Question about Ricoh Aficio CL3500N Laser Printer
White stripes through sentences
We replaced the drum kit already, but when we print there are still white stripes going through the sentences.
    Problem Solver:
  • 10 Answers
Try to identify the location of the laser slit glass (will be pointing directly at drum) make sure it is clean.
Posted on Feb 06, 2008
HP color laserjet CP 1510 printing stripes on the left
Is this for all colors or just one color? There are three color toner cartridges plus a black cartridge.
Mar 09, 2015 | HP CC378A Color LaserJet CP1518ni...
I'm getting a line that isn't printing through my printing from a Fuji Xerox DocuPrint C3055 DX
Possible reasons are: 1.empty toner cartridge, 2.dirt under one of the toner cartridge's developing roller, 3. dirt on the primary charge roller in the drum cartridge, 4. obstacle on the laser path.
Replace the empty toners first and try printing again. Follow the next steps if it didn't solve the problem.
Print a test page with 4 stripes across the page - black, cyan, yellow and magenta. See if all have the missing toner line or only one of them. If the white stripe is going trough only one color, inspect the cartridge with that color. It has to have the same stripe on the developing roller. See if there is some dust beneath it that makes the stripe and clean it with a brush. If the stripe is across all colors, then inspect the drum unit. The drum itself has to be evenly shining on the light. If there are uneven matte tracks on it, consider replacing. There should be a gap somewhere for the laser beam to pass and the drum is visible trough it. Look trough it for obstacles like piece of paper or hair. The primary charge roller has to be close to that gap inside, touching the drum. Look for dirt on it. Clean if possible.
Toner cartridges last approx. 6500 pages. The drum cartridge lasts between 14 000 and 28 000 pages depending on the color use.
Jul 02, 2014 | Digital Products Office Equipment &...
Want to attach a harbor breeze light kit to an existing hunter fan. switch housing has 3 white wires hooked together with a blue connector cap and a single black and white wire(labeled for light). there...
White to white ( single white ) & blue from light kit to Black with white stripe. Also make sure the black with white stripe coming out of TOP of fan is connected to the hot wire.
Aug 26, 2013 | Hunter 52" Ceiling Fan With Light And...
C2801 bizhub 750
Sir/Mam,
There is a sensor that monitor the drum some times it gets cover with toner and can not do its job of monitoring the drum which it has to do before copying/printing Sometimes you may also get "please wait" same problem. Have to remove the drum assy. Two bolts and center bolt. Then pull out assy. BE CAREFUL DONT NIC THE DRUM!!!! Then you remove the drum and clean the sensor. (Two sensors the white covered one, clear one is for paper jams) When was the last time a 250,000 copy Preventive maintenance kit was installed? and Drum replaced at 500,000 developer also replaced at 250,000 copies/prints. every 250K PM kit install.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
May 10, 2013 | Konica Minolta Konica 600/750 Mount Kit...
There is a white stripe (miising writing) in the middle and in the left side of the printed paper. i have changed the toner, but the problem doesnt solve. maybe its the laser motor dirty? thnx for any help
Problem : white stripe (missing writing) in the middle and in the left side of the printed paper
Printer Laser Printer MF5650
Cause of the problem Dust
Solution Cleaning ..
There could be reasons for your problem
1) The TONER CARTRIDGE not clean - i think you replaced it
2) The Imaging Drum
3) Beam Alignment Lance (glass which reflect the rays)
1) there are toner and the drum
2) take out the Toner cartridge
3) there is a black roller on Toner Unit - clean it with the Cotton
4) Take out the Drum clean it (Don not use water or spirit to clean it )
5) Fuser Unit a Hot Unit the Red Color Roller no need to clean ..
Following Video will show you the over view of the Product
Video 1 use full video help you to understand the whole process
Jan 03, 2010 | Canon LaserBase MF5650 All-In-One Printer
The Print has white stripes
White stripes are caused by dust and toner powder on the scanner window, which is situated in the bottom of the printer, under the drum unit. Open the printer, remove the drum unit and using a soft cloth with a little meths wipe the window clean of toner and dust. It's quite dark inside the printer, so use a torch to find the glass panel (only about 10mm deep x the width of the drum).
Jun 24, 2009 | Brother MFC 9180 All-In-One Laser Printer
Black stripe and white stripe on copies
Black stripes can be down to dirty optics, unplug the copier and remove the glass, then clean all mirrors and the glass itself. If this does not resolve the problem, it will be the drum cleaning blade that has worn and will nedd replaceing.
Feb 16, 2009 | Sharp AL 1631 Copier
Magicolor 2430 DL vertical white blank stripes
remove PC drum and under that you can see laser glass, clean it and reinstall.
Aug 28, 2008 | Konica Minolta magicolor 2430 DL Laser...
Blank vertical stripes on incoming faxes
1st. Print a report. If the blank stripes are still there, you must remove the drum and t6oner combination and clean the laser glass located on the bottom of the machine.
If the blank stripes do not appear, then the fault is on the scanner of the sending fax machine.
Feb 25, 2008 | Brother IntelliFAX 2800 Laser Fax
Ricoh Aficio CL3500N Laser Printer Logo
147 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
