Question about Panasonic CQ-C8303U CD Player
CQ-C8305U display problem !
I just install a C8305U in my girlfriend accent 2002.
The back light work fine, the sound is good the volume work and I can go in the menu.
But the display dont work while the car run. But when i turn off the engine, I have a message on the screen PLEASE REMOVE PANEL !
TY in advance for your advice
I have a CQ-C5303U, IT WORKED FINE ONE DAY AND THE NEXT NOTHING. THE BACK FLASHING LIGHT STILL WORKS BUT NOTHING ELSE. IT THERE A FUSE ON THE CHASSIS?
Posted on Oct 02, 2008
  • 24 Answers
That unit has a black out feature it can be changed by pushing the display button
Posted on Feb 21, 2008
Sound 1997 acer
check in device manager and see if you need to update the sound driver.
Jan 20, 2014 | Acer Computers & Internet
My 2002 Hyundai Accent is dying at lights and when the car is at an idle
im thinking maybe a fuel filter sounds like it good luck
Aug 10, 2012 | 2002 Hyundai Accent
I have a 2002 Hyundai Accent the Alternator went out and replaced that and it started just fine acept for the following: The low beams on the head lights work high beams ( but the low beams don't work )...
It sounds like a blown fuse. Are you checking them with a test light? And have you located all of the fuses. there will typically be a fuse box under the drivers dash area, and one under the hood. have another look Im certain you'll find a blown fuse. Good luck.
Jan 20, 2011 | 2002 Hyundai Accent
Check engine light went on while starting. Car is running fine. 2002 Accent, 26k miles How do reset the light? Tried disconnecting battery, but no joy. If I have to pull the ECU fuse, where is it located...
You could go to your local auto zone to have them clear the code, but if it comes right back on it has a constant problem that will not go away until it is fixed.
May 19, 2010 | 2002 Hyundai Accent
No sound from radio, display works, speakers work, wires correct
do you have an amp hooked up to your car stereo ?
Apr 25, 2009 | Car Audio & Video
Dash lights not working, shift console lights not working
Check the wiring to the dimmer switch. Sounds like there is no power at the switch, so get a wiring diagram and trace it back toward the battery. There is either a short or open in the circuit path.
Nov 21, 2017 | 2002 Hyundai Accent
Panasonic CQ-C7103U having faceplate attachment issues.
You can order a new faceplate from Panasonic, if that is the problem. (You may find one on ebay, too?) Carefully check the connection before spending anything, as I wouldn't want to suggest spending on something that isn't broken. If you have electronic skills, check the internal connections from the jack to the internal board and every other connection. Also look for cracks in the board. If found, a light coat of solder can fix that up fairly well, and not cost anything.
Of course, this is all a guess, and I would verify everything yourself before doing anything. Good Luck.
Feb 04, 2008 | Panasonic CQ-C7103U CD Player
CQ-VD7003U
Make sure you have good amount of room around the back of the unit. It sounds like you may have an overheating problem. If that isn't it, you have a bad ground or +.
Jan 07, 2007 | Panasonic CQ-VD7001U Car DVD Player
Panasonic CQ-C8303U CD Player Logo
146 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
