The defrost heater is located on the evaporator coil (located in the freezer compartment) and is designed to melt the frost from the coils. If there is power getting to the heater and it will not get hot, the defrost heater is most likely faulty. It should have a resistance of 20-50 ohms in most cases. Part number=> WR51X10042
Can be also purchased here=> Appliance Part Southeast
The defrost thermostat is designed to turn the power off to the defrost heater once the coils are clear of frost. It is a temperature actuated switch and once the coils are clear, the thermostat will open and the heater will be turned off. If the thermostat does not reset once it gets below freezing, it is most likely defective. Part number=> WR50X10054
Can also be purchased here=> Appliance Parts Southeast You may contact me here at Fixya or Appliance 911 or through my website SEA BREEZE APPLIANCE PARTS AND TECHNICAL SERVICES Thanks,and if you have questions or need help please let me know, Sea Breeze
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
heatman101
