Question about HP Photosmart C4280 Aio Printer
HP Photosmart C4280
I changed the balck ink cartridge. I got a message to align. to do that I had to print an alignment page which only came out blue and not multicolored, like it is supposed to be. Nevertheless, I used this to align and message on printer said alignment page not detected? What do I do? How do I get a multicolored alignment page?
  • 2 more comments
  • pachanga Feb 17, 2008
    After I installed my printer, I got a message to align To do that I had to print an alignment page
  • Anonymous Jul 28, 2008
    I changed cartriges which then printed more colors and then it allinged sucessesfully
  • desonfed Jul 30, 2008
    I got the message to align after installing a new printer. It said to put in the last page printed and press ok. I did all that and nothing happens and now when I try to print a page, it comes out like I have a half empty cartridge.
    Help?
    Diane
  • jessicagrey Jan 13, 2009
    I scan the alignment sheet but when it says press ok, there is no "ok" on the printers little screen. So i press "done" on the computer screen, because the scan is showing up, and the thing keeps telling me to align over and over.
Printer is the HP Photosmart C5550 , bought from Costco June of 2009. was/am getting BSOD with random error codes, usually a letter like 'B' followed by a dozen or so numbers. so far have had to pull power while still on, turn off and on at its power button many times in many combinations.
When it does come back it is locked into 'Align Cartridges' mode and won't respond to cancel, menu, back key or anyting other than OK, which leads it to draw in paper, then spit it out and request 'plain white paper', which is what's it's loaded with.
This time the only thing that broke the cycle was to remove the (fresh, new) cartridges and put them back in.
It's printing now, but my faith in it and HP consumer inkjet printers is shot.
Hope this helps someone.
Posted on Nov 10, 2011
    Genius:
  • 3,587 Answers
Hmmmm...assuming that the cartridge is installed properly, yes? seems that your black ink cartridge may need to go through a 'clean' process, prior to alignment(sure wish that the replacement folks would insist on cleaning out the old heads, before doing an alignment. It's like changing the oil on your car, but using the old filter. Same gunk still in the system.
Posted on Feb 06, 2008
I finally got mine to run through the following process:
Pulled back out the black cartridge I had replaced and put it back in
Pulled out the color cartridge and put back in.
CLosed the cover and was prompted to print alignment page.
Placed alignment page on glass with 4 blocks to the left (as depicted on alignmnet sheet)
Press Okay to start alignment
Alignment was FINALLY succesful.
If I were to put anything on this troubleshooting, it was pulling BOTH cartridges back out and resetting them
Posted on Apr 02, 2009
HP Photosmart C4280 All-in-One printer, printing in only black blue and weird pinky red
Replace color ink cartridge ,black cartridge is not required because of black prints are ok..
Sep 04, 2012 | HP Photosmart C4280 All-in-One InkJet...
H P Photo smart C4280 Will not print color/; Prt cartridge just replaced
After replacing the cartridges, printer performs align print are you check this page? any color print in that? If you found colors in align page, no problem with printer.> check print command in color or not.. > If no color print in align page, perform clean cartridges > check with another cartridge.> check trailing cable,carriage PCB & Formatter..
Dec 06, 2011 | HP Photosmart C4280 All-in-One InkJet...
Prints alignment page everytime turned on
Did you follow the alignment procedure after changing the ink cartridge? If not complete the alignment.
May 15, 2009 | HP Photosmart C3150 Printer
How do I install ink cartridge for hp photosmart C4280
To replace the print cartridges
1. Make sure the HP All-in-One is on.
CAUTION: If the HP All-in-One is off when you open the print cartridge door to
access the print cartridges, the HP All-in-One will not release the cartridges for
changing. You might damage the HP All-in-One if the print cartridges are not
docked safely when you try to remove them.
2. Make sure you have letter or A4 unused plain white paper loaded in the input tray.
3. Open the print cartridge door.
The print carriage moves to the far right side of the HP All-in-One.
4. Wait until the print carriage is idle and silent, and then lightly press down on a print
cartridge to release it.
If you are replacing the tri-color print cartridge, remove the print cartridge from the
slot on the left.
If you are replacing the black or photo print cartridge, remove the print cartridge from
the slot on the right.
1 Print cartridge slot for the tri-color print cartridge
2 Print cartridge slot for the black and photo print cartridges
5. Pull the print cartridge toward you out of its slot.
6. If you are removing the black print cartridge in order to install the photo print cartridge,store the black print cartridge in the print cartridge protector or an airtight plastic container.
7. Remove the new print cartridge from its packaging and, being careful to touch only
the black plastic, gently remove the plastic tape by using the pink pull tab.
1 Copper-colored contacts
2 Plastic tape with pink pull tab (must be removed before installing)
3 Ink nozzles under tape
CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching
these parts can result in clogs, ink failure, and bad electrical connections.
8. Slide the new print cartridge forward into the empty slot. Then gently push the upper
part of the print cartridge forward until it clicks into the socket.
If you are installing the tri-color print cartridge, slide it into the left slot.
If you are installing a black or photo print cartridge, slide it into the right slot.
Work with print cartridges 69
Maintain the HP All-in-One
9. Close the print cartridge door.
If you installed a new print cartridge, the HP All-in-One prints a print cartridge
alignment page.
10. When prompted, ensure plain white paper is loaded in the input tray, then press the
button next to OK.
NOTE: If you have colored paper loaded in the input tray when you align the print
cartridges, the alignment will fail. Load unused plain white paper into the input
tray, and then try the alignment again.
11. Place the page print side down on the scanner glass and then press the button next
to OK to scan the page.
When the On
Please Don't forget to rate this solution. Thanks.
Feb 17, 2009 | HP Photosmart C4280 Aio Printer
Dell 922 printer alignment problem-
try this...
Aligning Ink Cartridges Your printer automatically aligns the ink cartridges when they are installed or replaced. To verify your ink cartridges are aligned, you can print an alignment page. After you close the printer unit, press the Menu button. The alignment page begins printing. During printing, the operator panel display reads Alignment Page Printing. When complete, the message reads Auto Alignment Complete. Your ink cartridges are now aligned for optimal print quality.
You may also need to align ink cartridges when characters are not properly formed or are not aligned at the left margin, or when vertical or straight lines appear wavy.
To align the ink cartridges:
  1. Load plain paper. For more information, see Loading Paper.
  2. Click Start® Programs or All Programs® Dell Printers® Dell Photo AIO Printer 922® Dell Printer Solution Center.
  3. Click the Maintenance tab
  4. Click Align to fix blurry edges.
  5. Click Print.
The ink cartridges align when the page prints.
If this helps you plz rate this fixya. Thank you kindly. If you need more help post it & I'll be glad to do what I can.
Feb 01, 2009 | Epson Printer
This printer is saying that print cartridges missing, they are both brand new. HP Photosmart C4280 all in one. what to do.
Be sure to run the print test page after installing cartridges.  After doing so, place the page face down on the scanner and select cartridge alignment.
gary.schaut@gmail.com
Jan 06, 2009 | HP Photosmart C4280 Aio Printer
Printer says 'cartridges missing or not detected'
Did you run the print sample page used to align the print cartridges by scanning the test page?
Jan 05, 2009 | HP Photosmart C4280 Aio Printer
HP Photosmart C4280 All-in-One Printer: when setting up printer it printed the alignment page okay put it on glass upside down right hand corner pressed ok message comes up Alignment Page not detected....
The reason is that your colour cartridge has run out of ink. You need to replace your colour cartridge as well and try the alignment process again.
Aug 18, 2008 | Office Equipment & Supplies
HP Photosmart C4280 Aio Printer Logo
2,903 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
