Hard drive collapse
I have a La Cie 160 gb external hard drive which I have been using as a back-up. Suddenly it won't light, nor will its icon appear on the desktop.
T 6552LL/A I take it is a model-number? The serial number is: 134103894.
Is there any way to resuscitate this unit? I hate the idea of losing all the files that are on it. Is there any way to recover the files if the product cannot be repaired? My email address is:
djkoury17@comcast.net
Thank you.
    Genius:
  • 3,422 Answers
try this:
1.From the Finder contextual menu, on the Finder Menu Bar, select Preferences.
In the window that opens, click on General.
Under Show these items on the Desktop:, make sure that Hard disks is checked
2.In the Finder Preferences, try de-selecting then re-selecting the Hard Disks box to leave it in the on state.
If that does not make it reappear, then try a Restart.
Goodluck,
Dont forget to rate me as fixya.
Posted on Jan 29, 2008
  • Priya darshan Jan 29, 2008
    to recover ur data from extrnal hard disk drive watch this video
    Sergeant:
    Champion:
  • 226 Answers
Try to pull out the hard drive from the casing and replce it with a standard casing which you can purchase it in the market. once you pull out the hard drive try to check if there is a connetion that hasbeen disconnected. try to put it back.
    Novelist:
    Scholar:
  • 117 Answers
The most likely cause if it has an external power supply is that the supply has stopped working. If it hasn't got one or if testing the PSU shows that it's still working then it's likely that the electronics in the box have packed up. If that's the case, then you can remove the drive from the box and try connecting it directly to a computer using a spare IDE or SATA connector. If doing that shows that the drive is still OK, then simply buy another external box and put the drive in that.
    Master:
  • 788 Answers
I would first check that the AC Adapter is providing power to the drive with a multimeter, if not then get a universal adapter and set it to the same output voltage. If the adapter is giving power then I would also try the drive on another computer, if it works then you might have a usb driver issue on your computer.
If none of that works then your best bet is to open the LaCie up and remove it's hard disk. You could then connect the disk as a secondary disk in any computer and read the files. It might be that the controller board in the external enclosure is faulty but the drive is still good. If this works then you can get a new external enclosure without a disk for faily cheap these days and put the drive into it, or leave it in your computer.
    Champion:
  • 207 Answers
I strongly recommend you to go on this website: http://www.drivecrash.com/lacie_data_recovery.php
they can help you badly about that.
My external La Cie 500Gig HDD has worked well for 3 years or more. Now when I connect it (via USB as aI have always done) ..The following happens: 1 I see the drive usually but not always under "My...
your drive has failed at either the power supply level or internal hard drive level.
First, please verify your power supply. When plugged into the power outlet, it should be silent. A defective power supply will hiss or have a high pitch noise to it. If it is defective, replace it and check if the issue is resolved.
If the power supply is silent, one or both of the internal hard drive is failing. If no data is needed, you can either replace the defective one which you will have to isolate by connecting the internal hard drives to a computer or with another enclosure and running a block scan software like hdTune which is free to download. The other option would be to scavenge the healthy drive and use it in another enclosure or inside the computer directly.
If you need the data and the problem was not the power supply, you will need to contact a data recovery center.
Regards,
Jan 07, 2011 | LaCie Big Disk 500 GB Hard Drive
250 GB La Cie desktop Quadra drive will not mount and makes a soft clicking noise; does not show up on System viewer, only as 'unknown device' Mac Pro OS X 10.5.6 Have tried to swap out firewire cables,...
Hello
At the link below you will be directed to a tip i wrote on this exact issue. Click on the link below to navigate to page.
Click HERE.
Please feel free to let me know if you need any further assistance.
Thank you for using Fixya!!
Kind regards
Lock123
Sep 20, 2010 | LaCie (300770) 250 GB Hard Drive
La Cie (500 GB) icon not showing up on desktop
kcrosbie
If you are having trouble with the drive it is possible that the USB controller on the drive failed but the drive its self should be fine.
I would try the drive on another computer to see if it detects properly. Sometimes if the drive gets stopped improperly this can cause detection propblems but connecting it to another computer will force a scan of the drive that will repair any corrupted files that may be on the drive. Also check to see if the drive shows in disk management. The links below will show you how to check this.
How to change your drive letter in Windows Vista and Windows 7
How to change your drive letter in Windows XP
If the drive does not show up in disk management and the drive is not in warranty I would recommend opening the drive and connecting it directly to your computer to access the data.
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Jul 05, 2010 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
I have an old La Cie 160gb (maybe 5 years old?) - do you know the specs? rpm, for instance? I need something with 7200. This old one must be 5400, right?
Lacie drives have a 5400 RPM on there 160GB line nothing really changed until 500 GB to 1tB at 7200 RPM.
so the answer is 5400 RPM
Hope this helps please do rate and leave feedback.
Apr 29, 2010 | LaCie (300740) 160 GB Hard Drive
Blu light flashing
This is most probably a faulty power cable, a common fault on La Cie apparently. Another cable got my disk working fine!
Nov 12, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
How to recover data from a LaCie Porsche 160 GB Hard Drive that's not working?
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Sep 02, 2008 | LaCie Porsche Mobile 160GB HD 160 GB Hard...
La Cie External Hard Drive 160 gig
A clicking noise from a harddrive is defenenly NOT a good thing. It usually means that the harddrive is going bad.
Nov 17, 2007 | Computers & Internet
sounds like hd is getting hot via firewire try and use the usb lead if same problem then get your files off quick and repace drive any thing above 80 gig will get hot in use that's why I use harddrive coolers on my large 300gig 400gig internal and only use my 250 gigs and 160 gig only when i need the files off they are turned off all time
Jun 07, 2007 | LaCie (300740) 160 GB Hard Drive
Hard drive won't turn on
You could remove the drive if you can get the enclosure open and either install it in a new enclosure or as an additional HD inside your Pc. Good Luck.
Nov 17, 2006 | LaCie Big Disk (300872) 400 GB Hard Drive
Computers & Internet Logo
315 people viewed this question
David Payne
David Payne
