
Oct 15, 2015 | Bissell 1950-3 Quicksteamer Plus Vacuum
My bissell quicksteamer makes a high pitch squeal
Something is caught in your beater bar , causing preasure on another part of machine. This contact is the cause of the noise. GOOD LUCK FRIEND.
Sep 16, 2014 | Vacuums
Bissell quicksteamer 1950 motor
take bottom apart see if belt broke if bad check motor shaft see if it spins
Jul 31, 2017 | Bissell 1960-3 QuickSteamer Plus Upright...
Manual for Bissell quicksteamer.
Hello, this is Ava with Think Crucial.
You may find the User's Manual for your Bissell model by clicking the link below.
Bissell QUICKSTEAMER 1950 User Manual
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Bissell
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Mar 19, 2012 | Vacuums
I have a Bissell Quicksteamer plus model # 1950 and when I plug it in it begins to heat the water then trips the circuit. Can this issue be corrected?
Have you cleaned the tanks recently? If not do it.
Remove water from the solution tank and collection tank.
Keep the tanks open and allow to dry in sunlight.
If you can, remove the solution tank and see whether there are any leakage signs where the tube connects to the solution tank. If there are, use an adhesive that can withstand heat and stops the leak.
You can also contact Bissell consumer service on 1-800-237-7691.
Aug 07, 2011 | Bissell 1960-3 QuickSteamer Plus Upright...
Need to download PDF format Parts Manual for Bissell 1950-3 Quicksteamer plus -- is there one available?
BISSELL User's Guides can be downloaded at www.bissell.com
On the front page under Customer Service click on User's Guides and enter the model number of your unit.
User Guide will be displayed as a PDF file.
Sep 19, 2010 | Bissell 1950-3 Quicksteamer Plus Vacuum
Where can i order a quicksteamer plus 1950 clean water tank?
I had a look at the Australian variant of this model and located parts number 407-0931 Clean Water Tank.
My best suggestion is that take this part number and contact your local Bissell Service Center, go to the Bissell International website to locate information for your country.
May 26, 2010 | Bissell 1950-3 Quicksteamer Plus Vacuum
Cleaning
Either you have a pinched or clogged water line, or the rod in the handle is pushing down like it should. The drw back is Bissell has deemed this unit and its parts obsolete. So any parts are hard to find.
Nov 04, 2007 | Bissell 1950-3 Quicksteamer Plus Vacuum
Bissell Powersteamer 1694 Upright Vacuum Logo
768 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
