Question about Intel Dot Station (INTC300AIO) PC Desktop
KEYBOARD HOW TO RIGHT CLICK IN THE MOUSE?
    Champion:
  • 207 Answers
Do you see windows button? use the arrow sign button between the windows button and CTRL button.. that's it!!!
Posted on Jan 29, 2008
Suppose the numeric keypad of a keyboard is not functioning correctly, and when a numeric key is pressed, the keyboard redirects the cursor. Provided that the keyboard is not faulty, which of the foll
what os youre using ?
if windows os then maybe the mouse keys on Accessibility feature was turned on
how to check it on windows 8 :
1.Swipe in from the right edge of the screen, and then tap Search. (If you're using a mouse, point to the upper-right corner of the screen, move the mouse pointer down, and then click Search.)
2.Tap or click Settings.
3.In the search box, enter Change how your mouse works, and then tap or click Change how your mouse works.
4.Under Control the mouse with the keyboard, check the Turn on Mouse Keys check box, if selected then deselect it and then click OK.
On Windows 7 :
1. goto start -> control panel -> ease of access center
2. click on use make mouse easier to use
3. check the turn on mouse keys check box, if it checked then deselect it
4. clik ok
Sep 20, 2014 | Computers & Internet
TOUCHPAD MOUSE ANS KEYBOARD NOT WORKING
Try these steps.. Click start button, type "mouse" on Search Programs and Files, click "mouse" under control panel. In mouse properties options....as you an see the touch pad driver tab? click it. Choose or click option button and you can enable the right and left click button. About the keyboard problem,,,,,go to device manager, right click the standard PS/2 keyboard..uninstall it. Windows restarting and the keyboard driver will re install automatically.. check if the keyboard works fine.
Aug 17, 2014 | Acer Aspire 3810T 4810T 5810T
Mouse and keyboard
It sounds like someone is playing a prank on you, but normally it is easily fixed.
Open your control panel and here you can find Keyboard and Mouse. In those two, you can change the permanent settings for your mouse and keyboard.
Jul 02, 2014 | ASUS M3000N Notebook
Windows XP Professional, can't log in, try to type
Which model of laptop ?
Nearly every device in your computer system can be turned off and on by accessing the Windows Device Manager with a few clicks of the mouse. It gives you plenty of flexibility and allows you to customize your computer on a whim. The Device Manager will allow you to enable your factory keyboard and mouse and disable your current ones, effectively resetting them to the default settings
Make sure that your default mouse and keyboard are plugged into your computer. Click on the Windows "Start" button in the lower right corner of your desktop. Type "Device Manager" in the "Start Search" box. Click "Device Manager" under "Programs." Click "Continue" if the Windows permission window pops up. Click the "+" next to "Mice and other pointing devices." Right-click the default mouse and click "Enable." Switch to your default mouse then right-click your other mouse and click "Disable." Click "Yes" in the warning popup window. Unplug the other mouse. Press the "+" next to "Keyboards." Right-click your default keyboard and click "Properties." Click the "Driver" tab then click "Enable." Click "OK." Right-click your other keyboard and select "Properties." Click the driver tab then click "Disable." Click "Yes" in the permission window then click "OK." Your computer is reset to the default keyboard and mouse.
Jan 30, 2013 | Computers & Internet
ASUS 9039URF 111 keyboard manual or how to install, I followed the 10 second par instructions to the wireless device that controls the mouse and keyboard and nothing works, I also replaced batteries in...
you might have to uninstall the mouse and its drivers then restart your computer then reinstall the mouse and its drivers
click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question mark? right update driver
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you have options to troubleshoot also you can select properties under driver you will have the options update driver,rollback driver or uninstall in xp
click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question mark? right update driver in
make sure the battery is good ((has full charge))also you might test the usb device for the mouse is inserted correctly into the usb port (if applicable)
Windows 7 all of these will apply for the keyboard as well
hope this helps
May 04, 2011 | Computers & Internet
Just bought this wireless keyboard and mouse...the shift button does not work
if you can provide more information about the keyboard make and whether you have installed the drivers or not.
Solution :
1. Right click on MY Computer or Computer and click on properties
2. Click on Device Manager ( Hardware )
3. from the list, click on + sign on keyboard
4. check if the keyboard name is listed / also check if there is no yellow exclamatory mark in the list as unknown device.
5. right click on the keyboard name ( wireless ) and click uninstall
6. Reboot the PC ( With the keyboard CD Driver disk in CD ROM )
7. Continue with the New Hardware found Screen to re-install the drivers for Wireless Keyboard / Mouse
Jun 16, 2010 | Rosewill (RKM800BLK) (AKMA8C35IBLACK)...
Dell wireless mouse and keyboard installation problem
click start
right click my computer
properties
hardware
device manager
?mouse and keyboard
scan for hardware changes
Aug 23, 2008 | Dell Wireless Keyboard Optical Mouse w0147
Logitech cordless desktop
  1. right click on my computer
  2. click on properties
  3. click on hardware
  4. click on device manager
  5. click on mic & other pointing device
  6. click on(+)
  7. then right click mouse
  8. click on update driver
  9. select second option in window(advanced)
  10. then click on( search removable.......)
  11. then insert driver cd in cd rom
  12. And click on Next option
If you have done this than do this
  1. select third option(Don't search.I will...............)
  2. And click Next option
  3. click Next option in next window.Thats it
Hope this solution works
Mar 24, 2008 | Computers & Internet
Wireless keyboard problems
  6. click on(+)
If you have done this then do this
  1. if it is not work then do above procss and select third option(Don't search.I will...............)
Mar 11, 2008 | Logitech 967461-0403-PK Keyboard/Mouse
Cant get my mouse to work
How to fix it:
Start, My Computer right click, got to properties, Device Manager find the Keyboard and Mouse click one, insert disc that came with the mx 3200, double click on keyboard on, reinstall drivers, then click yes this time only, next windows click the advance box. it is the bottom one of the two. the next window should ask if you want the computer to select the best driver or if you want to search yourself. select search myself there should be about 4 different drivers select the one that has (106 keys). should be working. follow similar steps for mouse there will be about four different drivers for the mouse just pick one if it isn't the right one you will get an error try the next one, it will be one of the four etc. also have you connected them to the usb receiver.
Dec 28, 2007 | Logitech Cordless Desktop MX3200 Laser...
Intel Dot Station (INTC300AIO) PC Desktop Logo
37 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
