Question about Xerox Phaser 8550DP Printer
Garbled text phaser 8550DP is printing garbled text instead of the pictures I need
  • tech teacher
    tech teacher Jan 30, 2008
    Thank you.. I restarted the printer and it worked well. I had been trying to print a picture from my kodak camera's software.
    President:
  • 2,072 Answers
Did you just install it ? Sounds like a driver issue.
The only other thing I have seen cause that is software corruption.You can do a NVRAM reset from the screen.
But I would try restarting the machine first. Then go to the Xerox.com site and download a new driver before resetting the NVRAM memory.
It sounds like either the program you are trying to print from of the driver is the issue.
I bet you are printing out code.
Posted on Jan 29, 2008
  • Rick Kasper Jan 30, 2008
    Ok sounds like the software just was corrupted.
    Good job
How can i avoid label sheets getting stuck in phaser 8560
1. Make sure you are feeding the labels from the bypass tray, not from the cassette.-
2. Make sure the labels are for Laser printers, not Inkjet printers.
3. Do not try and re-use a label sheet that only was half printed on.
4. When you put the labels in the bypass tray, set the paper type to labels...this slows down the print process so they won't get jammed.
Jun 02, 2014 | Xerox Phaser 8550DP Printer
Xerox Phaser 8550DP printing duplex
are you not able to get even the print menu?
Jul 22, 2008 | Xerox Phaser 8550DP Printer
Black not printing correctly. It prints yellow and green
check the black cartridge, it may be out. If it is ok, print a test page to see it will print black. If it does not print black, there may be toner spill blocking the black toner sensor.
Dec 06, 2010 | Xerox Phaser 8550DP Printer
Printer all of a sudden stopped printing, (LED screen out so unable to read errors). Everything was working fine and then it just stopped printing any more jobs, the red light was on the control panel and...
The inverted, blank, or garbled display is pretty common, a new control panel will fix that and is super easy to install and no tools required. Here is a video that shows how.">
Jul 04, 2010 | Xerox Phaser 8550DP Printer
Installation of Phaser 8550 DP on network
This is no problem for someone with even a little networking knowledge, but it would take longer to write the instructions here, than it would to have someone spend less than an hour configuring it on site. That's my recommendation
May 19, 2009 | Xerox Phaser 8550DP Printer
Xerox phaser 8550 prints garbled characters
This happens to mine occasionally after I have put it into standby a few times. If I reboot this always sorts it out.
Apr 05, 2009 | Xerox Phaser 8550DP Printer
Phaser 8550 printer fault 37,008.44:25860
This is a pre heater error.
I would make sure the printer is connected directly into the wall and not into a power strip or UPC as these devices may create momentary AC voltage sags that could cause this error. If power levels going into the printer are good, you will need to contact Xerox for support
Jan 13, 2009 | Xerox Phaser 8550DP Printer
Printer screen
Your display is blank because the LCD unit is bad and needs to be replaced.
Jan 10, 2008 | Xerox Phaser 8550DP Printer
Xerox Phaser 8550DP Printer does not recognize the ink it has
  1. Open and close the Top Cover to resolve the problem.
  2. If the problem persists, arrange the ink sticks until there are no spaces between sticks of the same color.
  3. Check for non 8500/8550 ink sticks jammed in the ink load chutes.
Nov 16, 2007 | Xerox Phaser 8550DP Printer
Xerox Phaser 8550DP Printer Logo
298 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
