Question about Acer Aspire 5630 Notebook
Connecting two computers by a wired connection
I want to connect my laptop to pc (without bluetooth or internet but by simply using a transfer cable- I have an UTP cable) How can I do it ? What kind of cable is required ? Will it be done by simply connecting the cable ?
pls illustrate the process.
thank you!!
  • Parag M Feb 14, 2008
    ya i have a crossover cable-CAT 5e
    but i have 2 different OS on 2 different pcs..
    xp prof and vista hp
    how can i configure them so as to share files ?
    thank you..
    Sergeant:
  • 201 Answers
Hey there parug1987, you can connect the two computers as long as they both have network cards i.e. ethernet port. You will need a crossover cable specifically to make the connection. Also, only connect them when they are both powered down. then start both fully, allowing the new connection to be recognized. From here you can run the network wizard and choose your options. This is a short term solution. If you want to have them always connected I recommend you use a switch or router for better results. Good Luck!
Posted on Jan 29, 2008
How do I transfer pictures from Nokia Lumia 928 to laptop
You can transfer photos from your nokia lumia 928 to laptop wirelessly or wired. Wired transfer is the easiest way when your unit comes with the data cable and the software. Now, if the software is not inclusive you can set your CP's connection settings "Connected as USB memory" however you may have difficulties in viewing since the connection layer platform is not capable of viewing the pictures or images but you can view later after you copied it on your laptop. Now, if your unit doesn't come with data cable and software you can use the BLUETOOTH connection by simply turning or enabling both Bluetooth device on your laptop and cp which can be found in settings usually, once enabled and set visible you will noticed both devices sees each other with their name if not try to search manually by pressing search and chose paired bluetooth device with confirmed access code or id. Right then, when connection is successful you can start copying pics or images to your laptop. (Make sure you know the directory your pics are being copied, it is usually saved in bluetooth download images directory or other directory, pls manage to locate). Thanks hope this helps... Goodluck.
Oct 07, 2014 | Nokia Lumia 900 Smartphone Black Unlocked
How to move photos from original Moto RAZR to computer - en mass
basicly you need the data cable and the motorola software. you can most likely buy the software at the sametime when you buy the cable from the shop. if not its also available online.
May 31, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
How to connect samsung c6712 to pc without data cable?
you can use bluetooth option on your phone and bluetooth device on your laptop,On desktop computer,buy a bluetooth adapter and install it in your pc. Pair it then do any operation you want like file transfer and internet connection.
Sep 14, 2011 | Samsung Star GT-S5233 Cell Phone
How do i connect my bluetooth on my laptop with the bluetooth on my cellphone?
Do you want to connect for file transfer or internet sharing throuhg the phone's internet connectivity???, first activate the bluetooth in the computer, than activat it on the phone, than in the bluetooth menu choose the correct connection type (file transfer or internet sharing)... enter the security keys respectively and voila! connection!
Aug 04, 2011 | Dell Inspiron M5030 Laptop
To transfer pictures from iphone to computer
Use the bluetooth to connect your Iphone to the PC.
Open menu - connectivity and click bluetooth to ON.
You can also open the picture and use right key to send via bluetooth. The laptop must be On as it will detect the bluetooth, accept and get all the files send.
Sep 17, 2010 | Apple iPhone 3G Black Smartphone
HOW CAN I PUT MY VIDEOS IN THE COMPUTER?
In order to transfer your videos to your computer or vice versa. You have following few options:-
1. Wifi - If your PC is having a bluetooth dongle or your laptop is having a bluetooth then you can pair your mobile through your pc or laptop and transfer your files through bluetooth.
2. Media. In order to transfer files without wifi you require a media that could be a usb cable connecting your phone to your pc or laptop. No additional softwares will be required if on connecting a popup is coming on your mobile asking you through which instance it should connect. Select data transfer mode and you can use your phone memory or your data card on your phone just like a pen drive. You can browse and copy whatever you like.
Apr 06, 2010 | Samsung S3650 Corby / S3650 Genio Touch...
WHAT DOES USING A BLUETOOTH DO FOR ME? DOES THAT REPLACE WIFI?
Nope just will transfere your files Wire less way... it means that you can move arround 100 m freely with keep trasfer of file going on and recive call any where arround...
Jun 23, 2009 | Dell Latitude D600 Notebook
How to download songs to my cell phone
There are different ways of downloading songs to your phone. To download songs using the Internet, you should have a program to use for downloading.
For example: Lime Wire, you may install Lime Wire to your computer and then search the songs that you would like to download. After downloading your favorite song using Lime Wire, you need to save it into your computer and then, connect your phone using a USB cable.
After connecting the phone, right-click the song and then select "Send To" and then select your phone.
2nd option:
To download MP3 using a CD as your source of music, please follow the steps below:
- Connect the phone to the computer using a USB cable.
- Load the CD that carries the MP3 songs.
- Explore the CD and right-click the song that you would like to transfer.
- Select "Send To" and then select your phone.
3rd option:
You may transfer MP3 via Bluetooth. You may refer to the user manual of your phone on how to pair up your phone with another Bluetooth enabled phone and then transfer music.
Apr 12, 2009 | Nokia 6300 Cellular Phone
Transfer pics frm moto razr v3 to laptop using bluetooth
Check your bluetooth connection with the PC and use Moto Tools suite to transfer photos . Other option is to simply make a connection with your PC and send photos one by one or mark all , send all to PC via bluetooth connection
Jan 04, 2009 | Motorola Mobility RAZR V3
Acer Aspire 5630 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
