WASHING MACHINE NOT SPINNING AT END OF CYCLE AND SOMETIMES REPEATS THE CYCLE.
HOOVER WASHING MACHINE
I have a Fridare washer and the spin cycle wont spin
Posted on Jan 07, 2009
    Champion:
  • 207 Answers
Check the turbine blades, maybe the wer'e loosen up. Try to refit that one.ok??
Posted on Jan 29, 2008
LG tromm washer is stuck at 22 minutes and just keeps washing and spinning
Sometimes the firmware or program in the microcontroller of the machine gets scrambled due to electrical spikes or fluorescent lamp frequencies in the vicinity of the machine.
Unplug the mains supply for about 10 to 20 minutes and retry, this will normally solve the problem as the firmware program resets itself.
Dec 14, 2015 | LG Washing Machines
Clothes still wet at end of cycle
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Feb 18, 2011 | Hoover Washing Machines
Drum hitting sides of machine in spinning cycle (unbalance)
It sounds like you may have to many clothes in it. Try to remove some or reposition them. Sometimes the clothes get pushed to one side of the drum during the spin cycle and all of the weight to one side is making it off balanced.
Dec 27, 2010 | Hoover Washing Machines
Hswf 147 hoover washing machine wont spin
Not spinning at all can sometimes be caused by a blocked filter or drain pipe. Does your machine spin if you turn the dial to the spin only setting? Ours has developed a fault whereby it won't spin at the end of a normal cycle, but if I turn the dial to 'off' then to 'spin only', it will spin.
Dec 11, 2010 | Hoover Washing Machines
The machine will not spinn, the washing is very wet when finnished washing
clothes are wet after spinning this is due to faulty Motor coupler. test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:If it's spinning when you lift the lid, the coupler is fine.If not then the coupler is broken.It has to be replaced;.This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely. ----------------------- If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn motor pulley or tub bearing. Replace the applicable component. Thanks.
Sep 16, 2010 | Hoover Nextra HNL 3166 Z Front Load Washer
Hoover AL 120 washing machine won't spin
i would check the motor carbons it could be your problem if it fills goes through the programme until the end but has motor action
Apr 12, 2010 | Hoover AL120 Front Load Washer
I have an lg washer wm2077cm and it goes off balance when the spinning cycle starts and the stops.
Sometimes if the heavy bed spreads or curtain may cause this problem. Switch OFF machine manually and restart after the spin stops.
If problem repeats.
Check springs or shock obsorber inside the machine. The tub will be suspended with this.
Mar 30, 2010 | LG WM2688HWM TROMM SteamWasher
Washing machine
Here is what I suggested to another person with a similar request......
Not knowing what model machine you have, I would hazard a guess and say it is your break solenoid or break arm or a variation on a break system.
After the spin cycle, the break solenoid or break motor engages a break arm to stop and lock your spinning drum. The loud clunk is normal especially in Simpson and Hoover top load machines.
You can check this by putting the machine on a spin cycle. Once the machine gets up to speed, open the door. You will hear the clunck and then the drum stops abrublty. When you close the lid again, you will hear the solenoid release the drum, and then the motor starts spinning the drum again.
If that is the case, it is normal and no need to worry about it. However, if you did not have the noise before, then best to get a repairer to check it out.
Regards
Ash
Nov 08, 2009 | Washing Machines
How do I set the washing machine to spin only on a Hoover Nextra HNL662?
Adjust the timer to the end of any cycle. The pressure switch will recognize the water presence, and drain before spinning.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 05, 2009 | Washing Machines
Hoover 1300 spin 5+5 washer dryer
you don't say which cycle it will start on. however, could be cold valve open circuit which also means no rinse or cold inlet hose kinked etc. can you give more info?
Apr 09, 2007 | Hoover H120M Front Load Washer / Dryer
Washing Machines Logo
244 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
