Question about Brother HL 5250DN Laser Printer
Brother 5250 I have had a problem with the 5250 feeding multiple sheets when printing. This seems to happen more when printing checks. I have separated the checks by hand but it is still a problem. Thanks for your help. Gene
  • 417 Answers
Are they going through the cassette or manual feed ? either one has a small rubber pad that separates each page from one another. clean this pad or tension the spring behind it but the best way is to replace it.
Thanks J
Posted on Jan 30, 2008
HP 2300 jams when duplexing multiple pages.
try to replace the pickup roller and sepration pad (if ther are old)
Mar 12, 2010 | HP Office Equipment & Supplies
Frequent Paper Jams in Brother HL-2140
Every 120,000 pages, the paper feed rollers, fuser, transfer roller, and OPC belt cartridge should be replaced, usually by a trained techncian.
Fuser and OPC belt units are customer-replacable.
The multiple feeding of the paper into the printer is due to a worn paper separation pad. part no. LM0711001. If the machine is picking up the paper okay and the jams occur solely from multiple sheet feeding, then this part is probably all you will need. The steps required to access and remove & replace the separation pad unfortunately is about 10 steps. Better consult a tech.
Oct 06, 2009 | Brother MFC-9420CN All-In-One Laser...
I have a Brother HL-5250, drum light on, not printing
When the drum light is on solid, it's time for a new drum, if you have a new drum, just open the front door and hold the go button til all lights flash and the drum is reset. Press the go button 3 times and it will print a sheet showing the drum status.
Sep 15, 2009 | Brother HL 5250DN Laser Printer
Miss feeds when print multilpe pages
The paper feed solenoid is sticking, it can be seen thru a hole in the back with the door opened. Not easy to get to, but I have been able to bend the stop tab slightly and run just fine.
Sep 02, 2009 | Konica Minolta magicolor 2300DL Laser...
'1) Lost' Black print 2) Can no longer scan more than one page
Lost Print solved by repeated cleaning. No solution to the single feed problem yet.
Jun 22, 2009 | Brother MFC-5440CN All-In-One InkJet...
Feeds multiple pages
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 26, 2009 | Brother MFC 6800 All-In-One Laser Printer
Multiple jams
I waited awhile to let the machine cool down (and me too!) Then I put in a fresh batch, being especially carefull to align everything. Since then it's worked fine. I did print out a cupla emails while I was chillin.
Jan 11, 2009 | Brother MultiFunction Center MFC-440CN...
Brother 5250 DN Paper Jams
You problem is actually in the pick-up roller and separation pad areas. the paper is delaying and not making it through to the next check point in the machine fast enough.
1st
Take it by your closest Brother Service Outlet. They're in the phonebook under "Computer Service & Repair". It's a cheap fix but requires parts.
2nd
Use good paper. Paying a little more for paper will save you a lot over time in repairs and premature toner and drum failures. Brother printers are really finicky about paper quality. Recommend "HP Office" brand paper as a minimum. It's a known good paper for general everyday printing and won't break the bank.
Jul 24, 2008 | Brother HL 5250DN Laser Printer
Pohot paper jamming in Brother DCP-115C printer
This is a common error of this printertype. Please use only paper of max. 220g. There is no problem reported with that.
Jan 14, 2007 | Brother DCP-110C All-In-One InkJet Printer
Brother HL 5250DN Laser Printer Logo
125 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
