Question about Panasonic TH-50PX60U 50 in. Plasma HDTV
Screen blanks out int when on local channels
I am hooked to a dish hd receiver . This problem seems unique to only the local channels . The symptom is that the screen will blank out momentary then return , the problem seems to occur about every min or so . The thing that unique is if I go to any non local channels it works fine . The input to the tv is via hdmi1 . I would think if there was a hdmi problem it would show up on all channels ... thats not the case .
I had the same problem (a flashing HDMI 1 text box in the upper left hand corner of the screen every +/- 10 seconds) and rebooting the cable box seemed to help. I'd previously tried disconnecting and reconnecting the cables, but wasn't successful. I assume my problem originates with Time Warner Cable.
Posted on Apr 01, 2008
  • Steve Snyder
    Steve Snyder Mar 10, 2014
    only happens on att uverse
How to get full picture on my tv?
First, ensure your tv is using the highest resolution possible (Usually 1080 for flat screens) by using an HDMI cable from the receiver to the television, and that you are on the correct input. Second, ensure your tv is not sizing the video by using the 'picture size' or 'aspect' or 'ratio' key on the remote that came with your tv (Not your DISH remote). Third, tune your DISH receiver (with your DISH remote) to an HD channel (for VIP model receivers, when you tune the channel to an HD channel, an opaque white 'HD' appears insude the blue box at the top of the screen). Fourth, hit the star key on the remote, while watching the screen. On the right hand side, near the top, it will cycle as you hit repeatedly the star key, the style of screen widening. Hit the key as often as you need to make the screen appear the way you want it to. The receiver will remember your setting for all HD channels. When finished with the HD channel, tune your receiver (with your DISH remote) to a SD channel (any channel in the guide that does not have the HD icon). Repeat the fourth step.
For Hopper/Joey family receivers, hit menu, settings, screen size. Follow the instructions to resize your screen to match your preference. When finished, repeat step four above on each an HD and a SD channel.
Mar 15, 2015 | DISH Network Televison & Video
Can I use a dish 500 dish with a VIP722K receiver Ilive In eastern Pa.
If you have a clear view of the south western sky, the receiver will receive most channels (after running a check switch test, menu, 6-1-1). You will not receive most HD (which comes on Eastern Arc satelllites not on that antenna, or on satellite 129, not on that antenna) and depending on your DMA you may not get locals, but most cable channels will be available, at least in Standard Definition.
Aug 08, 2013 | DISH Network Televison & Video
3D tv issues with HD channels on Dish Network
check screen resolution of your lcd tv & receiver too
Aug 24, 2012 | Dynex DX-L42-10A 42 in. LCD TV
I have a 20 inch sanyo hd digital hooked up as a second tv on dish network receiver. I had to unhook it temp and when I hooked it back up, no picture. I tried channel scan and nothing. How can I get the tv...
bring the tv out to the main tv and hook it up to that connection to determine if it's the TV or the connection. Or try hooking up a VCR to the tv while the TV is set to CH 3. Do you get a blank picture or a snowy Picture?
Sep 20, 2009 | Sanyo Televison & Video
NOT CORRECTLY IDENTIFY SAT
The HD feed comes in on 61.5 for a majority of stations most often locals come off 119 or 110. The USA hd comes off of 61.5 transponder 19.If you press menu 611 on your dish remote and manuever the highlight to the satellite and go to 61.5 and then change the transponder to 19 you will probably have a poor signal from 0 -39. Typically this can be resolved by having the dish re-peaked but sometimes foilage may be the cause. Thanks for using Fix Ya.
Aug 02, 2009 | DISH Network 301 DTV Receiver
Have Direct TV using a Sony Digital Satellite receiver model #SAT B2-2 /Sony Satellite dish purchased in 7/97. I get local channels thru Direct TV. Recently, local channels will show on the Direct TV guide...
Your dish is out of alignment. The local channel satellite doesn't have as strong of a signal, so a slight misalignment will cause problems.
It could also be an F-connector needs to be replaced at the dish or multiswitch (if you have one). Sometimes moisture builds up inside the connector and corrodes the copper stinger inside.
If you go into your satellite signal strength menu and find the local channel satellite, you're sure to see either a weak signal or an intermittent one.
One more thing, if a tree has grown in the line of sight between the dish and the satellite, this will cause signal problems too. In this case, you either have to trim the tree or move the dish.
Hope this helps!
P.S.
The customer service reps at DirecTV usually idiots reading from a script with no real field experience.
Mar 25, 2009 | Televison & Video
Panasonic plasma TV has a black screen after disconnecting Dish TV
proably not tied in tv nomore dish will take over that prot if u got dish hd u get locakls form dish free in hd dont need attc nomore
Oct 10, 2008 | Panasonic TH-37PD25U/P 37 in. EDTV-Ready...
RCA HDTV, indoor antenna and Dish Receiver 311
I want to use two (2) 311 dish receivers with only 1 outside antenna.
Jan 08, 2008 | RCA L32W11 32 in. HD-Ready LCD Television
Directv locals
It sounds like u need to run another update on your new hd system if i can remember unplug your reciever when it comes back on welcome push 24680 that should over ride everything else if im right its been awahile though
Oct 06, 2007 | Televison & Video
Panasonic TH-50PX60U 50 in. Plasma HDTV Logo
109 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
