Question about Palm Treo 650 Handheld
Palm Treo 650 is not turning ON
My Treo 650 has shut off and is showing no signs of waking up. I tried changing the battery but that too hasn't helped. When I charge the cell, the battery becomes hot. What must be the problem and how can this be fixed? Pl help.
  • kirankshetty Feb 05, 2008
    I have tried a new battery but there is no response
    Problem Solver:
  • 5 Answers
Try a new battery - if you have had it for a while and not kept it charged up then it could be that it has lost its capacity to hold charge.
Good luck
Megan
Posted on Feb 05, 2008
Hi how to unlock my palm 650 to used outside of USA
You can use the Unlock code to Unlock Your Palm-One Tero 650 model Phone,You can get the Unlock code from here
Wickedunlock and follow the instructions and Unlock it step by step..
Palm One Treo 650 Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your Palm One Treo 650 mobile phones. If you enter over a certain amount of wrong unlock codes on your Palm One Treo 650 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Palm One Treo 650 with an ACCEPTED SIM Card,
2 - Go to Menu and select "Phone Tool" or "Phone Application",
3 - Type on Virtual Keyboard *#*#CODE#,
4 - Select with PEN "Numer" and Palm One Treo 650 will show that it's unlocked now!
or
1 - Switch ON your Palm One Treo 650 with a NOT ACCEPTED SIM Card,
2 - Enter the Unlock Code we send to you.
or
1. Remove Palm One Treo 650 battery, unplug cable,
2. Switch ON your Palm One Treo 650 with a NOT ACCEPTED SIM Card,
3. 'Sim not allowed' is displayed, click OK,
4. Go to the dial pad, and dial *#*#CODE#,
CODE: The unique unlock code for your Palm One Treo 650.
ACCEPTED : We mean, to use a sim card from the network your Palm One Treo 650 is locked to.
NOT ACCEPTED : We mean, to use a sim card from a network other than the network your Palm One Treo 650 is locked to.
Jul 10, 2011 | Palm Treo 650 Smartphone
Is there a way I can revert my Palm Treo 650 back to original factory settings
Factory Reset for Treo 700p and 680 smartphones
If you've set a password on your smartphone, any hard reset will automatically become a Factory Reset. With this method, you'll enter a password and then perform a hard reset.
On your smartphone, launch the Security application.
2.If the Password box says "Unassigned," tap the box and create a password for your smartphone.
3.Once the password has been set, disconnect your smartphone from the AC charger and take off the battery cover. Do not remove the battery yet.
4.Hold down Power/End .
5.While holding down Power/End , remove the battery. Then insert it again.
6.While still holding Power/End , the screen will show the Palm logo and a progress bar. Then the circular Palm Powered logo will appear. Release the power button when you see the Palm Powered logo.
Keep holding the Power button during this screen. When you see this screen, you can release the Power button.
7.A message will appear warning that you are about to erase all the data stored on your smartphone. Press UP.
8.If you performed this reset correctly, the screen will go blank after several minutes, and you will not be able to turn on your device. The charging LED will not light up. (any other activity - such as the Palm OS logo and then the Applications launcher appearing - means the reset was performed incorrectly; try again) 9.Your device will appear "dead." To wake up your smartphone, perform a soft reset.
if u like plz comment
Mar 11, 2010 | Palm Treo 650 Handheld
Palm Treo 650 Unlock Code.
Call your service provider.
Jul 16, 2008 | Palm Treo 650 Handheld
Treo 650
my treo 650 just turned of the light of the screen.thought it was only battery.i pulled out the battery then put it back again,the light is on and say palmOne with a bar loading.then the light was gone again.try to sign on but nothing does
Jun 24, 2008 | Palm Treo 650 Handheld
Palm Treo 650
Ihave a PALM TREO butIT IS not a phone and I had the same thing happen to me.
What worked for me was # 2
If you have not tried it yet try this!
1). Press the reset set button on the back of the Palm.
2)This is a little bit more memory destructive and you might want to back up you data cause it will wipe out everything!
hold down the power key and press the reset button!
May 26, 2008 | Palm Treo 650 Handheld
My palm treo 680 turns itself off repeatedly
hi dear
BACK UP your Treo 650 software and data BEFORE doing the following.
1. RESET the Treo 650 back to default set by holding power buttom following by reset the treo.
2. There is a way to reset the voltage regulator in the Treo ; believe is by holding the RESET for > 3 seconds. Believe need to take out the battery in out during this process. Can't recalled the correct steps. This could could reset the Treo's power regulator.
3. TRY reinstall your palm software with minimun software or 3rd parties one, this software could be running in the back ground which drain the battery.
Try above steps might help.
Mine also got the same problem last two weeks, my treo could felt there is kind warm sensation if it took out from my waist pouch after leaving it for sometime on the table. BTW, the battery could felt quite warm also.
If yours also behave the same which I believed the Treo got some kind of contact problem which draw more power then usually does.
Now, mine got no more warm sensetion after carry out above steps. It gets better as Compared to last two weeks ago BUT not that good as compared previously when it can last 3~4 days after a full charge.
Good luck
Mar 15, 2008 | Palm Treo 650 Handheld
Unlock code for palm treo 650
sign up at mytreo.net I was able to get an unlock code program for my treo 600 there
Jan 06, 2008 | Palm Treo 650 Handheld
Palm treo 650
You can do a soft reset by pressing the small indented button on the back with your stylus,: or you can do a hard reset by removing the battery and pressing the same button on the rear with your stylus. I would try the soft reset first, as the hard reset wipes all your data.
Jan 05, 2008 | Palm Treo 650 Handheld
Bluetooth not working w
1. Treo 600 does not support Bluetooth! 2. The battery for the treo 600 is not removable unlike that of the treo 650.
Jul 02, 2007 | Palm Treo 600 Handheld
Auto-off not working
I heard this happens after updating the Treo 650 with the new version 1.17. Is this your case? If so just remove the new update... Anyway, you can try the soft restart or even Performing a system reset(from the user guide p.170): ".. Performing a soft reset A soft reset is similar to restarting a computer. If your Treo is not responding or you have trouble synchronizing with your computer, a soft reset may help. 1. Press the Battery Door Release button and slide the battery door downward to remove it from your Treo. 2. Use the stylus tip to gently press the reset button on the back of your Treo. .."
Jan 03, 2006 | Palm Treo 650 Handheld
Palm Treo 650 Handheld Logo
66 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
