Question about Fellowes Powershred P-45C Shredder
Have to turn off manually
Shredder does not turn off when shredding complete. have to turn off manually.
  • terrij Mar 20, 2008
    have cleaned the sensor to no avail. guess I have to buy a new one?
  • 168 Answers
Either there is a piece of paper that is jammed where the paper in sensor is located, or there is paper fibers covering the paper in sensor, or the paper in sensor is defective.
The paper in sensor is usually located in the center of the shredder where you place your paper. Once you locate your sensor, you can try blowing it out with a can of air that is used to clean your keyboard out.
Since the opening for the paper or the Thoat width is 9", the switch should be close to 4.5" towards the center.
To try to help you located the sensor, take a piece of 8 1/2 " x 11 paper and fold it in 1/2 Long ways. This will place a crease in the middle of the paper. With the power off, or unplugged, place the paper in the shredder and look around where the middle of the paper (crease) lines up in the shredder. You might need a flashlight to help you located it. It will either look like a slot, or a little black lever.
Hopefully you will be able to blow the sensor out and clean it.
Good luck.
Posted on Feb 06, 2008
  • 3 Answers
There is not a manual sensor on the P-45c. There is a electronic sensor on the P-45c
Posted on May 09, 2008
SOURCE: Won't shut off after shredding.
I FIXED MINE!!! Hey folks same problem AS1018CD would not shut off. CURE: Take apart and clean electronic eye. PROCEDURE: 1. Unplug. 2.  Remove shredder and turn upside down. 3. Remove 6 phillips head screws on back of unit ( 1 is under sticker in middle peel back sticker to access screw. 4. Carefully separate unit. 5. Pull off shredder piece. It is a snug rubber grommet fit and just lifts off( gears everything comes off as one piece. 6. Electric Eye is exposed remove screw holding in and gently slide out and wipe clean. Do both sides. While apart clear all debris and wipe entire unit as clean as you can. Put gear assembly back on grommets. Put top and bottom back together. Replace screws. Plug in. FIXED :-)
Posted on Jul 11, 2008
  • 18 Answers
SOURCE: My shredder stop shredding. has paper caught in itposted
If your equipment makes abnormal noise when you try to switch on again then gear problem is confirmed else the change over switch should be defective or there may be a open circuit in the change over switch connection I shall advice you to call the service engineer for fixing the problem else take safty pecaution to attempt repairs
Posted on Sep 02, 2007
Shredder drive gear is probably shredded - hard part to find or replace usually. Could mean a new shredder;-(
Posted on Sep 08, 2007
  • 35 Answers
SOURCE: intimus 600 shredder
The plastic reverse pushbutton over the soft touch keypad is broken/stuck in or down causing this problem. A new pushbutton cover is needed. How are the Forward and Stop buttons?
Posted on Feb 23, 2009
FixinFax
  • 3085 Answers
SOURCE: Staples SPL-X21G shredder won't turn off
Blow canned air down into the feed slot.
Posted on Sep 22, 2009
I have read the instructions on how to remove a jam in my shredder and have repeated these steps over and over. It still says "Anti jam". What do I do?
You will have to get access to the shredding mechanism. If your shredder has a removable bin, remove it and turn the shredder upside down. With power disconnected, remove all bits and pieces of paper you can find. I have used tweezers, a utility knife and other tools to complete this tedious process, especially where coated stock or plastic has been shredded. When finished, and exhausted, turn the shredder upright and insert the bin to close the interlock. Connect power and check operation.
Aug 19, 2016 | Shredder Office Equipment & Supplies
Why doesn't forward shredding work?
  • The jam was not cleared completely
  • The shredding mechanism was damaged in the process of clearing he jam
Nov 28, 2015 | Royal 150MX Cross-Cut Shredder
My shredder worked fine but now when I turn on it does not stop running and does not shred paper ?
Most shredders will have a shred and a reverse setting. Is it running in reverse? Has the bin been emptied? With the power off, you can remove the bin and manually pull excess shredded paper jammed in the cutting heads -watch out, sharp metal . Once cleared run single sheets for the first minute to help clear rollers.
Jan 05, 2015 | Shredder Office Equipment & Supplies
Omnitech 10 sheet shredder keeps running constantly after a page or pages have been completely shredded. I have to stop it and start it manually.
Shredders have to be cleaned periodically to remove bits of paper that may be blocking the sensor that detects when paper has been inserted. If you turn the shredder mechanism upside down, you can see the bits of paper and, with power off, you can pick them out. I find tweezers are a useful tool for this
Dec 13, 2012 | Omnitech 10-Sheet Micro-Cut Shredder
Need owners manual for B&D paper shredder Model BD-10P. i have a jam
Hi and welcome to FixYa, I am Kelly.
The manual is little help but you can find it here:
http://media.homedics.com/IBs/bds/BD-10P_IB.pdf
Troubleshooting
If you have a problem with your shredder, check the symptoms and remedies below.
If you cannot solve the problem this way, contact Black & Decker paper shredders
Customer Service.
Do not open shredder head to attempt repair: It could expose
you to electric shock and will void your warranty.
- Check to see if bin is full. If bin is full, empty bin and
replace. Follow instructions under maintenance.
- Oil cutting cylinders.
Shredder squeaks, grinds or runs
below capacity.
- No action required. This is a self-Shredder continues to run for cleaning function.
1 or 2 seconds after shredding
has been completed.
Symptom Remedy
- Make sure shredder is plugged in.
- Make sure power switch is in "Auto" position.
- Make sure bin is fully closed.
- Check to see if either bin is overfull which could result
in a jam. If so, empty.
- If you are unable to clear the jam, turn off and unplug
the shredder. Slowly and carefully pull the remaining
paper out. Forcefully removing the paper is likely to
cause irreparable damage to the shredder.
Shredder does not start or stops
while shredding.
Paper jams.
HOW TO GET SERVICE:
Visit our website at www.blackanddeckershredders.com or call the toll free customer
service line at 1-800-297-5028.
® SKU #BD-10P
Product Information
This product is designed to shred paper, staples, small paper clips, credit cards, CDs and DVDs.
It is not intended to shred large paper clips, continuous forms, adhesive labels, transparencies,
newspaper, cardboard or any other plastic other than credit cards. Using it for these purposes
is likely to cause irreparable damage. Please do not attempt to shred more than 10 sheets/1 CD
or DVD at a time. Shredder should not run more than 200 sheets/50 disks continuously. Items
should be centered and unit will begin and end shredding automatically. All disks should use
specific entry as noted on your shredder.
Maintenance
It is important to empty the waste bin regularly to ensure the smooth operation of the
cutting cylinders. The shredder will not operate when the bin is full. Regular oiling
is also necessary for proper performance. It is recommended to use the shredder oil
every few weeks.
Maximum running time: 3 minutes
Automatic cool-down period: 30 minutes
Voltage: 120
If you have any questions regarding the product, please feel free to
call toll-free 1-800-297-5028
Thanks for Choosing FixYa,
Kelly
Apr 07, 2011 | Black & Decker Garden
Sep 22, 2009 | Office Equipment & Supplies
ROYAL RL170MX Shredder won't shred
Did you ever put shredder oil onto the cutting blades?????
The blades can clog with paper dust and then it can't shred as many papges as it should or even jam completely...you should occasionally shred a sheet of paper with shredder oil poured onto the sheet.
Aug 11, 2009 | Royal 1280MX Shredder
Shredder continues to run after page is shredded, must be manually switched off.
there is a sensor that detects paper in front of it to turn on the shredder mech. it is probably covered with paper dust so the machine constantly thinks there is paper being shredded. give it a clean with a qtip moistened with isopropyl alcohol - make sure the shredder is unplugged first.
Jun 20, 2009 | Fellowes Powershred P-45C Shredder
Overly loud shredding; stops prematurely
I have taken many shredders apart and found them so clogged up with shreds of paper and too much oil will turn into paper mud.Be bold and take the top off and clean it out. Unplug the power source and when removing the top , be careful because their will be a short cable connecting the top to the circuit board. Easy to damage.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
May 12, 2009 | Fellowes S701CM Shredder
Fellowes Powershred P-45C Shredder Logo
615 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
