Question about HP LaserJet 2840 Printer
HP 2840 printer cartridge
We replaced the black cartridge with a correct new one. But the screen keeps saying Order black cartridge, how do I make that little message go away? ! Thanks.
Also, how do we connect a new laptop to our network so that the printer can be used? Is there a key # or something like that we need to put in for this to work? We have vista.
Thanks again.
  • jeannie725 Feb 06, 2008
    thanks, link was great.
    But, can you please tell me what to do about the cartridge message? Something very simple, but I cannot find it!
    Thanks again.
    Problem Solver:
  • 16 Answers
If both of your systems are running vista go to this link and it should give you all of the info that you need to share your pinter and set up your network!
http://technet.microsoft.com/en-us/library/bb727037.aspx
Posted on Jan 29, 2008
Hi there , I have a HP 2840 Color Laser Printer that is saying "Replace Supplies " . All cartridges are showing "empty" besides yellow . I only wish to replace the black cartridge and...
There is no option like what you are expecting. But now a days all chips are avil in market simply replace the chip & cut the cost...
Sep 12, 2011 | HP LaserJet 2840 Printer
How can I override the calibrating mode on A HP LaserJet 2840 All-In-One printer. My black toner is out and it would not print any documents, keep saying replace toner can I override this until I purchase...
You Cannot override, as the black cartridge is required for all print functions. Both B/w and Color use the black, obviously in smaller amounts in color, but it still requires it none the less. Sorry, I know you were hoping to trick the printer somehow, but with HP printers it's not an option, especially on the Laser Printer models like yours.
Dec 15, 2010 | HP LaserJet 2840 All-In-One Printer
I have hp laserjet 2840 i replaced imaging drum and black cartrige now my printer says incorrect yellow and i cant get it go rotate or print?
If you used a compatible cartridge (as I assume) the problem is with the cartridge "CHIP", very common on compatible cartridges, return the cartridge or replace the chip. The chip is on the top of the cartridge and can be remove.
Dec 01, 2010 | HP LaserJet 2840 All-In-One Printer
My printer won't print---I just had the black ink cartridege refilled but it keeps saying replace supplies
Return the cartridge and use only genuine supplies with HP. HP cartridges have chips on them that dictate if they are OEM or not. Typically, if you use a refiller , these chips won't get reset.
Oct 20, 2010 | HP LaserJet 2840 Printer
HP 2840, black ink drum q3964a
Hello, these printers tend to be finicky.
In other words, just replace the black toner. When the printer says its low, or empty, regardless of wether or not it is, just replace it.
Replacing the drum, when it says black toner needs to be replaced will do nothing to rectify the issue.
Buy only HP Toner and Drum cartridges for this printer. Do not try to refill toner cartridges, and do not reset drum. You will only end up destroying your printer in the process.
Feb 26, 2009 | HP LaserJet 2840 All-In-One Printer
HP 2840 Prints Blank Pages
Black is used on all prints. Did you pull the tape on the new cartridge?
Jan 13, 2009 | HP LaserJet 2840 All-In-One Printer
Error show on panel replace black cartridge
The replacement cartridge is a cheap imitation, that does not have the proper equipment to keep this error from reporting.
Dec 25, 2008 | HP LaserJet 2840 All-In-One Printer
Re-installing yellow cartridge in HP 2840
There is a gray button right of the LCD display that has a black arrow circling clockwise and four color dots (magenta/black/cyan/yellow). Push it until you see the "Rotating to Yellow" in the LCD display, then open up the top of the printer by pushing the big gray latch next to the picture card reader at the right front of the printer. You now have access to the cartridge. pull it out and examine it. If it is a new cartridge, check to see if you pulled the plastic dam strip out (which keeps the toner in place in shipment etc).
Sep 07, 2008 | HP LaserJet 2840 Printer
Black replacement cartridge
This is an easy one, you do the black the same as each color cartridge. All four cartridges sit on a carousel that rotates.
Just keep pressing the button that's directly underneath the ready light until it says "rotating to black". After the machine stops rotating, open up the cover and put the black cartridge in.
Apr 03, 2008 | HP LaserJet 2840 Printer
Replace Cathridge
The front panel tells you witch toner cartridge should you replace. If a supply memory error ocures then the cartridge should be replaced or exchanged with a new one. The imaging drum unit is also consumable. for "Joe 50" - there are 4 toner cartridges in the printer.
Dec 28, 2007 | HP LaserJet 2840 Printer
HP LaserJet 2840 Printer Logo
127 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
